Phillips 170B Screen goes Blank after 1-2 seconds
  • thestigp11gt
    • Jun 2013
    • 30
    • Scotland
    My current monitor is being a pain in the backside, as it takes about 20-30 hits to get the screen to come on. I was then given Phillips 170B monitor, however the monitor did sit in a shed for 4 years, which meant temperatures were down to -10*c and potentially dampness
    Anyway I got it, let it get to room temperature (infact was about 3 metres from a radiator for a full day), I plugged it in, and the screen came on, for around 2 seconds and then went back off.
    Done the usual search on Google, and suggested that the caps were probably done, The old caps were CapXon ones, There was no physical evidence that the caps were done as they were not leaking and were not bulging. I replaced the caps on the main power supply board anyway, plugged it up, exact same problem,
    I am out of ideas not as Google is now limited.
  • selldoor
    Slow Learner
    • 7870
    Re: Phillips 170B Screen goes Blank after 1-2 seconds
    Originally posted by thestigp11gt
    boom, exact same problem,
    Is the "boom" just for effect or did it happen? Did you have the correct
    value caps and were they in the right way round.
    Perhaps repairs to your current monitor before it gives up completely
    would be easier - sounds like the startup cap at the moment but it could get a lot worse. - Suggest start another thread for that.
    Either way we are going to need really good clear in focus pictures you will need to take in good light and without flash.
    • thestigp11gt
      • Jun 2013
      • 30
      • Scotland
      would be easier - sounds like the start-up cap at the moment but it could get a lot worse. - Suggest start another thread for that.
      Ignore the part where i say boom, it's Scottish slang, i have a habit of forgetting to leave it out. I will start a new thread about the other monitor.
      As I said the monitor goes off after 2 seconds, but what i have noticed is that the power LED remains on after the screen goes back off.
      What I have also notices after trying to switch it on and off for about 10 times, when i did it once, there was a weird buzzing from the monitor, and then it went off once the screen went off again.
      • selldoor
        Slow Learner
        • 7870
        What is the part number on the power supply may be 715G1813-1 or something like that
        • thestigp11gt
          • Jun 2013
          • 30
          • Scotland
          Model Number: EADP-43AF A
          This is the PCB
          • selldoor
            Slow Learner
            • 7870
            Ok I will have a look at the pic though we normally require a straight down
            and a pic of the back.
            Here is a youtube video of someone diagnosing this board which has 2 sec to black.
            I cant believe you could be so lucky!!
            May just want to start at 20 minutes in.
            If you have the voltages at the connector - think you will have - as otherwise it probably wouldnt flash at all you need not test most of the stuff - just th e inverter transformers for now.
            http://www.youtube.com/watch?v=FYoS13Ox214
            • thestigp11gt
              • Jun 2013
              • 30
              • Scotland
              Nice one, I need to order a new Tester, mine has went haywire, Will check it out as soon as it arrives.
              • thestigp11gt
                • Jun 2013
                • 30
                • Scotland
                New tester arrived today, went though what that video did, but the inverters are fine, I have continuity though both of them
                One thing i noticed is that one of the outputs which is for 12v, shows 13.5v when on power. Is this normal or is this the issue?
                Just a note also, When connected to the power, and screen comes one, as i said you hear a funny noise (similar to the old snowy picture noise on old TV's but low volume) which happens for 2 seconds, Once the screen goes off it goes away.
                When you turn off the monitor IE pressing the switch so the LED goes off, you can then hear a high pitch squeal, It is very faint, but goes off when you power on the device.
                • Rtech
                  • Jul 2010
                  • 1095
                  Just by chance I have a complete set of working boards for this monitor,although like a lot of monitors with the same model number the insides can be totally different.My lot include the PSU/Inverter 715G1813-2 and the Logic 715G1767-1 VB,the latter having a little plug in PC for the Audio.
                  I set it up on a Dell 17"Test Screen and it all works fine,BUT I did noticethat like yours the LED stays on Green as soon as the Power is connected, AND stays on irrespective of whether there is a PC signal or not,so I think yours is acting the same and is correct.As you do get a 'flash' of Screen initially,for the moment I suspect it is getting a PC signal,and what you need to do is eliminate the PSU/Inverter AND the Backlights !!.
                  On the Power supply connector that goes to the Logic board is there any markings to indicate what should be on each pin ???,and have you a set of test backlights from another monitor ??.I have added photos of my boards,and the same from you may be helpful !!
                  • thestigp11gt
                    • Jun 2013
                    • 30
                    • Scotland
                    The back light connectors are funnily enough the same as my Proview monitor, I wonder if I could use the power supply board to power the back light screen itself, to eliminate the actual back light being broken.
                    • Rtech
                      • Jul 2010
                      • 1095
                      On the connector mentioned there may be a pin marked On or O/F or En(for enable),So if you connect ONLY your Psu to the mains,Plug in your screen backlights to the sockets and then apply 3v Dc(maybe from a battery) between the pin I have indicated and GND,or use a !K Resistor from the 5V which should also be on that connector, the lamps should work,if not then you have confirmed the fault is the PSU or backlight, then you can plug in the other set from the other monitor LAMPS ONLY and see if they work
                      • thestigp11gt
                        • Jun 2013
                        • 30
                        • Scotland
                        the 3.3vdc from a computer PSU will do the trick for that.
                        • thestigp11gt
                          • Jun 2013
                          • 30
                          • Scotland
                          Okay, So i built my Arduino Capacitance meter, One of the capacitors, which is the 100uf 450v one, shows as only 81uf - Could this just be another faulty cap?
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            What brand of caps did you use for replacements and which ones have you changed?
                            • thestigp11gt
                              • Jun 2013
                              • 30
                              • Scotland
                              I replaced all of them, All others seem okay
                              Unsure of the make, just has KXG on the capacitor.
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                I replaced all of them, all others seem ok.
                                So not all of them replaced???
                                Were they low ESR caps?
                                • thestigp11gt
                                  • Jun 2013
                                  • 30
                                  • Scotland
                                  Yes, All of them replaced, the capacitor in question is a KXG model, the other new capacitors are cheng.
                                  Testing of other capacitors check out okay, the KXG model is the only one that seems out by a margin.
                                    May be its time to use test lamps to verify the function of the inverter circuit.
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      I assumed he had done this from Post 11 ??
                                        I did not see if he indicated that he did or not after your post 11.
                                        Post 10: "The back light connectors are funnily enough the same as my Proview monitor, I wonder if I could use the power supply board to power the back light screen itself, to eliminate the actual back light being broken"
                                        • kotel studios
                                          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                          by kotel studios
                                          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                          State I got it in:
                                          Squealing from the PSU
                                          After logo I get a blank screen
                                          After 10 seconds of having a blank display w/ backlight the TV dies
                                          Give it 7-10ish seconds again and it starts to bootloop.
                                          What I did so far:
                                          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                          Checked all voltage rails:
                                          5VSB - 4.8V
                                          AMP+13V - 14.4V
                                          13V - 12.98V (in manual 12V)...
                                          09-21-2025, 02:00 AM
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          08-11-2025, 02:14 PM
                                        • twonk9098
                                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                                          by twonk9098
                                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                          I have tried a few new bios but exactly...
                                          07-14-2024, 11:19 AM
                                        • hasel17
                                          CH341a can erase and read but can't write and blank check
                                          by hasel17
                                          So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                          Code:
                                          Checking for blank...
                                          (Press
                                          10-26-2023, 06:20 AM
                                        • liquidzorch
                                          Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                                          by liquidzorch
                                          Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                                          10-18-2024, 05:19 PM
