IBM Thinkvision 6736-HC9 No power
    Re: IBM Thinkvision 6736-HC9 No power
    Or just do resistance reading from the L on the IEC inlet all the way to the ~of the bridge, same for the N on the IEC inlet all the way to the ~ of the bridge.
    • eckertb83
      • Jan 2011
      • 71
      OK I tested just to 2 points on the bridge rectifier ( between + and -) and I dont get any reading at all.
      Didnt see your post budm, I did check resistance between those 2 points
      Live resistance 10.0
      Netural resistance 1.6
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4282
        • Italy - Milan
        "OK I tested just to 2 points on the bridge rectifier ..." i don't understand, tested how, voltage, ohm? between which points?
        "Live resistance 10.0
        Netural resistance 1.6"
        ohm? Megaohm??
          I hope those are in Ohm, if that is the case you may be OK. The Neutral to ~ of the bridge is good.
          The Line to ~ of the bridge is 10 Ohms is due to the Thermistor (I do not know the value, you need to look at it) is may or may not be OK, but since we do not have open circuit between Line or Neutral to the ~of the bridge, then you should be able to see 120VAC on the two ~ pins of the bridge at this point.
          • eckertb83
            • Jan 2011
            • 71
            yes that's ohms, I had the DMM set to 200. I flipped the board over to look for the Thermistor (TH) I couldn't locate. Where about should it be?
              Thermistor. So at this point, do you get 120VAC at the ~ pins?
              • eckertb83
                • Jan 2011
                • 71
                I removed the heat shrink wrap from the thermistor and this is what is printed on it-
                SCK
                086
                I am getting about 117VAC at the ~ pins. It jumps around a little but not much 116.8-117.4 VAC
                  "I am getting about 117VAC at the ~ pins. It jumps around a little but not much 116.8-117.4 VAC" Then you should have DC on those two min filter caps, not 0V as you had tested before.
                  • eckertb83
                    • Jan 2011
                    • 71
                    Yes I am getting between 159 and 162 DCV on the 2 filter caps. I'm not positive but I may have had the switch in the wrong position the first time I tested them.
                      OK, that was a long tail chasing to get to this point, we now need the P/N of that SMPS IC so we can start check voltages. You also try heating up the two small caps next to the S shape heat sink where the MOSFET is mounted on to see if the power supply will start up.
                      • eckertb83
                        • Jan 2011
                        • 71
                        IC-
                        203D6
                        PTFP
                        I will try to heat them up with my heat gun and report back.
                          That numbering system does not look right, is it 1203?
                          https://cdn.badcaps-static.com/pdfs/...93618ef001.pdf
                          If it is, then check the resistance between GND PIN 4 against 7 other pins and report the resistance readings, make sure to put down if the resistances are in Ohms, K Ohms, or M Ohms. No power to the board, of course.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4282
                            • Italy - Milan
                            #33
                            eckert please, you confirm the main mosfet measurement that last time seemed shorted?
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #34
                              "Heat" means quite gentle as with a hairdryer for 30 seconds. you are not trying to reflow them.
                              • eckertb83
                                • Jan 2011
                                • 71
                                I am trying to measure resistance but cant seem to get any thing. There was some sorta glue that I had to clean off before I could actually do anything. I had the DMM set at 200 Ohms and couldn't get any reading off any of the pins. Does this mean its shorted?
                                "You also try heating up the two small caps next to the S shape heat sink where the MOSFET is mounted on to see if the power supply will start up."
                                Do I have to connect it back to the video board and heat it up then try to turn it on?
                                  Just that board by itself, then see if you do get any 5V and other voltages on the pins going to the logic board.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #37
                                    Which query are you replying to? what are you testing? try cleaning your probes with Isopropyl alcohol - shorted is the same as holding your probes together or very low ohms.
                                    Please read back through and answer some of the questions you have missed.
                                    Please update you profile with country so we know which time zone you are in
                                    and voltage .
                                    • eckertb83
                                      • Jan 2011
                                      • 71
                                      SMPS IC is what I'm testing, that I cant get any reading like its shorted. I have cleaned the probes and still the same thing. I posted a pic of the IC so you can see the part number. I believe the data sheet Budm posted is correct for this part.
                                      I still have to try heating it up and checking it for voltage.
                                      as far as the MOSFET i did re-test it still shows as being shorted.
                                      DMM set @ 200 Ohms
                                      blk probe
                                      pin1- pin2=1
                                      1-3=1
                                      2-3=1
                                      all on the left side of the DMM
                                      I changed the setting on the DMM to 2000K ohms and I am getting somewhere i hope....
                                      all done with back probe on PIN 4 Ground.
                                      1-004
                                      2-046
                                      3-001
                                      5-002
                                      6-329
                                      PIN 7&8 just a 1 one the left no resistance.
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #39
                                        We keep asking you to say what the value of the results are do you mean 1 ohm
                                        I do wonder if the "1" you are stating is in fact the meter telling you it is over scale
                                        The same as having your meter on ohms 200 and the probes apart?
                                        If that is the case the mosfet is probably NOT shorted
                                        • eckertb83
                                          • Jan 2011
                                          • 71
                                          Yes that is what I mean, That is also why I stated it was on the left of the meter.
                                          Reading through the "2sec to black guide" I remember reading that when checking resistance use 200Ohm setting for most/all parts. Even the other monitor that DID have a bad MOSFET and Bridge I tested them with 200Ohm setting .
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • Thomas Smith
                                            Asus Tuf gaming fx506l no power, mosfet does not open
                                            by Thomas Smith
                                            Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                                            Initial Symptoms:
                                            • The laptop has no power at all (no LEDs, no fan spin).
                                            • No 3.3V or 5V present on the board.
                                            • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                                            Power Rail Checks:
                                            1. Charger input (FETs PKCH2BB)
                                              • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                                            2. BQ24780S Charger IC:
                                              • VCC and ACDET are present.
                                              • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                                              • Shunt resistor has 10Ω to ground.
                                            03-30-2025, 03:38 AM
                                            03-31-2024, 02:12 PM
