Clicking and Popping?
  • stevo1210
    • Oct 2006
    • 4156
    Hello Everyone,
    I have a Diamond View 1770e CRT monitor that i think is going to die very soon, im only guessing this, but i'm not a computer monitor expert.
    It sometimes clicks or pops and loses power for a second or so during operation. Whats wrong with it and is it going to die soon?
    I wonder if it is time to buy a new LCD display for my personal PC yet?. I only have LCD displays on the gaming PCs, not the work/business PCs.
    Anyone got any ideas to this issue?
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Clicking and Popping?
    common failure in diamondtron crt.
    replaced many in apple studiodisplay series.
    if you look in the neck you can often see the flashover.
    • stevo1210
      • Oct 2006
      • 4156
      Thanks kc8adu,
      Thats sounds quite serious.... i think i might as well throw it in with a computer im giving away to someone....
      I'll probably go back to using that 15 inch CTX monitor for the meantime .... It still works quite well and fits the table perfectly.... the display is for a spare PC in my brothers room anyway.... no one uses it.... apart from me at certain times when i'm really bored.
      Thanks.
      • stevo1210
        • Oct 2006
        • 4156
        I still have that monitor here except I've just taken it out of my shed after a period of storage.
        The flashover popping thing still happens. I also noticed that the monitor is quite dusty.... could dust play a part in the clicking and popping noises??
        What exactly is happening that causes the clicking and popping and can I fix this monitor in any way??
        • Krankshaft
          • Jan 2007
          • 2328
          Dust can cause arcing from the anode cap it wouldn't hurt to clean the CRT off and see what happens.
          The best thing to do is power the monitor up with the cover off and look for any signs of arcing check the deflection coil and in the neck of the tube as another member suggested.
          If those check out then you have an arcing flyback.
          I had an 80s Sylvania TV with an arcing flyback and it lasted for years it was still working when I dumped it.
          Shortly after putting it out a scavenger picked it up .
          Unfortunately I knew squat about TV repair back then man I wish I didn't throw that TV out.
          • mbutts
            • Dec 2007
            I'm new to the forum. BTW love all the useful info u have here. I have worked on a few TV's over the years. I seem to remember GC used to have some high voltage corona dope you could paint on stuff to insulate it from HV arcing. I forget the exact name on the bottle. I found that dust would create a carbon arc path from the anode (HV connection on the neck of the display tube) You can clean the dust off the neck and try to remove the carbon path. However you have to be VERY careful since the anode will have dangerous voltage on it even if shut off and unplugged. I used to discharge them with a HV probe grounded to chassis. DO NOT attempt to try to clean any carbon paths around the anode unless you are completely familiar with working with TV HV sections. 40 K plus voltage can be present there!!!! Flybacks can break down too and spark as noted above.
            Puppy Linux user
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
            • wattage
              AOC AG493UCX 49-inch monitor - Firmware request
              by wattage
              Hello Badcaps Community,
              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
              Today, 04:41 PM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
            • Rick_1234
              LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
              by Rick_1234
              Good evening, gentlemen.
              I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
              To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
              https://drive.google.com/file/d/1L6S...ew?usp=sharing
              Things I tried
              - Bought a new AC adapter thinking that was the problem but the problem...
              06-22-2024, 04:44 PM
              Wise Wing F199 19'' LCD monitor - recapped
              by momaka
              Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
              I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
              When I saw the Craigslist post, I wasn't...
              08-24-2020, 10:58 AM
