Acer H243H Bbmid - replacing caps not enough
  • mcflash
    • Nov 2012
    • 10
    I am from Germany, so I am sorry for my bad english.
    I have here a Acer H243H Bbmid.
    2 seconds to black. you can see the picture with a flashlight.
    I replaced the caps on the supply board. It still doesn't work.
    I left it for a few weeks. on a new test it worked with a whisteling tone.
    I opened it again and then there was the 2 seconds to black again with that whistling tone. I got near with my ear and could locate the tone on the "red marked" piece.
    before the monitor shuts off it is flickering as the whisteling tone is.
    what can I do next to find out what is wrong?
    Is it possible that the whisteling piece is broken or can it be another part which causes in the marked piece the failure?
  • Rtech
    • Jul 2010
    • 1095
    Re: Acer H243H Bbmid - replacing caps not enough
    It could be the bottom set of backlights that is causing the problem.You need to measure the resistance of the two transformer secondaries, and compare them !!
    • mcflash
      • Nov 2012
      • 10
      I have red the tutorial, but I 'm not sure.
      Shall i measure like I marked in the photo?
      put GND on one pin (black) and measure the others (red)?
      how do i set my multi meter 200 ohm or 2k ohm.
      thank you
        @mc, the high voltage winding is on the two pins on the opposite side of your marking, your marking is for the primary side winding of the transformer.
        • mcflash
          • Nov 2012
          • 10
          okay,
          but how can I measure the transformer.
          Where put the GND? on the side with my marking? so I can measure from primary to secondary winding. or only secondary winding?
          this is what I did not understand properly.
            See picture. Just measure at the two pins of HV Winding which is on the secondary side as shown.
            • mcflash
              • Nov 2012
              • 10
              Thanks for the help.
              I measured the HV winding on secondary side.
              transformer 1: 647 ohm
              transformer 2: 658 ohm
              transformer 1 is the one which made the noise.
              so they should be in the 3% tolerance if I understood it right in the guide thread.
              • Rtech
                • Jul 2010
                • 1095
                That looks good, suspect the backlight and/or its wiring
                • mcflash
                  • Nov 2012
                  • 10
                  hello
                  I disassembled the panel.
                  and the bottom pair looks like this. I think it is not good.
                  I have another samsung 19" monitor.
                  can I try the backlight from this one or must it be another 24" backlight? have the manufactures different voltages or are they all the same and the just get more current?
                  • Rtech
                    • Jul 2010
                    • 1095
                    You can try the 19" one for Test ONLY,as if you try and fit it to use permanently, you will get a large shadow on the Screen.So its either buy new,or an old 24" from somewhere with a set of good lamps.
                    • On-3
                      • Nov 2014
                      • st.lucia
                      Originally posted by mcflash
                      hello
                      how difficult was it to remove the back light and did you find anywhere selling them? I'm having the exact same problem as you.
                      • OBTA13
                        • Mar 2017
                        Here's a link to my youtube showing the symptoms
                        I already opened up the power board and visually inspected the caps and none were bulging. Should I just replace the caps first or can this be a backlight issue itself?
                        https://youtu.be/wF0w2yKxIsc
                        • hitec
                          • Apr 2017
                          • 4
                          • algreria
                          check fluorescent lamp
                            09-06-2024, 05:27 AM
                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                            09-07-2024, 05:00 AM
                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 04:10 AM
                            Acer Swift SF314-43-R46R + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                            This specification for the Acer Swift SF314-43-R46R + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-43-R46R + Pack Gold Acer 14'' boardview and SF314-43-R46R + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                            09-07-2024, 03:10 AM
