LG 787LE with molten metal film
  • Darkside
    • Jun 2006
    • 7
    I have an LG 787LE monitor with 2 faulty caps. It appears they have been hit by a surge. I'm trying to find replacements but am having difficulty matching size with value. They are marked as "2μ2J 63". According to guides I found on the net that would make these 2.2uf 5% 63v. However units of similar specs are much larger (at least the ones i found). These 2 are 7.5mm long 6mm wide and about 13mm tall with a pitch of 5mm. The only other marking on them is what I assume is a manufacturers logo, it looks like a "T" with the vertical line like this "/". You can see the deformation quite easily (sorry about the picture quality)
    If any one can help with a suitable replacement or an exact that would be great.
    Cheers,
  • Darkside
    • Jun 2006
    • 7
    Re: LG 787LE with molten metal film
    So I guess nobody has seen these before? if you have any ideas for replacements perhaps different type maybe?
    • Harvey
      • Apr 2007
      • 264
      Unless they are doing anything important (i.e. they are part of the high-volts side of the PSU or similar) you should be fine with almost any capacitor of equal rating.
      • Darkside
        • Jun 2006
        • 7
        they are part of the low voltage inverter circuitry
        • Logistics
          • Apr 2007
          • 721
          Maybe Part# 478-3402 at Digikey.
          • Darkside
            • Jun 2006
            • 7
            Thanks that looks like the right one.
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • silver60618
              How to clean Liquid Metal from under CPU?
              by silver60618
              Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
              The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
              Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
              07-11-2025, 01:47 PM
            • shadow666
              ASUS N43SM with Nvidia GT620M crash after touch metal case
              by shadow666
              i have a asus N43SM i7 2th gen and i have a big probelm
              After hitting the metal part of the touchpad or the sides of the mouse is metal, the system locks and the image crashes !
              disassemble notebook and this cover on top picture I insulated all the bases on which the screw is fastened so that static electricity does not cause this problem again but not working !
              Sometimes, when I didn't work with the notebook for a few minutes, after I touch the touchpad, the image confused​ and the system locks ( See Down Picture). I have to turn the system...
              01-05-2025, 08:45 AM
            • Techie_hobby1
              Help with a poorly looking component identification plea
              by Techie_hobby1
              A friend of the family has handed me a food warmer that has failed on her.
              I appreciate that some people will alert me that it is probably cheaply made, but she has extremely limited mobility, and it is perfect for keeping her food nice and warm, once her carers have left.
              It has 2 power options (either 12V DC cigarette lighter or AC 240v IEC C7 socket).
              Basically, it powers 2 x PTC elements which are attached to a metal plate.
              A (removable)metal deep tray is then placed on-top of the small plate which keeps the food nice and warm.
              I thought at first...
              03-23-2025, 06:54 PM
              1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
              I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
              This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
              12-29-2024, 07:18 AM
