I have a 7" LCD TFT monitor that works with composite video.
I didn't use it for some months, today I came to use it, plugged my 12V battery into it as usual and it turned on but then after a moment it turned off.
I power cycled it several times and it turned on again, this has never happened before... well anyway it worked for couple minutes and after that the screen turned off again and now it doesn't turn on anymore...
I opened it to check the PCB, there is a AMS1117 3.3V regulator in the middle of the board, a NDP2435KC 5V regulator near the electrolytic caps, both make the correct voltage according to my DMM, I don't have a scope.
The red and green wires on the big plug are battery + and - for the board. The yellow and black are video signal and video ground. The four other black wires go to a small board on the front with buttons for menu etc.
I noticed that when I give the monitor power there is a very faint change on the screen but no backlight at all, it feels as if the screen becomes slightly more black when powered on, but it's very slight, almost unnoticeable.
