Gateway FPD1760 LCD Monitor
  • leaver
    • May 2013
    • 17
    Re: Gateway FPD1760 LCD Monitor
    lexwalker: I assume you are referring to the large IC (IC1) since it has a TI logo on it. Which pin do you think I should be measuring the voltage on? It looks like it has about 100 pins. I am out of town until Friday so I will resume checking when I return. I do have another gateway monitor (same model) so I guess I can try swapping LCD panels to see if that is the problem.
    • jose6326
      • May 2013
      • 707
      Sorry for jumping in on this thread but i havent received help on my thread
      Can someone tell me how to take the cover apart?
      I removed all of the screws and the dam thing wont separate only partially at the bottom
      • lexwalker
        • Feb 2011
        • 307
        • Malaysia
        Yes, that big I.C with the TI logo. Trace any connections from the DC-to-DC converter or regulator side to this I.C (since can't find any datasheet on this obselete part). Swapping panels would be the quickest way to determine if the panel was at fault...
        • leaver
          • May 2013
          • 17
          I swapped the LCD panel with by good panel and the white screen came up just as before. So, I will check the voltages as you suggested on the T-Con board.
          • leaver
            • May 2013
            • 17
            jose6326: If you have a Gateway FPD1760 monitor, you can disassemble it as follows:
            1) Remove the two corner screws on the back at the bottom of the case.
            2) Separate the silver and black sided "picture frame" from the black plastic rear case with a stiff thin tool (like a metal putty knife). Start at the bottom in case you knick the frame a little while you learn how to do it. There are plastic retainer tabs all around the frame that must be separated in order to remove the frame from the back plastic rear case.
            • leaver
              • May 2013
              • 17
              I swapped the LCD panels back to their original configuration and measured the voltage on the large IC4 voltage regulator near the TI chip on the T-Con board. It reads 3.32 volts on the output pin (center pin). The part number of that regulator is RT916A. One thing I may not have mentioned before is that the screen comes on white and shuts down in about 3 seconds. I guess that is because the monitor is not plugged in to the PC.
              • leaver
                • May 2013
                • 17
                My last post said the regulator part number is RT916A. It is a RT9164A. Sorry...
                • lexwalker
                  • Feb 2011
                  • 307
                  • Malaysia
                  #28
                  Then its not the Tcon problem anymore. Check the Dscaler board, and also try swapping the LVDS cables. That white screen means the Tcon isn't receiving any signals from the Dscaler side.
                  It a LDO voltage regulator. Most Tcon main I.Cs runs on 3.3V and/or 1.8V only.
                  • leaver
                    • May 2013
                    • 17
                    When I swapped the LCD panels, I removed the panel that is coming up with the white screen and installed it in place of the LCD panel on my other working Gateway monitor. As I mentioned before, the screen still came on white so I assumed that the problem was with the LCD panel or T-Con board. Was this not a correct assumption? I did not try to install the good LCD panel in place of the one I am getting the white screen on since I thought I had proven that the one panel was bad. Should I try anything else?
                    • lexwalker
                      • Feb 2011
                      • 307
                      • Malaysia
                      #30
                      I see. I thought you swapped the working panel with the faulty monitor. Looks like a dead Tcon board on the faulty panel. You could try powering the Tcon board itself permanently on and see if any self test pattern comes up.
                      • leaver
                        • May 2013
                        • 17
                        I agree and I should have explained more clearly what I did when I swapped the panel. How do I power up the T-Con board to check for a test pattern? I assume I would have to use a separate power suppply.
                        • lexwalker
                          • Feb 2011
                          • 307
                          • Malaysia
                          #32
                          Two ways. First method is thru the LVDS cable by making the FET that controls the Tcon power supply rail to switch on permanently. This works well when the Dscaler board isn't working (e.g. got hit by lightning strike). The second method is to solder the power supply rails directly from the Dscaler board to the Tcon board (with a pair of wires) with the LVDS cable disconnected.
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • penangit
                            Hp v193 monitor power supply board
                            by penangit
                            Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                            I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                            I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                            Steps taken so far:
                            Checked all...
                            02-21-2023, 04:00 AM
                            by momaka
                            03-15-2023, 10:17 PM
