7" LCD monitor display stopped working
    • 32065
    i think thats the enable pin for the backlight boost convertor,
    is it shorted to ground on either side of the resistor?
    • flat-earther
      • Dec 2022
      • 209
      • palestine
      #42
      Not shorted to ground. resistance to ground on either side of the resistor is close to identical on both monitors, in the kohm range.
        • 32065
        if you pull the pin of the 6pin device to 3.3v does the backlight come on?
        • flat-earther
          • Dec 2022
          • 209
          • palestine
          #44
          yes it does
            • 32065
            so, if you do that while feeding a dignal do you get the image?
            just wondering if the main chip is running with a bad pin or something worse.
            • flat-earther
              • Dec 2022
              • 209
              • palestine
              #46
              if I do it there's no image, only backlight.
              • flat-earther
                • Dec 2022
                • 209
                • palestine
                #47
                I went around with an iron and reflowed all pins of the main chip but it didn't help.
                  • 32065
                  then it's the main chip i guess - or the flash chip, but i think thats good or you couldnt have dumped it.
                  • flat-earther
                    • Dec 2022
                    • 209
                    • palestine
                    #49
                    Thanks stj. now I too think it's the main chip...
                    • flat-earther
                      • Dec 2022
                      • 209
                      • palestine
                      #50
                      Is the AMT630A main chip programmed or all firmware is on the flash meaning if I can get a new AMT630A it would function straight away?
                        • 32065
                        i imagine it's all on the flash or it wouldnt need one.
                        i was thinking your soldering skill/equipment wasnt upto that pitch of soldering or i would have suggested aliexpress.
                        • flat-earther
                          • Dec 2022
                          • 209
                          • palestine
                          #52
                          I just wonder what's the purpose of the 4 pin header contacts on the middle of the PCB and whether it was used to program the main chip in factory? one is 3.3V, G, and two of them go to the main chip pins 60 TXD_SDA and 61 RXD_SCL.
                          But if the flash really has all the firmware then I could attempt changing the main chip as they exist on ali.
                          I don't have hot air but I may be able to do it with an iron. I initially didn't think I could do it and worried I would just bridge the tiny pins but after I reflowed the pins earlier it actually wasn't too bad, I had a bridge but sorted it with wick...
                            • 32065
                            i checked the datasheet again, that serial port is for remote control - probably for testing it at the factory.
                            however, the chip has a metal plate under it to transfer heat - so you cant remove or fit one without hot air.
                            • flat-earther
                              • Dec 2022
                              • 209
                              • palestine
                              #54
                              Thanks.
                              I just found some images and there's actually no metal plate so great.
                                • 32065
                                they must have changed the packlage after they drew the datasheet!
