Buying transistor advice Dell E173FPc - 2 Seconds to Black
  • bigcap
    • 6
    what I found was
    top ccfls come on for 2 seconds then off even though some driver pin solders had melted...now been resoldered
    the bottom ccfls just don't come on at all. driver pins and solder look solid. tested ccfls on another display and there all good.
    before fault the screen seemed to be a lot brighter than my other identical monitor
    I'm basically looking for advice on replacing the 4 c5706 transistors.
    The one on the board are labeled c5706 with 4k printed on them.
    Can I replace with c5706 8k as I have no idea what the 4k or 8k stand for.
    was looking to get these
    http://www.ebay.co.uk/itm/C5706-3-Pi...item1c3aeb13ed
    or
    http://www.ebay.co.uk/itm/2SC5706-C5...item4605afb838
    or should I go for c5707
    http://www.ebay.co.uk/itm/C5707-Tran...48355501&rt=nc
    if anyone has a better link to the ones to get in UK, I'd appreciate very much.
    Re: Buying transistor advice Dell E173FPc - 2 Seconds to Black
    I use C5707 in place of C5706 for all my repairs.
    You also check the tunning caps (grey or white or yellow) to make sure it still have correct capacitance, and resolder all the joints.
    http://s807.photobucket.com/user/bud...?sort=3&page=1
    • bigcap
      • 6
      Hi budm thanks for replying.
      whith regards to the tuning cap I think my board is different here's my board
      are the tuning caps the 2 blue ones where the 4 transistors im gonna replace are... in-between the drivers on the left side of the pcb board?
      also I checked out the C5707 transistors. am I right in thinking they are an improved model on the c5706 ?
      as I seem to be able to get the c5706 in the UK would it be the preferred replacement and better for the ccfls lamps in the long term due to the small difference in specs ? or just go for the c5707 as there better all round spec wise for the ccfl lamps?
      http://pdf1.alldatasheet.com/datashe...I/2SC5706.html
      http://pdf1.alldatasheet.com/datashe...O/2SC5707.html
        "are the tuning caps the 2 blue ones where the 4 transistors im gonna replace are... in-between the drivers on the left side of the pcb board?" Yes.
        5707 has better spec but 5706 original is fine.
        • bigcap
          • 6
          thanks budm,
          think I will go with your suggestion c5707 as there cheaper and I get a few extras to put in my virgining electronics soldering tool box.
          Probably a stupid question but how do I measure the 2 blue caps? can I use a multimeter dmm.
          I just tried ie set to 200 on ohms scale, probes on each leg solder joint of blue tuning cap... my value 1 on dmm being open ...when probes are on legs I get .000 so closed circuit
          im almost sure ive done this completely wrong and probably need to remove them from board and have a different type of meter?
          caps are 7c184j 250V
          feeling a little embarrassed now but im hear to learn. :P
            You use capacitance meter to verify that the capacitance is still within the spec of the cap, it usually loses its capacitance when it goes bad.
            • bigcap
              • 6
              hi budm
              got the transistors
              these are results for in circuit of old transistors dmm set to 2k
              B + to E - = .608, reversed = .431
              B+ to c- = .246, reversed = .246
              when removed and tested on bench
              B + to E - = .760, reversed = 1
              B+ to c- = .756, reversed = 1
              1) I think these are all good? as new ones test .763 and .762 and on reverse is 1 on bench.
              2) do the 2 blue tuning caps cause these results when testing in sit u? I don't have a caps test meter to test them but does it indicate its them?
              3) if you look at the photo above closely the pins solder burnt out on the driver and resistor it looks like. I resoldered. but that cffl came on and went off after 2 seconds. The other side looks fine but the ccfl doesn't coming on.
              would this indicate something else is going on, on the board....or is it the blue tuning caps?
              see no point yet in putting new c5707s in as yet.
              What do u recommend?
              • Lumberjack777
                • 464
                Are you saying you have tested the C5706's on that board? That's almost ALWAYS the problem on that board. At least one has usually shorted. Here's retiredcaps method of testing from his "2 seconds to black" guide.
                "2) Shorted Transistors/MOSFETs
                On some LCD brands (example: Benq) the transistors (C5707) are sometimes shorted. Transistors are usually marked with a "Q" designation.
                If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test for shorted transistors "in circuit" (with power off and unplugged)
                a) put black probe on pin 1 and red probe on pin 2 - read/record ohm
                b) put black probe on pin 1 and red probe on pin 3 - read/record ohm
                c) put black probe on pin 2 and red probe on pin 3 - read/record ohm
                If any ohm reading is less than 30 ohm you might have shorted transistor. Remove the transistor and repeat the tests out of circuit to verify.
                Note: a shorted transistor would likely cause a very brief flash of the backlight or no backlight."
                  B+ to c- = .756, reversed = 1"
                  How about testing them off the board and also between E and C.
                  • bigcap
                    • 6
                    Hi budm,
                    I did check C and E results seemed ok. Decided to change all and removed them. tested all off board and guess what?.... one was clearly shorted. You were right Lumberjack777 at least one....thanks for chiming in.
                    its been a day and a half with new ones in and I can gladly report that you guys and badcaps can add another successfully fix dell monitor to the tally chart.
                    Much thanks!
                    Now to attempt a motherboard fix which i'll post in appropriate forum.
                    Thanks again!!!
                      Thanks for the repair follow-up and I am glad that you can repair it.
                      • 3Focus1
                        • Dec 2016
                        • 8
                        I am new at this. I am a second year EE student at LeTourneau University and don't know the best places to look for parts.
                        I have a monitor, Dell E173fpc which won't stay on, it sort of fades out. No blinking of the power light. I could just buy a used monitor for 20-30$, but I'd like to troubleshoot this one for practice. The power supply board 715L1283-4. Regular capacitors seem fine. No bulging etc. However,
                        1. C5706 5G Transistor bad? Can use C5707?
                        2. 7C184J 250V 0F ceramic capacitor Shorted. Tested by ohmeter while on circuit board (which I know is a no-no, but looking for any continuity). Looked at Mouser and found only a 50V, but not a 250V. Puzzling. Checked other sources too.
                        3. 80ll15t-7-ys g 0523 Bad transformer, 1 post blackened some solder missing. Already de-soldered and removed.
                        I don't know which happened first, the transformer went bad or the capacitor, or maybe even the transistor. I think FB901 is a fuse, but uncertain. It is very small. Anyway, it appears to be good. Of course, its a Dell, so I think they're pretty tight with proprietary parts breakdowns,etc though not certain. So just winging it really.
                        Thanks,
                        Scott
                          1) 2sc5707 is OK to use, see post 4.
                          2) Take the cap out of circuit and check the resistance.
                          3) Upload the pictures of the bad transformer and the board.
                          4) FP901 is the fuse and it should show <1 Ohm, so check that out first, it is 3A FUSE (BELFUSE).
                          Board is know for bad solder joints and bad caps in the Royer Osc. section.
                          Did you read the whole thread?
                          • 3Focus1
                            • Dec 2016
                            • 8
                            I'll look more closely at the other posts.
                            Edit: I see the image is not uploading. I'll try to figure that one out.
                              • 31090
                              lol
                              upload the photo, dont link it to your desktop!
                              • 3Focus1
                                • Dec 2016
                                • 8
                                Diagnostic picture.
                                • 3Focus1
                                  • Dec 2016
                                  • 8
                                  A couple more.
                                    The brown spot at the transformer leg is due to poor solder joints so it develop contact resistance which will heat up. As indicated, that board is known for lots of bad solder joints, just look real close at the legs of the parts for cracked solder ring around the leg of the parts.
                                      BTW, those two blue tuning caps will show low resistance because it is connected in parallel with the transformer primary winding which has low DCR. You need to check the capacitance to make sure it is still within tolerance.
                                        • 31090
                                        those capacitors arent ceramic, they are plastic film.
                                        probably polypropylene or polyester.
                                        • bohaboha
                                          ADVICE FOR BUYING A DIGITAL MICROSCOPE
                                          by bohaboha
                                          Hi I'm thinking of buying this :1080P 4K HD Industrial Microscope 150X C-Mount Lens 48MP/13MP Digital Camera HDMI USB-C VGA Measurement For PCB Soldering DIY it's on ALiExpress : https://www.aliexpress.com/item/1005...av-description
                                          the one i choose is the D full Set
                                          maybe you can advise me or maybe someone who has similar who can give feedback on it very grateful for...
                                          02-24-2025, 07:13 PM
                                        • bohaboha
                                          Buying some single smd led diode for tv repair, your advice needed
                                          by bohaboha
                                          I'm thinking of buying some single smd led diode for tv repair to have under hand there is so many, 2835 k-6000k 9v.6v, 3v white etc but don't know which to have if you advise me which Should I buy and which is most usual and bäst to have under hand. thank you
                                          03-28-2024, 02:00 PM
                                        • Hondaman
                                          Windows 11 buying advice needed
                                          by Hondaman
                                          My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                                          She does not want to switch to Linux. And she does not want to use a laptop because...
                                          04-14-2025, 11:35 PM
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          08-11-2025, 02:14 PM
                                        • twonk9098
                                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                                          by twonk9098
                                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                          I have tried a few new bios but exactly...
                                          07-14-2024, 11:19 AM
