GuestView Guide DS1-VR01S BIOS Password
  • Dge
    • Jun 2024
    • 7
    • CA
    I purchased one of those units for a project and the BIOS is password protected. I was able to dump the BIOS (Insyde), it's 8MB. Tried various ways to clear up the pwd to no avail. Hoping someone can figure out how to bypass it.
    Thanks!
    • 25650
    Thanks!
    Attach files directly to your posts please
    • Dge
      • Jun 2024
      • 7
      • CA
      I tried but it doesn't let me attach a 7z file, or a bin file. What extensions are acceptable?
      • Dge
        • Jun 2024
        • 7
        • CA
        Does this work?
        • Dge
          • Jun 2024
          • 7
          • CA
          Ok I figured it out, needs to be a zip. Sorry about all the noise!
          • a-better-gamer
            • Dec 2025
            Did anyone ever make any progress on this? I found a way to install windows 10 on these tablets (I can share if your not already aware how to), but I would like to run Linux on these as full windows is usable however a little much for the little processor, and 8gbs of ram.
            • Dge
              • Jun 2024
              • 7
              • CA
              I have one running Windows 10 LTSC, which isn't too bad. And another running Android (BlissOS). I also tried Batocera and Openelec, all worked great, so no reason that your standard Linux distro wouldn't.
              Btw, the password is a simple 4 digit: 2019
              • a-better-gamer
                • Dec 2025
                No way, your a life saver! Just confirmed this does work. How did you find to pass? Random guessing? I was searching for a eeprom chip to try a hardware attack lolol. Happy I can stop that effort now!
                • Dge
                  • Jun 2024
                  • 7
                  • CA
                  The password is stored in a UEFI variable, I used this tool to view it: https://ruexe.blogspot.com/
                  • laupe1
                    • Apr 2026
                    Hello how can I install win 10 on the Display? Thanks
                    • Dge
                      • Jun 2024
                      • 7
                      • CA
                      It's just a normal PC, you would install Windows or Linux the same way you'd do with any other PC (boot from USB and install).
                      • chriswfrye21
                        HP 255R G10 – BIOS Admin Password Locked, Cannot Enter BIOS (Need Guidance / SMC.bin Help)
                        by chriswfrye21
                        I’m working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
                        This is not a Power‑On Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
                        I’m posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
                        Model: HP 255R 15.6 inch G10 Notebook PC SK...
                        08-10-2026, 03:49 AM
                      • Olegst44
                        Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
                        by Olegst44
                        I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
                        Device Information:
                        - Model: Acer Aspire 3 A315-22G
                        - Motherboard: NB8607G02-MB (Compal LA-J761P)
                        - BIOS Chip: Winbond W25Q64 (8MB)
                        - Serial: NXHE7ER00X95002B784S00
                        Problem:
                        - BIOS is password protected (Supervisor Password)
                        - Boot from USB is disabled in BIOS
                        - After 3 wrong password attempts, system shows Unlock Key Hint
                        - I have RT809H programmer available
                        What I need:
                        1. Clean BIOS dump (password...
                        04-11-2026, 05:36 PM
                      • TopPop
                        Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                        by TopPop
                        Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                        I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                        12-14-2025, 09:40 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • vic6688
                        ASUS ExpertCenter D700SA - Need BIOS admin password removed
                        by vic6688
                        I would like to ask for your help with my ASUS desktop.
                        Model:
                        BIOS:
                        AMI Aptio V
                        BIOS Flash:
                        Winbond W25Q128JV (16MB)
                        I forgot the BIOS Administrator password.
                        I have already read and verified the complete BIOS dump using a CH341A programmer, and I have attached the original 16MB BIOS dump.
                        If possible, I would prefer to recover or identify the current BIOS password so that I can continue using the original BIOS without reflashing.
                        If...
                        09-05-2026, 06:23 PM
