Samsung Syncmaster 223BW - blank screen..
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4367
    • Italy - Milan
    Re: Samsung Syncmaster 223BW - blank screen..
    Originally posted by selldoor
    Perhaps 10 minutes is not enough time to look?
    What do you want to say?
    I've searched all them with alldatasheet.com and after with yahoo
    I believe
    A21SC is an eeprom 24c02
    How do you found them?
    Datasheets are available for all?
    • selldoor
      Slow Learner
      • 7870
      24co2 is at digikey data sheets available
      Sorry I have been a bit busy and will be for a few weeks
      http://www.digikey.co.uk/product-sea...980?k=%2024c02
      24co8 is at digikey data sheets available
      http://www.digikey.co.uk/product-sea...980?k=%2024c08
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4367
        • Italy - Milan
        But you say that A21SC is an eeprom 24c02.. i don't see it in alldatasheet...
        • cathary
          • Oct 2013
          • 3
          • Romania
          Hello guys.
          Has anyone troubleshoot the logic board?
          All I'm going to write is just what I read online, nothing is tested.
          Reading different forums, I saw that most of the techs (including me) are trying to find a faulty electronic component. Nothing bad till now, but not all to accomplish the final job.
          Reading some polish/russian forums (using google translate), I realized that I overlooked the bios (firmware) role. Itself, the firmware might be responsible for this kind of situation.
          There is a .*bin file (arabic forum) that can be rewritten in the flash memory. This procedure is called, from what I understand, "dumping eeprom".
          There are some SPI FLASH programmers and dedicated software, like RT809F High speed USB programming unit BIOS programmer, that can do the job. This is just an example.
          If someone has the possibility to test the file, I'll be more than greatful.
          If anyone else has a different oppinion or way of working, please share it .
          • neuralnet
            • Nov 2013
            • 14
            Hi Cathary, thanks for the suggestion. EPROM corruption was suggested by Davi.p but I don't have access to a reprogrammer.. maybe it's time to invest in one..
            • spuzzum
              • Oct 2014
              • 9
              Do a google for 24cxx eeprom programmer, and make one yourself.. cost like $5 in parts, and it's a pretty simple circuit. There's even a 4-pin socket on the board that I'm betting is for programming.
              But from what I've been reading.. you can dump and flash the chip directly from the desktop. Here's a post from a thread where somebody wrote a fixed eeprom back to his monitor with a GUI...
              http://ubuntuforums.org/showthread.p...1#post12002011
              • mrtek
                Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                by mrtek
                Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                11-26-2024, 09:58 AM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • Chrissygizmo
                samsung galaxy ao2s very temperamental after screen replaced
                by Chrissygizmo
                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                Ive eventually managed to get it on and working but it's very temperamental...
                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                05-26-2024, 12:05 AM
              • JunkmanJimbo
                Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                by JunkmanJimbo
                Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                Please help. Thanks in advance!
                08-12-2025, 11:45 AM
              • Kiberge
                Samsung LH82QENELGC/EN Help needed - Static line on screen
                by Kiberge
                HI guys!
                I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                04-22-2024, 11:28 AM
