Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
ASUS PG27U MONITOR
    Posted Photos 2 Photos
  • technonenehno
    ASUS TUF VG32VQ monitor, T-con(31M02-C01 CTRL BD) or panel malfunction?
    by technonenehno
    Hello everyone!
    As mentioned in the topic i am debugging a VG32VQ monitor which has a quite curios issue. For starters the backlight is working, the mainboard is also working and audio is being normally played thru the speakers. The problem of the monitor is that the screen is always blank(you can see the backlight turns on since the screen brightens a little bit but still black). When plugged into a computer the monitor is detected and HDMI signal is being broadcast to the monitor(checked with a data analyzer). The monitor panel should not be damaged but i am open to this option.
    02-10-2026, 12:18 PM
  • janos6662000
    Asus ROG PG248Q gaming monitor stuck in burn in (factory) mode
    by janos6662000
    Hi
    Almost 2 years agoi got a monitor like this. Problem is, when i switch it on, always starts in factory mode: Red-green-blue-etc, colors repeating in loop.
    I searched how to disable it and indeed it worked, but stays OK only until monitor is in standby .
    If you cut the power or the monitor enters deeps sleep, it comes back the same.
    I searched the internet and discovered that it is a very frequent problem with Asus monitors. Most of the users who "solved" this issue, replaced it in warranty period.
    Some say: replace internal battery, but i opened the monitor...
    02-14-2026, 07:55 AM
  • AppleLover123
    Asus X712EA 3 volts after the first mosfet
    by AppleLover123
    Hey guys,
    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
    Now i thought something...
    12-15-2024, 07:49 AM
  • Scotchmist
    Asus GA502D keeps blowing mosfet
    by Scotchmist
    I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
    I have removed the mosfet and can run the laptop no problem
    The MOSFET is FDPC5018SG
    Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
    08-24-2024, 02:23 PM
    by momaka
    03-15-2023, 10:17 PM
