Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
flatron lcd 575lm monitor blinking white screen
    Posted Photos 14 Photos
  • tech9pc
    Hisense 50" 50A6KV VIDAA TV Washed Out White Screen Problem
    by tech9pc
    Hisense 50" 50A6KV VIDAA TV Washed Out White Screen Problem. 2025 Model only about 1yr old. Puzzling because everything works except whited out screen barely visible picture. Screen is not cracked. Any ideas / suggestions? Would this be a all in one mainboard problem or is the screen failed. When on can barely see the image on screen, connects to WiFi and everything. Took back off and mainboard looks clean and new, reseated cables. Tried resetting the system to factory and it is the latest update May 2026. I researched this model online and apparently in the last 12 months about 2 out of...
    05-03-2026, 07:20 PM
  • harp
    White screen repairs
    by harp
    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
    05-13-2024, 03:43 AM
  • usmantemuri
    TCL 55-Inch TV No Picture, Only White Screen After Ribbon Cable Test
    by usmantemuri
    I have a 55-inch TCL TV with a T-Con board model ST5461D04-1-C-7.
    I saw on the internet that if one of the panel ribbon cables is disconnected, the TV may display half of the screen. However, in my case, when I disconnect either ribbon cable, that side of the screen turns completely white. The same thing happens on the other side as well.
    There is no picture at all—only a white screen appears when either ribbon cable is removed.
    08-01-2026, 04:47 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
    by momaka
    03-15-2023, 10:17 PM
