Black screen Samsung syncmaster 203B
  • mani300
    • Oct 2014
    • 14
    • France
    Hi !
    I have a little problem with my lcd display since couple of weeks, my screen has become black suddenly, we can see anyway with a flashlight some icons when i push the button menu for example.
    I think the problem is the power supply board (i've attached the service manual), i have already change the bad caps but the screen is still black. May be it's the inverter or somehting else, i'm not so good in electronics, i just read a lot of thread like this and watch video, so i will try to be clear with my answers, i'm sorry for my english but i'm a french guy...
    so please help me
  • 1supertech
    • Apr 2012
    • 384
    Re: Black screen Samsung syncmaster 203B
    Check fuse F301,and F101 cap job doesn't look that great caps are too tall looks sloppy
    • mani300
      • Oct 2014
      • 14
      • France
      How can i check this fuse ? i have a multimeter but i don't know how use it
      yes, i've bought caps in a electronic store who have only this type of caps and no shorter. So i have to twist them...
      If the soldering is good, it's ok no ? it looks like crap i know but i doesn't have a choice
      • Agent24
        I see dead caps
        • Oct 2007
        • 4963
        • New Zealand
        It's acceptable, but not optimal. Ideally you should get capacitors the right size. As long as nothing is shorting out or liable to short out, it's OK.
        The bigger potential issue is that the lack of choice in capacitors means you may have a series which is not suitable for the circuit. This is unlikely to cause complete operation failure, though.
        Likely the old, failed capacitors helped kill something else, you've solved the capacitor problem, now you have to find out what else went wrong because of them.
        We need more info. You say you get a black screen, but do you get anything else? Does the power LED come on etc?
        -David VanHorn
        • mani300
          • Oct 2014
          • 14
          • France
          The new caps have the same specification that the old one, it's just the size is different.
          When i turn on the screen, the power led is on (color blue, no flicking) but the screen is black, so the neon (backlighting) doesn't work.
          Please how can i check the fuse with a multimeter ?
          • Agent24
            I see dead caps
            • Oct 2007
            • 4963
            • New Zealand
            With the monitor powered OFF, set the multimeter to the lowest resistance scale, or the continuity test function.
            Connect one probe on either side of the fuse, you should get continuity beep or very close to zero ohms (like 0.01 Ohms or such). A fuse is just a piece of wire with basically no resistance. But when it blows, it goes open circuit, so you get nothing.
            If you are confused as to what reading you should see - touch your probes to each other and see what the reading is. You should get much the same if the fuse is good.
            You may also wish to read this: https://learn.sparkfun.com/tutorials...e-a-multimeter
            -David VanHorn
            • mani300
              • Oct 2014
              • 14
              • France
              i have testing with the continuity test function:
              the fuse F301 get a big score and increase until overload
              the fuse F101 get a zero or very close to that.
              When i measure with the ohm meter the fuses outside the circuit:
              F301 => nothing at all
              F101 => (range 200 ohms) => 00.5
              do you think that the problem will be solve by changing this 2 fuses ?
              • Agent24
                I see dead caps
                • Oct 2007
                • 4963
                • New Zealand
                It sounds like F101 is OK and F301 is blown.
                This makes sense - F101 is the Mains fuse for the 240VAC and you do have power to the rest of the circuitry, while F301 is likely for the inverter circuitry, hence why you have no backlight.
                Quite possible you have something shorted in the inverter section.
                Unfortunately the service manual doesn't show the PSU schematic, only the mainboard, we can try to find another manual, but in the meantime:
                Check for shorts to ground from both sides of the F301, you may get a low ohms reading on one side. If you do, probably there is a short somewhere in the inverter. If you don't, check anyway the two 8-Pin MOSFETs that drive the transformers, possibly one or both will be shorted.
                Also if you can get a nice clear photo of the underside of the PSU that will help, as well as part numbers of those MOSFETs if you aren't sure how to check them.
                -David VanHorn
                • mani300
                  • Oct 2014
                  • 14
                  • France
                  I found this http://archive.espec.ws/files/sem2005.pdf and this for the mosfet http://www.aosmd.com/res/data_sheets/AOP610.pdf
                  if it can help, and 2 pictures of the inverter part.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4963
                    • New Zealand
                    I would start with checking with diode test or resistance test across the power rails of the inverter (that is, across C316 - just after the fuse) If you get a low ohms reading, something is shorted and should be further investigated.
                    Of course you don't have to do this, but you will waste fuses if there is something wrong and you don't check.
                    I would check across those two MLCC ceramic SMD capacitors next to C316, the MOSFETs (check between the D1\S1 pins and D2\S2 pins, you should get only the body diode voltage drop when forward biased) You could also check between the Gate pins and other pins, there should be no connection at all.
                    -David VanHorn
                    • mani300
                      • Oct 2014
                      • 14
                      • France
                      Can you show me on the pictures of the circuit where exactly i got to check please?
                      for example, where is "across the c316" ? you know what i'm sayin' ?
                      and i don't understand all of your sentences like "you should get only the body diode voltage drop when forward biased" i'm sorry but its difficult for me, i know very few things in electronic, and added english it's even more harder
                      than you for all anyway
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4963
                        • New Zealand
                        OK, no worries, I will try to explain... When I say 'measure across', I mean to put the probes of your multimeter 'across' the leads of the component - one probe on each leg.
                        Typically this is said when talking about a component with two leads\legs: "measure across the component" - OR talking about two points in a circuit "measure across the voltage rail" (Hope that makes more sense??) - I've never really had to explain this so I don't really know the best way to say it!
                        In any case: See the picture I've attached that shows where to put the probes for the first test (Set to low ohms or continuity test). Hopefully this will explain better what I mean by 'across C316'
                        -David VanHorn
                        • mani300
                          • Oct 2014
                          • 14
                          • France
                          ok ok, thank you for the pictures, it help me a lot.
                          All is good then, so do you think that only the fuse F301 ? i will receive it soon anyway, i keep you posted.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4963
                            • New Zealand
                            I can't say with certainty that the inverter is OK, just that there is no short across its power rails. I think you should at least check the MOSFETs as well. (I will post a picture of where to check these too if you need)
                            -David VanHorn
                            • mani300
                              • Oct 2014
                              • 14
                              • France
                              I try to check the mofset thanks to your indications and the pdf document but i'm not sure, so yes if it not bother you i would like a picture
                              thanks !
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4963
                                • New Zealand
                                OK I have a list of 6 photos to test the MOSFETs. Use diode check mode, probe each pair of pins, and swap probes around so you check each pair in both directions. Do this for both MOSFETs.
                                You can also check the driver IC, ceramic capacitors, and transformers following the other photos. You shouldn't need to test both ways for these tests. Do the transformers with resistance test.
                                Write down the results and post them here. Hopefully it is easy to follow.
                                -David VanHorn
                                • mani300
                                  • Oct 2014
                                  • 14
                                  • France
                                  Thank you for all this pictures very understandable, so here's the results:
                                  test1: overload; 636 (one direction; opposed direction)
                                  test2: overload; 1601
                                  test3: overload; 815
                                  test4: 193; overload
                                  test5: 1154 (not so sure my be overload too, various measures); overload
                                  test6: 783; overload
                                  for the other mosfets i've exactly the same results
                                  test7: 673
                                  test8: 630 (for the both capacitors)
                                  test9: 1ohms may be less (0.8)
                                  test 10: 1350ohms (red arrow) 1360ohms(blue arrow)
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4963
                                    • New Zealand
                                    Well it does not appear that any of those parts are shorted so that is good. I think you can try a new fuse and see what happens.
                                    With regard to the transformer primaries, they are normally quite low ohms so that is OK.
                                    -David VanHorn
                                    • mani300
                                      • Oct 2014
                                      • 14
                                      • France
                                      Yessss it's perfect ! my screen work !
                                      Thank you, thank you so much man, I appreciated all the things you've done for me.
                                      And when i ordered the fuse, i order capacitors too with the right dimension, so i replaced them all, i should have take a picture, it's clean now
                                      Thanks again, see you...
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4963
                                        • New Zealand
                                        Great!
                                        -David VanHorn
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • totof
                                          Samsung UE50KU6070 black screen
                                          by totof
                                          I have my TV model UE50KU6070 which I am trying to repair.
                                          BN41-02528A / BN94-10800C motherboard.
                                          If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                          When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                          After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                          09-26-2022, 02:34 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
