Dell 2709w No power
    • 31199
    Re: Dell 2709w No power
    can you trace back where the cap gets it's charge?
    this is why i mentioned those 4 resistors - i'v seen resistors in series feeding startup circuits before.
      "Between 1>5 & 3>4 I see 0.5Ω"
      What resistance do you get again between pin 1 and 3 of the transformer as marked in your picture?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        #63
        budm: The value seen on the transformer between leg 1>3 is now: 280Ω & 4>5 is now 290Ω
        They where at 320Ω before?
        Have not checked the K3679 MOSFET on HS1 marked Q601 yet.
        jetadm123: No I did not check VCC on P1203D60 before I put back the transformer, will check your other points later.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          #64
          Originally posted by budm
          Did you check the Source to Drain of that MOSFET on the HS1 to see if it show low resistance?
          K3679 MOSFET on HS1 marked Q601:
          Source > Drain = 285Ω
          Source > Gate = 7.8Ω
          • jetadm123
            • 2169
            #65
            Appears to be a short at S-->G. Suggest you remove Q601 from board and check it again.
              Yep, remove and test it off the board.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #67
                The test was done with Q601 removed from the board.
                So you say it's dead then?
                Datasheet for Q601 (K3679 MOSFET) attached
                  So what resistance do you get now on the MOSFET of the board between S and D, S and G, D and G?
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #69
                    I never tested it in circuit, so values are as posted before more or less:
                    Source > Drain = 275Ω
                    Drain > Gate = 275Ω
                      That Drain to Gate low resistance could have caused damage to the GATE DRIVE output of the SMPS IC.
                      • jetadm123
                        • 2169
                        #71
                        Agree with budm. You should also consider replacing the 1203p60 along with Q601.
                          BTW, do you also see any liquid coming out of the legs of that main filter cap (big brown cap with 450VDC rating), that is one of the common failure cap.
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            #73
                            No the main filter cap measured fine in circuit: 160uF & 0.5ESR
                            It's a UCC KXG 450v 150uF capacitor.
                            And it looks fine too
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #74
                              It's working now!
                              Replaced Q601 & IC601
                              Thanks allot for the advice guys!
                                Thanks for the follow-up.
                                • rocket
                                  • Oct 2013
                                  • 10
                                  Update: I finally had time to crack open the screen. Applying pressure to the main BGA (FLI30366) while plugging it into the mains allowed the monitor to start up. As soon as some flux arrives I'll be attempting to reflow the chip.
                                  • petasis
                                    • Nov 2014
                                    • Greece
                                    #77
                                    I also have an 2709W monitor, which also stopped (gradually) working.
                                    It started with loosing signal from PC a few times a day, the disconnects increased in frequency, until yesterday I couldn't get it to show any input.
                                    After a few cycles of turning it on/off, it got into the state where when powered up only the blue led was on (no dell logo on screen), and in the next power on, even this blue led does not show up.
                                    I opened the monitor, no bad cups inside... :-)
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #78
                                      Can you spot the difference between the first post in this thread and yours?
                                      • petasis
                                        • Nov 2014
                                        • Greece
                                        #79
                                        I measured similar voltages:
                                        The big cap: 315 V
                                        1 (to most black wire) - 0v
                                        (empty)
                                        2- 0v
                                        3- 23.5V
                                        4- 0v
                                        5- 23.5V
                                        6- 23.5V
                                        7- 0V
                                        8 (bottom grey wire) - 0V
                                        The voltage in mine is 23.5V, not 24V. But in general, the voltages are as described on the first post. The blue led does not lit.
                                        (It used to be, but now it doesn't)
                                        • selldoor
                                          Slow Learner
                                          • Dec 2010
                                          • 7870
                                          #80
                                          ok - so straight on clear pictures of your boards and the voltages on the
                                          main board?
                                          • k4wers
                                            Dell 2709w
                                            by k4wers
                                            hi, i need cap values for the main board of this monitor.
                                            ¿does anyone have this model?
                                            i just received this board to be repaired but there are missing caps and idk the values.
                                            i'd be a good help to get them...
                                            10-28-2023, 04:55 AM
                                          • eidam655
                                            Dell 2709W
                                            by eidam655
                                            I have a used Dell 2709Wb on my desk that works... Sometimes. There's two symptoms which I'm hoping have a common cause.
                                            Issue #1 is that occasionally, when being turned off for a while, the monitor does not turn on. The power button does not react (nothing lights up), replugging the power cable does nothing. After being unplugged for a few hours, the first insertion still does nothing, but plugging it in the socket again but reversed brings it to life.
                                            Issue #2 is that when working occasionally after an hour or two the screen switches...
                                            02-25-2022, 03:18 PM
                                          • Francesc V.
                                            Technics SA-AX530 in protected mode. Overload message
                                            by Francesc V.
                                            I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                                            I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                                            I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                                            (Pin 13 goes through...
                                            11-18-2024, 12:39 AM
                                          • seppde
                                            Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                            by seppde
                                            I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                            ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                            The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                            In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                            02-09-2024, 05:19 AM
                                          • panoss
                                            Samsung LS19A100, slowed down, colors changed, lines not very crisp
                                            by panoss
                                            In the above mentioned monitor, I removed the plug a few times and this resulted no power.
                                            I opened it, soldered the dc jack and worked again.
                                            But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
                                            I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
                                            IC600 (D9329)
                                            pin 1 (BST) 9.6V
                                            pin 2 (VIN) 13.5V
                                            pin 3 (SW(Switching output)) 4.8V
                                            pin 7 (EN)
                                            pin 8 (SS) 2.6V
                                            IC601...
                                            10-13-2024, 10:21 AM
