Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
  • retrotechrestoration
    • Mar 2024
    • 10
    I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
    Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​
    • Mar 2024
    • 10
    Photo...
      • Mar 2024
      • 10
      And according to this site, an equivalent FBT might be the HR46290.
      https://www.hrdiemen.com/search/index?orig=&page=1574
        master hoarder
        • May 2008
        • 12168
        • Bulgaria
        If the picture on the screen comes up and you don't hear or see high-voltage arcing noises, then the flyback is not faulty.
        Picture "flickering" suggests the degauss coil relay might be stuck in the On position... or if the monitor doesn't have a degauss coil relay, then the PTC in series with the degauss coil is somehow allowing excessive current.
        Either way, here's a quick test to perform: disconnect the degauss coil from the main board and see if the picture still "flickers". If it doesn't and your fuse doesn't blow up anymore, then that's likely the issue.
        Also, I wouldn't worry about connecting the monitor directly to the wall without an isolation transformer / PSU. CRT monitor PSUs are usually pretty well protected against short-circuit and other faults. So nothing should burn up (degauss coil PTC excepted, of course, if there's a relay for it and it's stuck ON.)
          • Mar 2024
          • 10
          As I mentioned, it is making high voltage crackling, arcing sounds coming from all parts of the monitor, but I'll definitely check the degauss relay.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8678
            reminds me of a 14" VGA monitor I fixed years ago... there was a hole in the FBT that leaked HV out the side to the closest chassis ground, wicked spark... I stuffed it with plastic and it insulated enough for the crt to work... hah.
            hmm that fbt looks similar to one i pulled from a 17" crt I drop cracked... wonder if i still have it...
              • Mar 2024
              • 10
              This FBT looked pretty well intact, but I'll go over it more closely when I get home.
              If you happen to have a matching FBT, you'd have my undying gratitude and some fresh cash in your PayPal account!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8678
                Nope, sorry to get your hopes up, it's different though reminiscent...
                  • 30950
                  have you run it in the dark with the back off?
                    master hoarder
                    • May 2008
                    • 12168
                    • Bulgaria
                    I'll take a look inside my parts boxes as well, since I do recall having saved the boards from a CTX monitor that has a similar flyback.
                    However, do as sjt noted first - take a look inside the CRT to see if there is any arcing.
                    Also, I'm pretty sure the flyback, even if it is faulty (which I doubt) can make the fuses on your isolated PSU burn up.
                    The way pretty much all "modern" CRT TVs and monitors work is there is a main switching power supply inside that produces B+ (160-200V typically) and this B+ is then driven by the HOT (horizontal output transistor) to drive the flyback transformer. So if the flyback traffo was bad, it would pull B+ down and this would shut down the main SMPS. So it's just not possible for the fuse to blow simply from this circuit design. So don't replace the flyback blindly. Troubleshooting CRT monitors by method of shotgunning parts is usually the longer and harder way to getting them fixed.
                    Again, take a look at the degauss coil and particularly, try disconnecting it. This is the only thing that can draw such a high current to burn out your fuse. If the main SMPS was dead, the monitor wouldn't even try to start or make any noises - it would instantly be blowing fuses.
                      • Mar 2024
                      • 10
                      Good point... in addition, when I re-attached the FBT and tested it, there were no more arcing sounds... just the initial degauss "fwumpf" sound before the onboard power supply fuse and my external power supply fuses both blew.
                      I'll remove the deguass coil, inspect it and test again, but it seems like you may be right on the money.
                      Props!
                        • Mar 2024
                        • 10
                        Props!
                        *sigh* No change with the degauss coil(s) unplugged. This monitor has two coils-an inner and and outer. I'm currently tracing my way through the power supply circuit...will post if I find anything.
                          • Mar 2024
                          • 10
                          The hum wasn't coming from the degauss coil...it was coming from the main transformer. There's no fault and cleanly regulated power going all the way to its inputs when the transformer is out of circuit.
                            master hoarder
                            • May 2008
                            • 12168
                            • Bulgaria
                            OK, hold up a bit... I don't see a main input cap on the primary side, so this doesn't look like a conventional switch-mode PSU.
                            What happens when you plug in the monitor directly in the wall without the isolation PSU? Do this with the monitor's flyback installed. If there's a fault, let the fuse on the monitor power board handle it. I just want to make sure we are not chasing a "ghost" problem with the isolation PSU not being able to handle some kind of a high startup current that the monitor may normally have. If the fuse on the monitor board blows, then we know something needs looking after.
                            The PSU primary looks like some kind of a LLC / oscillator type found in electronic halogen lighting transformers, so not sure how that should act up with a fault on its secondary side, if there is one at all. I do see two optocouplers, so there is definitely some kind of regulation/feedback/protection going on. Might have to find a service manual for this one...
                              • Mar 2024
                              • 10
                              Thanks for the suggestion. I did try powering it up directly off the wall circuit, and the onboard fuse near the mains input did blow rather spectacularly. I saw the optocouplers. I've tested the relay that crosses the two board sections out of circuit and most of the other psu components. They've all tested good.
                              I'm still looking for a service manual.
                              • bohaboha
                                can a flyback transformer for USB charger isolate?
                                by bohaboha
                                can i use a flyback transformer from an usb charger to isolate galvanically a small diy led tester? or it must be an isolated transformer
                                01-15-2022, 02:36 PM
                              • ohren
                                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                by ohren
                                Hello!
                                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                Measured voltages with no load:
                                After rectifier diodes
                                12V: 6.17 V
                                5V: 5.67 V
                                Secondary transformer pins AC measurement (really don't know if this says anything)
                                12V: 2-2.5 V
                                5V: 1.04 V
                                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                03-18-2023, 10:33 AM
                              • mikey5791
                                Is it possible for transformer substitution?
                                by mikey5791
                                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                My questions are
                                1. How do i test to see if the transformer is in good working condition?
                                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                Hope you guys understand what i was asking. My intention is...
                                11-03-2022, 02:11 AM
                              • dennis_elx33
                                3PHASE STEP-DOWN Transformer in Check
                                by dennis_elx33
                                Hello All,
                                i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                Problem statement: Power tripped Off
                                Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                Action Done:
                                1) Replaced the faulty parts with good spare.
                                2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                12-02-2024, 06:52 AM
                              • Hitto
                                Best practice for soldering a Flyback Transformer
                                by Hitto
                                I'm trying to solder a flyback transformer back to its board. It is quite heavy and the PCB is battered by age.
                                Well:
                                There are at least 8 solderable pins and two screws which secures (or at least on paper, please read below) the transformer onto the PCB.
                                This is a reference picture:
                                I already had to reflow some pins once.
                                Who do you guys think would provide the less stress for the pins?
                                1) Screwing the transformer onto the PCB and then solder;
                                2) Solder the pins and then screw the transformer...
                                01-14-2020, 02:50 PM
