Dell e173FPf
+ More Options
Posts
  • Rtech
    • Jul 2010
    • 1095
    Re: Dell e173FPf
    This is a Monitor that only has one board.
    • mgabriel74
      • Feb 2013
      • 14
      Re: Dell e173FPf
      Originally posted by budm
      Any pictures of the main/logic board?
      Board Part # 790271200800
      • mgabriel74
        • Feb 2013
        • 14
        Re: Dell e173FPf
        Can anybody tell me what values I should have on L856 (labeled on top of the component CHK-053) and L855(labeled on top of the component CHK-057). I was looking at the back of the board and it seems that L856 was replaced. And L855 looks worn out (darker at the top), I don't know if it is because it is very close to cap C871, and the heat generated by the cap make it look like it is now. Please advice!!
        • Rtech
          • Jul 2010
          • 1095
          Re: Dell e173FPf
          Both should read less tha 1Ω.and both look ok on close up.Your fault is located on the part of the board to the right of the Big blue cap,as I have said you can spend lots of time and you will probably still end up with a un-repairable board.
          • mgabriel74
            • Feb 2013
            • 14
            Re: Dell e173FPf
            Well, THANKS once again for all your help!. I guess I will start looking for a replacement. Any lead to where I could find a replacement board at reasonable price??
            • Rtech
              • Jul 2010
              • 1095
              #26
              Re: Dell e173FPf
              Ebay perhaps,or as this is one of the older Dell models,one that may have a broken screen, but works otherwise..Craigs List also an option.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Re: Dell e173FPf
                I don't know what the local pricing is in Florida, but buying an used working 17 inch LCD monitor is $10 or less. Sometimes even free if you ask for one.
                I doubt you will find a replacement board + shipping for under $10 on ebay.
                --- begin sig file ---
                --- end sig file ---
                • mgabriel74
                  • Feb 2013
                  • 14
                  Re: Dell e173FPf
                  Rtech,
                  This will be my very last try, I just measured L855 and L856, and based on your response they should be reading NMT 1Ω. Well, here are the readings:
                  Without Power:
                  L855 = 1.8Ω
                  L856 = 2.0Ω
                  With Power:
                  L855 = 19.0Ω
                  L856 = 4.9Ω
                  I'm asking because, L855 looks worn out, and L856 seems that was previously replaced. Again, if obtained values are considered acceptable/normal, I'll drop the ball once and for all, otherwise, I might have a chance...
                  • mgabriel74
                    • Feb 2013
                    • 14
                    Re: Dell e173FPf
                    retiredcaps,
                    PLEASE tell me WHERE you found them for $10 or below!!!! LOL; I have found some of similar models at craiglist or ebay, but above $50. Anyway, thanks for try to help me on this one!
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Re: Dell e173FPf
                      Originally posted by mgabriel74
                      With Power:
                      L855 = 19.0Ω
                      L856 = 4.9Ω
                      Never measure resistance with power on.
                      Inductors rarely fail. If your reading is not below 1 ohm, it might be because your test leads have high internal resistance. Most of my test leads are 0.2 ohms or less when they are shorted. Cheaper or bad leads can be 1.0 ohms when shorted.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        Re: Dell e173FPf
                        retiredcaps,
                        Where I live, there are lots. So much that I gave up even trying to repair 17 inch monitors because the cost of new quality caps + shipping often exceeds $10.
                        • Lumberjack777
                          • 464
                          #32
                          Re: Dell e173FPf
                          retiredcaps,
                          Check out your local electronics recycling company. The one I volunteer for is nonprofit and we sell them cheap ($10 to $15) like retiredcaps mentioned. Or even give them away to low income families and kids. You can usually get a 17" for $25 or less off Craigslist. Just a couple suggestions. Good luck
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4426
                            • Italy - Milan
                            #33
                            Re: Dell e173FPf
                            watch post #11 in this:
                            https://www.badcaps.net/forum/showth...t=Dell+E173FPf
                            • lcdman
                              TinkerTech
                              • Nov 2010
                              • 232
                              • U.S.A.
                              #34
                              Re: Dell e173FPf
                              Hello mgabriel74,
                              I have one of these boards that I would sell you for $15 and the cost of whatever carrier would ship it the cheapest. Its been re-capped and cleaned to remove any flux residue. If you want it I'll ship it in a anti-static bag. If interested, pm me.
                              Take Care,
                              lcdman
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • nick3092
                                Mid/late 80's Nichicon Yellow Caps
                                by nick3092
                                I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                08-28-2022, 03:56 PM
                                by momaka
                                03-12-2025, 03:42 PM
                              • multimesut
                                Dell 2007FPB Yellow Light Problem
                                by multimesut
                                Hello friends,
                                A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                                11-13-2024, 07:00 AM
                              • huzo
                                DELL Latitude 3500 no image, fan max speed, caps lock frozen
                                by huzo
                                Dell latitude 3500
                                Board BOLT-L UMA MB
                                17938-1
                                FW8G6$LA
                                when i press the power, fan goes full speed, power button lights up , and caps lock light is on, the screen polarises, goes dark,no backlight...All voltages present, except PL4701, but that's probably for GPU power later....
                                I've tried a few dumps from posts, it always acts the same, so i thin it's not a bios issue...
                                No shorts found on the board...
                                What should i try next?
                                10-06-2024, 02:15 AM
