Dell 2709w No power
  • lalexan
    • 6
    Re: Dell 2709w No power
    Originally posted by Thomas W.
    Nice Thread... an it isn't dead, it's still alive.
    Today I got three of these Monitors today for 0€, all marked defect.
    Two of them starts normal, one shows the "blue power led stuck" error.
    I think, I will start with this monitor and do the lalexan method:
    And best wishes to all of you fine people
    regards
    Thomas
    Hi Thomas, did it work for you?
    A couple years after the fix the monitor failed again with the same problem. I needed to take the monitor through the same procedure again, and it works now. This time I heated it to ~230degC (sensed on top and 210degC at the backside of the board).
    • Gold007
      • Jul 2019
      • 9
      • Hungary
      #122
      Hi guys!
      I too have a 2709W with the following symptoms: Some (1-5 varying) vertical colour lines on each side of the screen that would go away after some time (10-25 minutes). The colour was a bit off too (rather warm, redish, purpleish).
      I have reflowed the main chip using a sandwich maker and a hot air station with an IR thermometer. I have used lots of flux (even Louis Rossmann would approve) and could see flux squishing out from under the chip when touched with tweezers, so I am pretty sure the reflow was successful. I have also replaced most of the electrolytic caps around the two chips. Most of them were measurably degraded with pretty bad ESR readings.
      After this, the screen works, the color is back to normal, but some lines are still present SoftMCCS still shows no DDC/CI (yes it is enabled in the monitor menu), so the chip is obviously not working correctly...
      Maybe the chip is damaged permanently/internally? It does get warm but not crazy hot.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Originally posted by Gold007
        Hi guys!
        This is a defect in the panel's tab bonds, there is no fix for it. Well known issue for this monitor.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • Gold007
          • Jul 2019
          • 9
          • Hungary
          #124
          Thank you for your reply! This is sad to hear, but then I guess there is nothing to do about that...
          This explains the lines on the screen, but DDC/CI not working seems a bit suspicious for me. I doubt it has anything to do with tab bonds making contact or not. But then who knows. I think I will just live with the lines and I don't use DDC/CI anyway At least now I know the electrolytics are good and the BGA should be fine for a few years at least.
          • k4wers
            • Oct 2023
            • argentin
            #125
            hi. i have this monitor, i've replaced some caps but something happened to the schematic and its ruined, now i dont know where the caps go, cant find a schematic, ¿can anyone send me a picture showing what values are the caps from the main board please? thanks.
            • Bob789
              • Switzerland
              #126
              Hello all 2709W friends - or "2709W victims"??
              Yes, an old thread, but still active (Oct 2023) - and very informative, thank you all!
              My 2709W worked well for more than 12 years (very good, I still like it!!), but had troubles recently, to the point of a "no image" failure. Being a rather occasional DIY electronics repair person, I read this thread and others and started disassembling the 2709W, removed dust and tested a few things.
              -> Unfortunately I must have caused a short somewhere because suddenly smoke was rising and the component Q603 on the main board (a MOSFET?) was dead, see picture below.
              A web search for "A1PV", half leggible on the damaged Q603, unfortunately did not come up with any relevant information.
              Questions:
              • Does anyone know which component (exactly) Q603 is?
                I guess it's a transistor or voltage regulator. The "D" in the corner (red arrow) could mean "drain". Dimensions are 2.9 x 1.6 mm (SOT23 or SOT23-3).
              • Which voltage should I get at the solder point to which the yellow arrow points in the picture below (on a healthy board)?
              • Resistor R661 (marked "104" -> 100 kOhm) seems to have gotten some heat too. Better to replace it as well?
              Thank you very much for any help!!
              • lotas
                • Jan 2016
                • 4754
                • Russia
                #127
                A1xx - AO3401 (30V P-Channel MOSFET).
                • Bob789
                  • Switzerland
                  #128
                  Wow!! Thank you very much!! So fast!
                  Have a nice evening!
                  • tony359
                    • Oct 2018
                    • 262
                    #129
                    Hi there,
                    My dell 2709 died some weeks ago and this is one of the most informative threads I found online on the subject. I managed to fix it and made a video repair, I mentioned this forum and linked this thread in the description.
                    I've had three DELL's monitor of that era which ALL failed for the same reason. I wonder whether whoever re-flowed the main processor actually unintentionally "fixed" the same issues all my monitors had!
                    Feedback always very welcome
                    • k4wers
                      • Oct 2023
                      • argentin
                      #130
                      En Castellano:
                      Hola, tengo el monitor 2709WFPb. Cambié los condensadores, dañé la placa y conseguí una nueva. La conecté, pero no se encendió. Hoy fui a la tienda de un ingeniero electrónico de la ciudad, y me dijo que podía revisar la fuente de alimentación con su osciloscopio. Hice algunas pruebas y había voltajes correctos en algunos puntos... alrededor de 18V, pero él comentó que necesitaba verificarse con el osciloscopio.
                      Cuando le llevé el panel con las placas, me dijo: “Ah, es un LCD, no un LED... déjalo, hijo. Estas cosas tienen tubos que se desgastan con el tiempo, y hay un circuito que lo detecta y hace que el monitor no se encienda o se apague automáticamente... Y, tal vez, podrías cambiar uno de los tubos, pero se rompería en unos 3 meses. No malgastes tu dinero”.
                      Así que… QUIERO CONVERTIR ESTE LCD EN UN LED.
                      ¿QUIÉN SE APUNTA A ESTA AVENTURA?
                      Y lo más importante de todo: ¿cómo podemos engañar al sensor que detecta el fallo de los tubos del LCD?
                      In English:
                      Hi, I have the 2709WFPb monitor. I replaced the capacitors, damaged the board, and got a new one. I plugged it in, but it didn't light up. Today, I went to an electronic engineer's shop in town, and he said he could check the power supply with his oscilloscope. I tested it, and there were correct voltages in some spots... around 18V, but he said it needed to be checked with an oscilloscope.
                      When I showed him the panel with the boards, he said: "Oh, it's an LCD, not a LED... give up, son. These things have tubes that wear out over time, and there's a circuit that detects this, causing the monitor not to light up or shut down automatically... And maybe you could replace a tube, but it would break in about 3 months. Don't waste your money."
                      Now... I WANT TO TURN THIS LCD INTO A LED.
                      WHO WANTS TO JOIN THIS ADVENTURE?
                      And most importantly: how can we bypass this LCD tube sensor censorship?
                      • k4wers
                        Dell 2709w
                        by k4wers
                        hi, i need cap values for the main board of this monitor.
                        ¿does anyone have this model?
                        i just received this board to be repaired but there are missing caps and idk the values.
                        i'd be a good help to get them...
                        10-28-2023, 04:55 AM
                      • eidam655
                        Dell 2709W
                        by eidam655
                        I have a used Dell 2709Wb on my desk that works... Sometimes. There's two symptoms which I'm hoping have a common cause.
                        Issue #1 is that occasionally, when being turned off for a while, the monitor does not turn on. The power button does not react (nothing lights up), replugging the power cable does nothing. After being unplugged for a few hours, the first insertion still does nothing, but plugging it in the socket again but reversed brings it to life.
                        Issue #2 is that when working occasionally after an hour or two the screen switches...
                        02-25-2022, 03:18 PM
                      • Francesc V.
                        Technics SA-AX530 in protected mode. Overload message
                        by Francesc V.
                        I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                        I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                        I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                        (Pin 13 goes through...
                        11-18-2024, 12:39 AM
                      • seppde
                        Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                        by seppde
                        I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                        ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                        The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                        In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                        02-09-2024, 05:19 AM
                      • panoss
                        Samsung LS19A100, slowed down, colors changed, lines not very crisp
                        by panoss
                        In the above mentioned monitor, I removed the plug a few times and this resulted no power.
                        I opened it, soldered the dc jack and worked again.
                        But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
                        I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
                        IC600 (D9329)
                        pin 1 (BST) 9.6V
                        pin 2 (VIN) 13.5V
                        pin 3 (SW(Switching output)) 4.8V
                        pin 7 (EN)
                        pin 8 (SS) 2.6V
                        IC601...
                        10-13-2024, 10:21 AM
