Samsung 305T bad picture
  • andrew1
    • Mar 2013
    • 32
    Sometimes it works flawless. Could be a bad DVI cable or something else? Thank you.
  • 1supertech
    • Apr 2012
    • 384
    Re: Samsung 305T bad picture
    Try VGA cable
    • andrew1
      • Mar 2013
      • 32
      Originally posted by 1supertech
      Try VGA cable
      This monitor has one DVI port. VGA cable is not compatible.
      • spidey
        climbs
        • Dec 2012
        • 648
        • Cyprus
        reseat the fly cable, logic board to screen.
        • andrew1
          • Mar 2013
          • 32
          I did that but no change. This is how black background looks. If you look closer you see something like vertical lines. In windows alot of colors are missing in the center of color wheel from color correction section (all are replaced with this color I see on black background).
          • lexwalker
            • Feb 2011
            • 307
            • Malaysia
            Try cleaning the LVDS cable and the FFC/FPC connectors on both the Tcon and Dscaler boards, with contact cleaner. Also check the supply voltage to the Tcon board. If that does not help then you're looking at a failing panel (ie. possibly dying Tcon board).
            • andrew1
              • Mar 2013
              • 32
              Thanks lexwalker. i'm going to do that.
              I have a dell 24+1 DVI dual-link cable. There is no continuity on 24,25 pins. Not sure if that's ok and I don't have a spare cable . I'm starting to hate this monitor.
              • andrew1
                • Mar 2013
                • 32
                FFC/FPC connectors - OK
                T-con voltage - OK
                Now I have to check the DVI cable...and last the T-con board.
                • andrew1
                  • Mar 2013
                  • 32
                  The transformer in the picture make a buzzing noise. Any ideas? (Check SMPS diagram).
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                    09-07-2024, 05:50 AM
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • Dodgethis
                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                    by Dodgethis
                    Hello all,
                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                    09-11-2024, 07:39 AM
