BENQ et-0027-b
  • terminatorX
    • Feb 2012
    • 63
    BENQ et-0027-b
    Long time no see
    Ok so this screen has the problem of some temporary flashing.
    When PC is started with this screen it shows bootsplash screen and then the windows logo and then nothing, just a black screen. It seems that it has some problems maintaining the picture. Any suggestions?
  • Rtech
    • Jul 2010
    • 1095
    Re: BENQ et-0027-b
    Open it up and sort some photos out, and I'm sure you will get some help
    • bibilit
      • May 2013
      • 20
      • Montrouge
      Re: BENQ et-0027-b
      Maybe not related, but have a look here:
      https://www.badcaps.net/forum/showthread.php?t=14857
      Benq/Dell monitors are known for those kind of trouble.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Re: BENQ et-0027-b
        Tried the computer with another monitor?
        Ifit works fine with another monitor, you have the "2 seconds to black" issue. (P.S. it isn't always two seconds LOL)
        This can be caused by bad capacitors, a bad backlight inverter, or a bad ccfl/ccfl wiring.
        Muh-soggy-knee
        • terminatorX
          • Feb 2012
          • 63
          Re: BENQ et-0027-b
          Thanks everyone for your interest!
          It would have been fun if the monitor would have c5707 transistors since I have some frome another troubleshooting project But thanks anyway bibilit.
          I did try the monitor with another PC and still the same thing, however I had desktop light shining on the monitor and while it was black I could actually see that there is a picture. Which should mean that for some reason the backlight switches off. So I guess it's what ben7 suggests.
          My pictures are not the best but should be enough for some multimeter testing perphaps.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Re: BENQ et-0027-b
            First, check for some bad solder joints on the PSU.
            Second, try measuring the voltage across any one of the capacitors C701, C702, C703, and C801 (they are in parallel). I'm not sure what voltage you should get, but backlight inverters usually use 24V. It may be anywhere from 12-24V. The thing we are looking for here is, once the backlights go off, does the voltage increase a lot? The backlight could be shutting off due to too low an input voltage.
            Third, each backlight HV transformer has two secondary, high voltage windings. With the power supply OFF and un-plugged, measure and tell us the resistance of each winding. If you are not sure where to measure, I can draw a circle around each pin for you.
            Have you done work on LCD power supply/backlight inverter boards before? Just be careful of the high voltage, don't stick your fingers on the board while it is plugged in!
            -Ben
            Muh-soggy-knee
              Re: BENQ et-0027-b
              Check the Inverter xformer's HV winding resistance.
              It may have bad Dual-MOSFET also, there are four of them that drive the inverter transformers.
              • terminatorX
                • Feb 2012
                • 63
                Re: BENQ et-0027-b
                Hello!
                From the top down the reading on the resistance is as follows:
                1. 2.1 MΩ
                2. 0.991kΩ
                3. 0.985kΩ
                4. 0.982kΩ
                Not totally sure what u mean..I guess u mean the whole board. Tried to look closely at the solder joints and lets say that alot of them look...not so nice but not broken. Have had a monitor that had a broken one. The pin just went through.
                I think I have to ask for detailed drawings for the right points. BTW should the pc also be connected for this test or just the power?
                I did some trouble shooting on a monitor for more than a half year ago and maybe I came across some checking for that but I dont remember. Cant get enough of safety so thanks for that. But Im very green in this still so I cant get enough of details
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Re: BENQ et-0027-b
                  Hello!
                  1. 2.1 MΩ
                  2. 0.991kΩ
                  3. 0.985kΩ
                  4. 0.982kΩ
                  That is the problem. One of the high voltage windings inside that transformer has burnt out.
                  Muh-soggy-knee
                  • terminatorX
                    • Feb 2012
                    • 63
                    Re: BENQ et-0027-b
                    Good!
                    Then we located the problem. I googled the numbers on the part without success...
                    What should I do?
                    • Rtech
                      • Jul 2010
                      • 1095
                      Re: BENQ et-0027-b
                      You could have a look at...... http://www.lcdparts.net/T.aspx
                      and see if they are on there !!
                      • terminatorX
                        • Feb 2012
                        • 63
                        Re: BENQ et-0027-b
                        Like stated before Im green at this so don't assume anything.............
                        I looked quickly at the numbers presented at:
                        http://www.lcdparts.net/T.aspx.
                        Did not see anything that resembless what is wanted however if there would be someone kind that could verify this then the numbers can be seen in one of the photos.
                        Does anybody know what type of monitors are prone to have these exact parts?
                        Obviously asking this in case I find another monitor to act as donor.
                        • canadaboy25
                          What is normal?
                          • May 2013
                          • 509
                          Re: BENQ et-0027-b
                          Could you post the part number(s)?
                          canadaboy25
                          canadaboy25
                          -Sometimes the light at the end of a tunnel is an on-coming train
                          • terminatorX
                            • Feb 2012
                            • 63
                            Re: BENQ et-0027-b
                            Thanks for your interest canadaboy25! Thought people here would be more philantropic....
                            Anyway the supposed part number is on the attached picture. Hope it's distinguishable.
                            Would be interesting if the part could be obtainable from a different source other than
                            Any decent suggestions are welcome
                            • Xer0
                              • Jul 2013
                              Re: BENQ et-0027-b
                              Hi TerminatorX, I have the same monitor with the exact same problem. I have checked the transformers and get ~1k resistance across 3 of the secondary windings and an open circuit across one of them.
                              Did you have any luck finding the part?
                              the part number on the transformers is IJ.26061.021
                              This looks like it might do the trick: http://store.lcdparts.net/1J26051001-MS300T_p_2724.html
                              (More detail of the same part here: http://www.lcdparts.net/TransformerD...ProductID=2724 )
                              The description states that the secondary windings are around 950 ohms and the primaries are at around 0.5 ohms, my crappy meter isn't very accurate but this seems to be close to what I'm getting when testing the good transformer module. The pin configuration looks to match also, but without a dimensioned drawing it's hard to tell.
                              Can anyone please provide advice on whether this is an adequate replacement?
                              • TheAddler
                                • Sep 2013
                                • usa
                                Re: BENQ et-0027-b
                                Would love to know if the above posted part worked or not. I have an Asus VK246H with the same board in it and was wondering if that transformer would work for a 1J.26061.021
                                Thanks!!
                                • thefox
                                  • Nov 2013
                                  • South Africa
                                  Re: BENQ et-0027-b
                                  I havd a similar monitor, and I've deduced that one of the ccfl tubes being broken is the cause of the screen shutting down. Does anyone know where I can source a replacement ccfl tube assembly? I've stripped my whole monitor down but can't find parts online.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Re: BENQ et-0027-b
                                    Anybody got it working with the 1J.26051.001? The CCFLs itself can work fine from 650 to 800 V usually but some dramatic changes may shorten their lifespan. Question is if not only secondary but also primary windings count is the same, the ratio primary:secondary is important.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4298
                                      • Italy - Milan
                                      Re: BENQ et-0027-b
                                      i don't imagine how can a secondary winding increase in resistance without going open...
                                        Re: BENQ et-0027-b
                                        For example:
                                        http://s807.photobucket.com/user/bud...?sort=3&page=1
                                        • abajor
                                          A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                          by abajor
                                          Having this very weird issue.
                                          The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                          I swapped with a working screen from an A2141 waiting for parts.
                                          The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                          The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                          04-27-2024, 01:37 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Yolojays
                                          HP Zbook Flash Screen Logo question
                                          by Yolojays
                                          Hello everybody,
                                          I cleared the Bios password on a HP ZBook 15u G3 Laptop (i5-6200U​) using HPUnlocker tool. My question is, the laptop has a Custom Boot Logo and can't find a way to restore it to the original HP logo. Anyone by chance know a way to do it?
                                          What I tried and checked:
                                          -No custom logo option in bios
                                          -updating the bios did not help
                                          -Hp client management library method id not work
                                          -ereplogo utility di not work
                                          Thanks in advanced....
                                          03-15-2024, 10:04 AM
                                        • jake-b
                                          dell e6540 boots to black screen (no dell logo)
                                          by jake-b
                                          good morning all,
                                          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                                          01-08-2024, 10:29 AM
                                        • deepak47
                                          Asus GA503RM ON BUT AFTER LOGO AND SOUNG SCREEN GOES OFF AND WINDOWS BOOTS PROPERLY
                                          by deepak47
                                          Hello Everyone,
                                          I have this Asus DANJPMB2AB1 REV:B
                                          laptop getting on but after logo and sound screen gets off but the windows does boot properly, moreover it stays on in bios menu.
                                          ​​​help me please...
                                          10-19-2024, 10:46 PM
