Dell 2709w No power
  • petasis
    • Nov 2014
    • Greece
    #81
    Re: Dell 2709w No power
    I have taken some photos:
    However, I don't see anything wrong (visually).
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      #82
      Great - can you edit your post and take them off - post on the forum using manage attachments so they dont drop off and to save them being loaded every time we look at the thread. - Thanks
      • zombielinux
        • Nov 2014
        • 5
        I know I'm a newcomer, but I do have a request.
        Has anyone decoded the I2C lines and controls for the monitor?
        I have 4 of these that will be in a location where the bezels are not accessible. I'd like to write some code for an arduino or some other micro to control the monitor externally, but I don't have a scope that does I2C capture.
        The way I see it, there could be two different command sets.
        1) Where the buttons are hard mapped and the mainboard only receives 5 different commands (one per button)
        2) Where the buttons are soft mapped to an encoded menu map on the button board, and only the actual menu commands are sent to the mainboard.
        The first option would make for a cheaper bezel and I would hope Dell would have chosen to go that way. Can anyone confirm my hypotheses?
        • petu
          • Nov 2014
          • Россия
          #84
          Hello guys!
          I have two 2709W. One of them failed. The issue is in power board 4H.0GY02.A00 (I discovered this experimental).
          Is there any way to get '4H.0GY02.A00' from somewhere?
          I tried ebay, aliexpress. Only taobao has one but I was late with it .
          (I'm in Russia, Moscow).
          • zombielinux
            • Nov 2014
            • 5
            What is the issue with the power board? You may be able to just recap it.
            • Temelie
              • Feb 2015
              #86
              Originally posted by petasis
              I also have an 2709W monitor, which also stopped (gradually) working
              Did you have any success in repairing it? My monitor - 2809W, RV01 - started to fail, to the point that no image is shown on the screen - not even the menu. The sensor panel works and responds just fine - I can power off/on the monitor.
              I give it a try and took the monitor to a repair shop, but the didn't noticed any fault and they even put the menu panel backwards. So this was definetely not a success
              So I've installed a fan, on the metal case which protects the circuit boards - for cooling purpose. It worked an entire day. But after few hours of standby - during the night, in the morning, the LCD screen is not responding. I notice an attempt to start, but in the end it fails - black screen. So the "stress" was present, while standbying.
              Now I'm thinking that the fault might be in the main power board. I've inspected the capacitors on the boards - none of them looked suspicious.
              • Temelie
                • Feb 2015
                #87
                I've made several photos with a part which looks weird - 1203P60 - the 8 pin part. One has no writings on it ( IMG_5555 - IC651 ). Could it be burned out?
                These could be one of the reason my LCD screen fails and goes black?
                • Temelie
                  • Feb 2015
                  #88
                  Follow-up: It seems that overheating is not the issue. LCD fails to start but after several attempts you get it working. At the beginning only the screen fails, the menu responds just fine. After you get it up&running everything is fine - no blackouts.
                  So the temporary solution for now is to plug/unplug the power cord, until you get the screen working. Obviously I deal with a faulty electronic part, but it wasn't identified after the visual inspection. Not yet
                  An alternative solution would be to leave the monitor always on - picture on or standby.
                  • sergiobajo
                    • Jul 2015
                    • spain
                    #89
                    hi folks. I have this monitor broken because of a storm. I have detected the Q601 shorted (the K3679) and the R603 completely destroyed. I'm trying to find the transistor (not easy yet), but my main problem is that I can't read de value of the Resistence, even in the pictures posted in this thread.
                    Please, can anyone help me with this issue?
                    I'm not sure, of course, that changing this two components the monitor is going to be ok, but that is my first step I thing.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #90
                      R603 is Brown/Black/Orange/Gold 10k Ohms 5%
                      Check also IC651 and D651 and also R699 and R670. I obtained an identical monitor damaged after a power surge with this damage
                      • sergiobajo
                        • Jul 2015
                        • spain
                        #91
                        thank you for this information diif. I will check what you say. Now I am trying to find the damaged transistor. Not easy directly in electronic shops yet here in Madrid.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #92
                          Mine came from eBay.
                            • 31296
                            2sk3679? get a datasheet and find an equiv part.
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              #94
                              Q601 on my monitor was fine. It was IC601i replaced as well as the other components i listed above.
                              • koshy
                                • Dec 2015
                                • Slovenia
                                #95
                                I have same problem as Neill or Temelie. I have to unplug it for few minutes so all the capacitors discharge, then I plug it in and the blue LED turns on but the monitor is dead. I then unplug power until the blue LED turns off then I quickly connect power back and the monitors turns on! So now i don't know in which board is the problem?
                                • Wilkieway
                                  • Dec 2015
                                  • Netherlands
                                  #96
                                  Hello friendly people of the badcaps forum!
                                  So this is what is wrong with my monitor:
                                  It powers on and I can hear the beeps from the onscreen menu however the menu isn't displayed. The backlight does turn on. So the problem seemed to be in the t-con board. I opened it up to find the broken part and there it was, a burnt diode. I tried finding a diagram to find out what part it was without success so I took a shot in the dark and tried to replace it with a HSMS-286E without success.
                                  I have included pictures of the board and you can see which part failed.
                                  When I removed the part after I attempted to fix it i accidentally tore off the solder pads
                                  Does anyone still have this board available and is willing to send it? Otherwise I'll have to nose around the fleabays
                                  • cendalc
                                    • Mar 2016
                                    • Czech Republic
                                    #97
                                    Originally posted by ytsoc
                                    Back with good news.
                                    Thanks to Neil who sent me his board so i can copy that eeprom, i got my monitor up and running again.
                                    Bonus i managed to fix his board too by reflowing the same bga chip.
                                    Hi, my monitor got into the same state as yours - power switch is on (blue), it is detected by pc but it is completely unresponsive and cannot be turned off.
                                    Is there a way how to fix it for a complete newbie like me?
                                    • sergiobajo
                                      • Jul 2015
                                      • spain
                                      #98
                                      Originally posted by petu
                                      Hello guys!
                                      I have found this link: http://www.yoycart.com/Product/520180503582/#
                                      I have not been able to repair my board and I am thinking about buying a new one in this web site. This is the first time I see yoycart.com. Any experience or any other suggestion to buy the 4h.0gy02.a00 board?
                                      • fatsubsonic
                                        • May 2016
                                        Thanks to everyone especially Per Hansson for providing very useful information.
                                        My 2709W just gave up on me last night while swapping power outlets on the wall (spark at connector). Now the monitor is stuck with a Blue LED power button, cant turn on or off just stays blue and screen is total blank.
                                        I suspect is been a long time slow failure as i have witnessed random 1-second powerouts on my screen every couple months.
                                        I have just ordered the following parts on eBay before i even pull apart the screen to get a head start;
                                        IC651 / L6561
                                        IC601 / 1203P60
                                        Q601 / K3679 (2SK3679)
                                        i will check the Caps and Resistors too when i pull apart then purchase locally if need be.
                                        Fingers Crossed !!!
                                        • dzebrys
                                          • Jun 2015
                                          • 7
                                          • poland
                                          #100
                                          hi to all,
                                          good thread and thanks for many ideas how to fix this monitor.
                                          i've own 2 of them and one was faulty. the fault was similar to some described here. it's started with picture distortions once and then, quite rarely to spot. it's slightly similar to degauss function in old CRT type monitors when display shatters or ghost picture artifacts. that usually start after some period of constant work ~1-2h sometimes 4h. it also does happen that it hang on standby and was not able to start, the power button was blue but not responding the only cure was to unplug from power.
                                          forgot to mention there were sight of earlier repairs as i bought it second hand. the panel lid time in service menu says some small value compared to similarly aged unit i own. i suppose it had backlight replaced.
                                          i've started with taking it to the professional service but it give up early. the check of voltages around power and video processing boards does not traces anything unusual.
                                          then i took it to friend for reheating of SoC at 350C. it helped for week or 2 but problem returned. rarely than before but still disturbing.
                                          the second attempt was to add laptop cpu fan at SoC heatsink. i've placed it so that it lays via some heat conductive rubber on top of lower heatsink and lean on the edge of second heatsink. the output air flow is directed toward this second heatsink. forgive me but i don't remember which one is main SoC, the lower or higher one. perhaps higher so air is going via it. off course fan is connected to some 5v found on board. it is hearable but hard to notice in work envinronment. i've tried 3.3V supply but rpm was too little i think.
                                          and this was it! no any problem return after fan mounting. it'a already like 2 months and works without any problems.
                                          hope this helps someone!
                                          regards
                                          piotr
                                          • k4wers
                                            Dell 2709w
                                            by k4wers
                                            hi, i need cap values for the main board of this monitor.
                                            ¿does anyone have this model?
                                            i just received this board to be repaired but there are missing caps and idk the values.
                                            i'd be a good help to get them...
                                            10-28-2023, 04:55 AM
                                          • eidam655
                                            Dell 2709W
                                            by eidam655
                                            I have a used Dell 2709Wb on my desk that works... Sometimes. There's two symptoms which I'm hoping have a common cause.
                                            Issue #1 is that occasionally, when being turned off for a while, the monitor does not turn on. The power button does not react (nothing lights up), replugging the power cable does nothing. After being unplugged for a few hours, the first insertion still does nothing, but plugging it in the socket again but reversed brings it to life.
                                            Issue #2 is that when working occasionally after an hour or two the screen switches...
                                            02-25-2022, 03:18 PM
                                          • Francesc V.
                                            Technics SA-AX530 in protected mode. Overload message
                                            by Francesc V.
                                            I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                                            I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                                            I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                                            (Pin 13 goes through...
                                            11-18-2024, 12:39 AM
                                          • seppde
                                            Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                            by seppde
                                            I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                            ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                            The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                            In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                            02-09-2024, 05:19 AM
                                          • panoss
                                            Samsung LS19A100, slowed down, colors changed, lines not very crisp
                                            by panoss
                                            In the above mentioned monitor, I removed the plug a few times and this resulted no power.
                                            I opened it, soldered the dc jack and worked again.
                                            But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
                                            I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
                                            IC600 (D9329)
                                            pin 1 (BST) 9.6V
                                            pin 2 (VIN) 13.5V
                                            pin 3 (SW(Switching output)) 4.8V
                                            pin 7 (EN)
                                            pin 8 (SS) 2.6V
                                            IC601...
                                            10-13-2024, 10:21 AM
