Using Polymers to replace 2nd stage lytics (Samsung Syncmaster 223BW)
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5077
    • US
    • computers, electronic stuff
    This board has bloated Samyoung NXE's (16v 1000uf). They're 8mm and 19mOhm. Mouser has the equivalent Panasonic out of stock. The bitch is these are 8mm. Only ones in stock that come close to the ripple (but not beat it) are 30mOhm.
    Polymers I find that work are Nichicon 16v 820uf and really low ESR (0.008), 7A. I've heard even on SMPS boards this can cause issues. Now I'm replacing the NXB's with Kyocera RPF polys that are just one mohm under and 3200mArms (vs 2000 mArms which is just perfect). I'll also be replacing the inverter caps with these too, and replacing the other NXB (yellow writing) with a more than sufficient lytic (matches ohms and ripple almost exactly with a slight bump up on the ripple)
    I've read that using poymers with such a decrease in impedance can cause high frequency voltage spikes in these types of circuits. Mind you I'm not sure if they're in the VRM in or out.
    edit: oh yeah the symptom is hitting the power button turns the power led on for two seconds, then it turns off, and starts cycling (no backlight fires during this)
    • 31771
    so,
    polymers have 3 potential problems.
    1: they have high leakage current.
    so fine for smoothing power but very bad for circuits that put a cap in series with audio/video signals to block DC.
    2: the impedance is so low that some psu circuits think the output is shorted and go into a shutdown-restart loop.
    this can probably be eliminated by changing feedback components if you have a schematic - but we dont need to get that deep into it.
    3: *if* you have a group of several on a power rail the initial inrush with such low impedance could blow a fuse.
    but thats only on like 1970's or 80's industrial psu's that would use a bank of 4 or more regular electrolytics on a single rail.
    inrush limiting could fix that anyway.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5077
      • US
      I haven't put them in yet. The restart loop is from the bad NXE's. But I'm honestly out of options on those. Lytics are too high ESR, polymers are too low.
        • 31771
        when i recap monitors i just stuff them with FR's
        not had a problem yet.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5365
          • New Zealand
          • Electronics and computer repair
          One option is to go a little ghetto with it... single sided board, likely large traces in that area. You can probably drill some extra holes, scrape away some solder-mask, and position the capacitors further away from each other so you can squeeze in some 10mm diameter parts.
          Or just go with the Panasonic FR as suggested by stj, the ratings are close enough they should work for ages. Remember there will be some (or should be) derating of the parts in the design spec, so they won't be running at max ratings generally. So a slightly lower spec'd part will often work just fine.
          Probably the backlights or something else will fail before the new capacitors wear out.
          (Although backlights can be replaced, too)
          -David VanHorn
            • 31771
            actually, after the caps the thing that fails the most is the mosfets in the ccfl invertor circuit
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5077
              • US
              motherfucker. I couldn't find my ruler so I eyeballed the sizes. These are 10mm. A FR would have worked and mouse had them in stock. In fact I found lytics for everything in 10 minutes. Well I already put the nichicon polymers in so I can't take them back.
              I have backlight turns on and off with the button, but no logo. Video board is probably damaged from continual use with the original bad caps. I'll have to take a closer look at that (I never detached the LVDS cable, so I know it's not that)
              • lotas
                • Jan 2016
                • 5353
                • Russia
                The firmware on the SPI Flash 25l1005mc has crashed. A common problem is swollen capacitors (unstable, pulsating power supply).
                Also check the electrolytics on the motherboard and whether 5V, 3.3V, 1.8V are present (without pulsations)
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5077
                  • US
                  I think you're right. I think the eeprom is corrupted. Anyone know where to find the .bin? Board is BN41-01075A/2008.5.16/Rev MP1.0
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5365
                    • New Zealand
                    I'd like to know too, I have a monitor the same model or very similar that also has similar problems, that I never fixed.
                    The power supply had all dead capacitors, but upon replacing them, the mainboard still wouldn't start.
                    Voltages were all OK on PSU and mainboard, but the microcontroller won't respond to the power button input signal and the monitor never turns on.
                    -David VanHorn
                    • lotas
                      • Jan 2016
                      • 5353
                      • Russia
                      Try
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5077
                        • US
                        shit I have to be a premium subscriber to download? I've been here longer since anyone in this thread (though one not by much), and am a mod.
                        • Tesla
                          • Jul 2011
                          • 152
                          sh*t I have to be a premium subscriber to download? I've been here longer since anyone in this thread (though one not by much), and am a mod.
                          Yeah, it just means you pay a little for a month of downloads. I think I read it's so he can keep the website online (without all that ad nonsense).
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5365
                            • New Zealand
                            Yes it's a bit ridiculous when you've been here almost 20 years but the site changed ownership and apparently needs to make money for itself now...
                            -David VanHorn
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5077
                              • US
                              Well I got the flasher. Flashed it with the bios. Wouldn't even turn on, no backlight at all. Tried to flash it back to original bin and the clip came off and I tried to put it back on while still connected to the programmer. Pretty sure the chip is dead. I tried.
                              • lotas
                                • Jan 2016
                                • 5353
                                • Russia
                                Did you indicate the motherboard number correctly? This number points to the monitor keyboard.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5365
                                  • New Zealand
                                  Get another EEPROM? It's only a small capacity one, they're cheap.
                                  -David VanHorn
                                  • Tarot Superstars
                                    How The AC stage of an Adaptor works
                                    by Tarot Superstars
                                    Hi. I have been watching videos on how a power adaptor works.
                                    There is explanation of the rectifier bridge to the pulse width modulator, the mosfet for switching, and opto-couplers, but there is little to nothing about the AC stage of the transformer the powers the primary coil.
                                    So, I see that the PWM needs DC to work, but I don't see anything about how the AC gets from the mains supply to the transformer stage.
                                    A transformer only works on AC so where is that part of the circuit.
                                    I only see Capacitors on the output. Should I assume that the secondary coil and...
                                    09-27-2023, 01:00 PM
                                  • privato89
                                    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                    by privato89
                                    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                    Let's begin:
                                    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                    03-26-2024, 06:37 AM
                                  • soopacrucial
                                    Samsung Syncmaster 740BF repair
                                    by soopacrucial
                                    Hi folks,
                                    I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                    Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                    10-29-2024, 02:40 PM
                                  • jdfnnl
                                    Syncmaster 225BW Repair
                                    by jdfnnl
                                    I am working on repairing this Syncmaster 225BW for the second time. I don't remember if the symptoms were the same, but the first repair was replacing the caps of course. This time the monitor turns on for a couple seconds then goes black, but think I can still see a faint image. The power button does not seem to work, it just stays lit. Took out the power / inverter board and the tops of the caps seem completely flat. I do not have intuition about testing with a multimeter so was thinking of just replacing a part. I read somewhere that when the screen is on without being backlit, the inverter...
                                    11-02-2025, 02:45 PM
                                  • MindSober
                                    Stage light - 27" 5K Late 2015
                                    by MindSober
                                    I bought a Late 2015 27 inch 5K iMac without an HDD. At this stage, I was able to make an external SSD boot disk and it's working (externally). My plan is to install it inside later. But, as you can see in the pictures, it has some periodic lights on and off at the bottom edge of the screen, all the time. I'm new to Mac by the way. My understanding that this could be due to the LED strip(s)/bulbs or maybe the cable or maybe the board?. There is practically nothing online for videos on this matter and model that shows clearly what's happening.
                                    I'm not even sure if it takes 1 or 2 LED strips?...
                                    07-22-2023, 04:59 PM
