Samsung Syncmaster 244T screen goes crazy
  • pixelphoto
    • Dec 2011
    • 16
    I recently replaced ALL caps except the largest cap on the ps board. Monitor works fine. Except through out the day, and this has been happening for over a year but becoming worse; out of nowhere the monitor screen goes haywire. The screen locks up and displays horizontal lines of mixed colors and sizes before the computer (Mac Mini late 2012) reboots. This occurs when the monitor and or computer are hot or cold.
    I have been suspecting my neighbor(s) of RFI/EMI. Sometimes it happens when one of them comes home. Talking to them to see if they are turning on electrical appliances, etc is futile.
    Any suggestions, advise would be greatly appreciated. I will soon replace the largest cap on the ps board.
    Thanks,
    Marvin
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung Syncmaster 244T screen goes crazy
    Please update your profile with country and mains voltage.
    What make series of caps did you use as replacements.
    Can you test the monitor on another PC/input
    Have you a second monitor/TV you can use to test the PC
    • pixelphoto
      • Dec 2011
      • 16
      Replacement caps were Panasonic and Rubycon of a higher quality and lower ers than original caps. USA, 120VAC 60Hz.
      No, I do not have another computer or monitor.
        "The screen locks up and displays horizontal lines of mixed colors and sizes before the computer (Mac Mini late 2012) reboots." How about trying with another computer, the monitor will not cause the computer to reboot or lock up.
        • pixelphoto
          • Dec 2011
          • 16
          1
          • pixelphoto
            • Dec 2011
            • 16
            https://www.badcaps.net/forum/attach...1&d=1435731463
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              looks like video corruption something is wrong with your mac.
              My pc
              CPU : AMD PHENOM II x4 @ 3.5Ghz
              MB : ASUS M4A89TD PRO USB3
              RAM : Kingston ValueRAM 16gb DDR3
              PSU : Cooler Master 850W Silent Pro
              GPU : ATI Radeon HD 6850
              • diif
                • Feb 2014
                • 6978
                • England
                Looks like logic board failure (BGA).
                • pixelphoto
                  • Dec 2011
                  • 16
                  Mystery solved! About eight months ago I decided to use my my Mac Mini as a music server. In a attempt to reduce vibrations and resonance I placed a 3.5" square box full of pennies on the Mac. Just last week I removed the pennies and disassembled the Mini to a degree to see if I could see if any fault was visible. I realized that the Mini being so packed with no room to spare that maybe the weight of the pennies was just enough to cause contact of parts after the Mini was warmed up. I reassembled the Mini and booted up and let the it warm up without the pennies sitting atop it. Well I haven't had a problem since. Isn't that interesting?
                    09-07-2024, 05:50 AM
                  • soopacrucial
                    by soopacrucial
                    Hi folks,
                    10-29-2024, 02:40 PM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
