Asus TUF LED monitor VG27AQ power cycling
  • sixstringartist
    • May 2012
    • 18
    My asus LED monitor VG27AQ is power cycling. I see backlight come on, displays logo and then shuts off and repeats.
    When I power it on, it draws ~200mA (@19V) before turning on the backlight. It jumps to 1.6A for a few seconds then Im guessing the processor goes to standby as it drops to a trickle (8mA). Each of the coils have voltage on them, none are short to ground. The diodes on the small board (LED driver?) look good. Im not seeing any significant hot spots under a thermal. All that really lights up is the two nearby coils labeled 2R2 when the draw ramps up to 1.6A, then off. None of the caps look obviously bad to me, but I could try removing/testing/replacing some. Im not sure what to look for next. Any help would be greatly appreciated. ​
  • lotas
    • Jan 2016
    • 4649
    • Russia
    The power supply itself (19V) supports the load; when switching to operating mode, the voltage does not drop?
    Also check the signal lines (relative to ground) of the hdmi and dp ports for resistance.
    • sixstringartist
      • May 2012
      • 18
      Yes the power supply supports the load. There is not a drop when it switches to the 1.6A draw. The problem is present when using a benchtop power supply as well as the original power adapter.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • meraklinetx
        Asus Z97-a power cycle, no boot no cpu voltage
        by meraklinetx
        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
        05-10-2023, 06:08 AM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • conghuyms
        Request for Help – ASUS G531GW Rev 1.6 – No Power On
        by conghuyms
        I need your support with an ASUS G531GW Rev 1.6 laptop.
        When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
        Here’s what I’ve checked so far:
        • Motherboard has been removed for inspection.
        • 3V and 5V always-on rails are present (3V/5V_ALW).
        • 1.8V and 1.09V at the PCH are present.
        • I don’t have the boardview/schematic, so troubleshooting is limited.
        • I tried checking the power button signal from the
        07-20-2025, 09:14 PM
