flatron lcd 575lm monitor blinking white screen
  • jean luc ferre
    jean luc ferre
    • Jan 2025
    • 66
    • France
    hello,
    thank you for your help and all your contributions.
    i made some new tests...
    lowering the resolution of the screen from 1024x780 to 800x600 suppressed all the instability; the screen remains lighted and didn't blint...
    putting a coin on the gnzan1 chip for acting like a radiator made the saving energy process (color amber of the power indicator led) is happening less frequently....
    so i supposed that all the difficulties came fom the operating conditions.
    but i have allways a default ; i don't see the osd screen and the error message when the vga cable is disconnected...
    thank you for all
    jean luc ferré
    • jean luc ferre
      jean luc ferre
      • Jan 2025
      • 66
      • France
      hello,
      as i said yesterday i can confirm that if i adjust the parameters of the graphic board for this flatron monitor to : resolution 800x600, frequency :56hz there are almost no cut off of the light on the screen; and the gmzan1 processor warms very less.
      i also noticed that changing of pc with this time an nvdia graphic board rather than an amd/ati now i haven't no more cutt off of the display and no amber color of the power indicator led. Probably that was a matter of power options of the pc.
      Now i will look why i am not displaying the desktop of the pc on this screen.
      Once more thank you for all.
      Jean Luc Ferré
        Back Again?
        • 32839
        If the input signal is VGA, try changing the VGA cable.
        It could be such an old monitor got upset by bad video signal.
        For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
        Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
        • jean luc ferre
          jean luc ferre
          • Jan 2025
          • 66
          • France
          hello,
          thank you for your answer...
          the vga cable works fine with other display and pc...
          i am waiting for a cooling radiator that i could stuck on the gnzan1 chip...and we will see.
          i have also ordered the controler kit in order to dispel any doubt about the quality of working of the screen itself. (a new screen that's relatively expensive!!!).
          thank you for all.
          Jean Luc Ferré
          • harp
            • Jun 2022
            • 742
            • Planet Earth
            Changing resolution to lower one, it cause less generated heat in processor, but also less current consumption, or involving less running signals to operate, so your conclusion to do a better cooling is maybe a unclear step. I have one monitor that work in bios / boot time / dos, but blinking in graphics. The fault is a small caps on controler board which control some signal, not even power rail... I found faulty one also by changeing temperature while measuring point which fluctating. You can see in video https://m.youtube.com/watch?v=aPAeZWeJ-nw
            • jean luc ferre
              jean luc ferre
              • Jan 2025
              • 66
              • France
              #26
              Thank you a t Harp for his answer.
              i examined severa times the main controler board; and nothing strange appeared...all the signals and power rails are ok...
              Perhaps it's a matter with the inverter board because tle coils l1 l2 of the filters are very hot.
              waiting for new ideas.
              Jean Luc Ferré
              • jean luc ferre
                jean luc ferre
                • Jan 2025
                • 66
                • France
                #27
                After the holidays i come back to you for more informations about this issue.
                i noticed that with anothers pc with others graphic boards (nvdia, intel hd graphics, instead of amd ati) the blinking phenomenon disapeared. i also put a small radiator on the Gmzan1 chip which improved things. With all that, now i no longer experienced disconnections of the screen with the switch to amber of the power indicater.
                Nevertheless i haven't the correct informations displayed on the screen...it might be a problem with the graphics panel?
                i haven't yet used the hitachi graphics controler i mentioned to you previously.
                Waiting for your answers.
                jean luc ferré
                • jean luc ferre
                  jean luc ferre
                  • Jan 2025
                  • 66
                  • France
                  #28
                  removing the original controler board by the contoler kit suited for screen; then this last one works perfectly. The problem is due to the controler board breakdown. i will soon change the 10µF 16v cpacitors and we will see.
                  Thank you for all.
                  Jean Luc Ferre
                  • jean luc ferre
                    jean luc ferre
                    • Jan 2025
                    • 66
                    • France
                    #29
                    hello,
                    i changed three capacitors (but not the others) near the lvds chip and the results are the same (screen blinking...) .
                    I have been very interested by the link that Harp quoted us previously in this post.
                    I walked a chunk of ice (in a plastic bag) all around the components of this controler board; and that's only near the L4973D5.1(U13) controller that i saw something different. Effectively then, the blinking of the screen stopped but equally the green led of the power indicator blinked approximatively at the same rythm. (that's very strange). And this lasted as long as the chunk of ice is present...
                    As soon as i will have the time i will noticed the voltages near this controller...
                    Does that ring a bell for anyone? IA didn't find appropriate solution for thi breakdown.
                    waiting for your answers after this long pause.
                    Jean Luc Ferré
                      Back Again?
                      • 32839
                      It is not uncommon to find components that are sensitive to temperature when they have failed, it could be a bad voltage regulator, or the scaler chip has an internal fault. Sometimes can be due to static damage (ESD) which makes the chip "walking wounded".
                      • tech9pc
                        Hisense 50" 50A6KV VIDAA TV Washed Out White Screen Problem
                        by tech9pc
                        Hisense 50" 50A6KV VIDAA TV Washed Out White Screen Problem. 2025 Model only about 1yr old. Puzzling because everything works except whited out screen barely visible picture. Screen is not cracked. Any ideas / suggestions? Would this be a all in one mainboard problem or is the screen failed. When on can barely see the image on screen, connects to WiFi and everything. Took back off and mainboard looks clean and new, reseated cables. Tried resetting the system to factory and it is the latest update May 2026. I researched this model online and apparently in the last 12 months about 2 out of...
                        05-03-2026, 07:20 PM
                      • harp
                        White screen repairs
                        by harp
                        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                        05-13-2024, 03:43 AM
                      • usmantemuri
                        TCL 55-Inch TV No Picture, Only White Screen After Ribbon Cable Test
                        by usmantemuri
                        I have a 55-inch TCL TV with a T-Con board model ST5461D04-1-C-7.
                        I saw on the internet that if one of the panel ribbon cables is disconnected, the TV may display half of the screen. However, in my case, when I disconnect either ribbon cable, that side of the screen turns completely white. The same thing happens on the other side as well.
                        There is no picture at all—only a white screen appears when either ribbon cable is removed.
                        08-01-2026, 04:47 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                        by momaka
                        03-15-2023, 10:17 PM
