acer x223hq monitor turning off/on
  • anno
    • Sep 2007
    • 140
    • netherlands
    i have an acer x223hq lcd monitor wich is shutting down after some time, then turning on again. when shutting down the 5v for the mainboard is going to 0v.
    i could'nt find any bad components. i changed the 'vcc capacitor' for the Power IC, but that didn`t help.
    anyone can help?
  • jetadm123
    • 2169
    Re: acer x223hq monitor turning off/on
    Post some good overhead photos of the power and main boards. Sounds like a heat related problem. With the monitor working, I suggest you heat up the power supply and mainboard with a hair dryer until the monitor turns off. Once you identify which board is causing the problem, repeat the heating process over various parts of that board to try and isolate the area of the board that's causing the problem.
    • anno
      • Sep 2007
      • 140
      • netherlands
      ok thanks. i put some freeze spray on the power ic and then it stays longer on. so i think that ic is bad. i am going to change it and see if monitor is ok then!
      • anno
        • Sep 2007
        • 140
        • netherlands
        the IC came in and i replaced it and all is fine now
        • Picaxxxu
          • Oct 2013
          • Portugal
          Hi there!
          Sorry to dig this old thread. What IC are you refering to?
          I have the same problem, can you please help?
          Thanks!
