is the crystal at pins 14&15 running?
7" LCD monitor display stopped working
If the flash chip is corrupted, if I can get my hands on another working monitor can the firmware from its chip be copied to a new chip?
with CH341A
This is my first scope I have nothing to compare it to but yea it's cool.Comment
Alright but I also want to know regarding the scope video I shared in post 20, why are the voltages on pin 1 CS CE and pin 2 DO so unstable and random?
is that from corrupted flash or the chip is bad?Comment
that does look strange.
clearly the data on dio is 5v, a bit surprising as i was expecrting it to run at 3.3v
and the clock is good,
pins 1 & 2 look a bit fucked!
try resoldering those signals on both chips - if that dont fix things i hope it's the flash chip.
Thanks for advice,
I reflowed all pins of the flash, didn't touch main chip as it's too small for iron.
The monitor still doesn't work but now flash pins 1 and 2 have change in behavior, pin 1 shows square wave, pin 2 has activity but it's weird as if there are two superimposed signals at once, how is that possible?
here is recording https://drive.proton.me/urls/2J4V7WBQKR#Rnl7CLCl5Zf3Attached FilesPremium supporters get full download access and other benefits.
If I get another functioning monitor can I extract the firmware from its flash with CH341A or is it read protected?Comment
I got a CH341A and with a clip and NeoProgrammer read the flash from the non working monitor.Attached FilesPremium supporters get full download access and other benefits.
I got another working monitor and extracted the contents of its flash chip.
Then I desoldered the chip of the faulty monitor and wrote to it the dump I got from the working monitor, but the monitor still doesn't work.Attached FilesPremium supporters get full download access and other benefits.
Just to be sure I just desoldered the flash chip of the working monitor and the read came out identical.Comment
on the working monitor's flash chip signals on pins 1 and 6 look a bit different https://drive.proton.me/urls/53DGRCVCNR#yUmnk2DPVZ0dComment
I found a problem,
on the working monitor there is 3V being delivered from the main chip's pin 58 (P07/DC_PWM3/RXD) through a 1K resistor to KDG2B (marked KDE2D on the faulty monitor),
but that pin is at 0V on the non working monitor.Comment
look at the red line in my image. those two points are connected.
It can't be an input because on the left side of the resistor there is 3.3V and on the right side the voltage drops a bit to 3V, that's on the working monitor.Comment
Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
- It started with a bright and greenish picture upon starting a cold monitor.
- About 2 years ago, only on the cold boot, the screen started to occasionally flash with
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by TheNewGPTL;DR: Bought this card dead. Reflowed a cracked 330 inductor near the PCIe edge which brought it from completely invisible on PCIe to fully enumerating. NVVDD confirmed working at 0.796V, all phases balanced. All measurable external rails are present. But driver initialization fails (RmInitAdapter) across two systems, three slots, six driver versions, and two operating systems. BAR0 register probe shows GFW firmware stalls at phase 3.3 with two distinct groups of internal registers unreachable (all PLLs, all FBPA partitions, FBHUB, SPI flash, fuses, display, several Falcons). Looking for guidance...
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by Rick_1234Good evening, gentlemen.
https://****************/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
- Loading...
