Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
AOC AG493UCX 49-inch monitor - Firmware request
I don't think a firmware update will help here; the problem seems to be with the display panel. It looks like one of the panel drivers has failed and is causing an error state, which in turn prevents the TCON (Timing Controller) board from outputting a picture. Another possibility is liquid damage to the information transmission pairs (LVDS or eDP). If even a single trace is broken, the picture won't display. It would be helpful to see photos of the connection from the TCON board to the display panel's ribbon cables. Also, there are ribbon cables between the panel's internal boards; it's worth disconnecting and cleaning them with isopropyl alcohol. However, you must be extremely careful, as the drivers are on flexible circuits bonded to the glass. Do not damage them during disassembly, as those chips are very fragile. -
Agent24 - I thought the same on the firmware when switching the mainboard. But felt a firmware flash couldn’t hurt. I haven’t checked the PSU yet. Honestly, not sure how. Do you know of a guide that shows how to check it safely and properly? I thought it was ok since the backlight was turning on and the input from the mainboard was recognized by the computers.
lotas - Which photo are you talking about? Do you think it can be saved? Seems an awful shame to render the display useless. Any thoughts on the firmware?Leave a comment:
Most likely the problem is in the panel itself, you can see the photo of the lower part of the panel itself, where the buffer strips are located.Leave a comment:
Did anyone check the PSU is working properly? Maybe there is some missing voltage rail or something.
If the firmware was the issue, surely the replacement mainboard would have fixed it?Leave a comment:
Hello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any input source.
It receives power. The backlight lights up. And it is recognized by multiple computers correctly (Windows 11 desktop computer, MacBook, Linux on old Lenovo ThinkPad).
I have tried multiple HDMI and DisplayPort cables on all the inputs and all the computers. The display is recognized on all, but does not show a picture - even when multiple computers are connected at the same time on different inputs.
I have installed current versions of both G-Menu and I-Menu (AOC's monitor management software). And have used both to factory reset the monitor. The issue persists.
The seller also had purchased a replacement mainboard and two replacement TCON boards. I have swapped these in with all combinations and all produce the same result. Power on. Backlight turns on. Black screen. No OSD menu. But all are recognized by the computer when connected.
I would like to install new firmware in hopes that it could help. But I do not find the firmware on the AOC support site. I hope someone here has it.
Please tell me what I should try further. Is there a way to do some sort of full reset on the monitor using the buttons or the remote? Again, I do not see the OSD menu. So I will need a sequence of buttons on the remote to press. Or some software/firmware to help.
Also, please let me know which chip(s) need to be flashed. I found a Winbond chip (25Q16JVIG, 1841, 6824, 4L700) on the TCON boards. And there are many 8-pin chips on the mainboards. But I'm not certain which is the firmware chip.
AOC LCD Monitor
Product No: AG493UCX
Model No: 493UCX
Barcode 1: HVPODF2KAPA6DN
Barcode 2: QKKMAJA000004B
Manufactured: 2021.10
Link to Google Photos album with pics and vids of the issue.
https://photos.app.goo.gl/fV7kMCEntB15DpMeA
I appreciate any details and help you can provide.
Thank you!Tags: None
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by Robby-GrHi all,
I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos -
by JayZeeI have a problem with my Samsung Odyssey G9 (C49G95TSSR) monitor. The LCD display is fine, but there is probably a problem with the electronics.
- When I turn on the monitor and it is disconnected from the computer, the text "No Signal DisplayPort1" is displayed, but the graphics is distorted (see photo).
- After connecting to the computer via DisplayPort1, the monitor lights up, but when I click the joystick, a scattered cross is displayed (see photo) and I can switch up, down, right, but I cannot change the input.
- When I try to click to display the complete...7 Photos-
Today, 05:35 AM -
by weisianHi all,
I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...-
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
- Loading...
