Main board schematic request: Dell U2415b
  • Mo Phoenix
    • Feb 2025
    • 7
    • new york
    Hello all -
    I have a request: does anyone have a main board schematic for a Dell P2412Hb monitor?
    My monitor is damaged, I found the culprit, but I need a hint. Is anyone able to tell me what this component is or indicate a replacement?
    Thank you in advance for your help.
    Click image for larger version  Name:	photo_2025-02-05_20-37-14.jpg Views:	0 Size:	202.2 KB ID:	3565394
    Caption
  • lotas
    • Jan 2016
    • 4577
    • Russia
    The same chip is located nearby, what markings are on it, take a high-quality photo of it.​
    • Mo Phoenix
      • Feb 2025
      • 7
      • new york
      thanx ..
      What is the datasheet of this IC so I can tell the seller?
      • Mo Phoenix
        • Feb 2025
        • 7
        • new york
        • lotas
          • Jan 2016
          • 4577
          • Russia
          I didn’t find something on this marking, please refer to this section, maybe someone can help.
          https://www.badcaps.net/forum/troubl...cal-discussion
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
