BenQ GW2255 - White screen.
  • stu232
    • Apr 2014
    • 7
    • Scotland
    This monitor is only 4 months old, I've lost the receipt so I can not get it repaired under warranty.
    I was using the monitor yesterday and the screen suddenly turned white. I rebooted the PC thinking that Windows had crashed but even as the computer was rebooting the monitor stayed white so I knew something was wrong.
    I followed a Youtube video which claims to have an easy fix for the white screen - it was basically telling me to clean the ribbon cable - which I did but it didn't help. All the capacitors look to be fine on both the power board and the video board.
    When I power it up the screen instantly goes bright white, after about 4 seconds it instantly turns black (doesn't fade) then it will turn white again then black then finally it will remain white until power is removed.
    The power board is 715G5000-P02-000-003M
    The video board is 715G3849-M01-001-004K
    • 31070
    Re: BenQ GW2255 - White screen.
    is there a manfacturing date on the back of the monitor?
    you can make a warranty claim without the eceipt if you can prove it's not old enough to be out of warranty.
    i'v done this with 4 monitors so far that people threw out!!!!
    • stu232
      • Apr 2014
      • 7
      • Scotland
      MFR. April 2013
      How would I go about doing this?
        • 31070
        find out who is benQ service agent & how long the factory warranty is.
        sony for example was 3 years on pro monitors.
        • stu232
          • Apr 2014
          • 7
          • Scotland
          Won't the fact that I've opened the case void my warranty anyway?
            • 31070
            depends, did it have any seals?
            • stu232
              • Apr 2014
              • 7
              • Scotland
              No, no seals at all which I thought was strange.
                • 31070
                pretty common actually these days - seals cost money!
                sooo - they wont know you opened it then, unless you scratched the case or screwheads.
                • stu232
                  • Apr 2014
                  • 7
                  • Scotland
                  The only screws on the case are the ones that are used to attach the stand, the rear casing and front bezel are all snap on. lol
                  • stu232
                    • Apr 2014
                    • 7
                    • Scotland
                    I've just spent 2 months going round in circles trying to get this screen repaired under warranty. I have no receipt and no proof at all that I bought it as I paid cash in store. Benq just do not want to know, it's like talking to a robot they will not budge unless I provide proof of purchase. The retailer has tried everything in their power to find details of my purchase but have failed.
                    I've given up on that front. I'll literally throw up if I need to speak to Benq CS again.
                    So I'll post my problem again and hope that someone can help.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      Can you post pictures of your boards - and if its not led lit and has one a separate inverter board. and the board on the back of the panel - careful with that the connectors can be fragile ( may even be the problem) On the board that is on the panel there is sometime as small fuse tha is what we are looking for.
                      EDIT - it is LED so no inverter board.
                      • bammbammfran
                        • Apr 2014
                        • 476
                        You will probably have to start by checking voltage at the large back plug that the white ribbon plugs into on the vga board
                        Voltage should probably be at pin 1 and 2 near the one canister type capacitor
                        • jetadm123
                          • 2169
                          Also, please post a photo of the board that is connected at the opposite end of the ribbon cable from the video board. It's at the top of the screen and typically covers the entire width of the screen. Some people call it the t-con board.
                          • AkumAone
                            • Feb 2013
                            • 23
                            • Bosnia and Herzegovina
                            White screen is probably due to no voltage on T-Con board. Check the SMD fuse on the T-Con board, if blown, replace and check the SMD bypass capacitors for shorts/low ohm faults.
                              master hoarder
                              • May 2008
                              • 12175
                              Agreed.
                              While bad capacitors in the power supply is still a possibility, I'm more inclined to think it's a t-con issues as well. Pics will tell us, though.
                              T-con usually takes 3.3V or 5V and its own power conversion module inside, which produces three rails: AVDD, (about 10 to 15V), VGH (15 to 30V), and VGL (-5 to -10V). Shorted ceramic capacitors on these rails are not uncommon, especially AVDD. Not too hard to find with a multimeter.
                              • bhaskar
                                • Nov 2015
                                • 13
                                • India
                                I have also same problem.. 3.3v ok on screen logic board smd fuse suply ok what i do next
                                • harp
                                  White screen repairs
                                  by harp
                                  To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                  Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                  On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                  05-13-2024, 03:43 AM
                                • Ryan.man
                                  by Ryan.man
                                  02-04-2025, 12:23 PM
                                  by momaka
                                  03-15-2023, 10:17 PM
                                • abajor
                                  A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                  by abajor
                                  Having this very weird issue.
                                  The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                  I swapped with a working screen from an A2141 waiting for parts.
                                  The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                  The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                  04-27-2024, 01:37 PM
                                • EazyBone
                                  Sharp LC-65Q620U White Screen
                                  by EazyBone
                                  Another TV topic!!
                                  I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                  The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                  Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                  08-21-2024, 12:56 PM
