Acer V223w
  • lexwalker
    • Feb 2011
    • 307
    • Malaysia
    Re: Acer V223w
    Originally posted by Behemot
    what's that
    Take a torchlight and shine right on to the panel screen from the top. Best is to turn off the lights in the room while doing it, and the torchlight should be as bright as possible (as some panels are quite dark to see). Check and see if there are any video images...
    • Behemot
      • 4845
      • CZ
      Re: Acer V223w
      Backlight is working fine, I am talking about broken driving circuitry making image trying to appear out of the display.
      • lexwalker
        • Feb 2011
        • 307
        • Malaysia
        Re: Acer V223w
        Does that happen on both inputs, VGA and DVI?
        Have you tried cleaning the LVDS cable, and checking the supply voltage to the panel Tcon board?
        • Behemot
          • 4845
          • CZ
          Re: Acer V223w
          Well I haven't even connected any input, I don't even see the "no input" window. Or I do, like 5 pixels from it flowing from side to side
          LVDS has been disconnected on both sides and seems clean to me. I think I will first try another LCD panel, I am going for two displays tomorrow and one of them is wide panel which should be compatible.
            Re: Acer V223w
            I would check the voltage on both end of the fuse/fuses on the T-Con board first.
            • Behemot
              • 4845
              • CZ
              #26
              Re: Acer V223w
              What exactly do you mean? Fuse is not burned so whatever is on one end, it is on the other end as well.
                Re: Acer V223w
                Well, we did not see you report from POST 18 and on ward if the fuse is good or not or what DC voltage you are getting to the fuse.
                Post 23 also ask "checking the supply voltage to the panel Tcon board?"
                • Behemot
                  • 4845
                  • CZ
                  #28
                  Re: Acer V223w
                  I check everything, you think I am some amateur after all those years?
                  Faster than removing the cover again…if it helps, I'll know the problem is in display/tcon. If not, I'll know problem is in signal board. As for the signal board, besides them all EEPROMs/serial flash memories and main microchip there is nothing else which could go bad (them two regulatorms/FETs are OK). So in such case, only replacement will be an option.
                    Re: Acer V223w
                    "I check everything, you think I am some amateur after all those years?" We cannot tell if you have the voltage on the T-CON or not, we cannot read mind from here. If you think that is an insult, then good luck on your repair.
                    • Behemot
                      • 4845
                      • CZ
                      #30
                      Re: Acer V223w
                      For the ones who have problems with their eyes in capitals: I WILL TRY SECOND LCD PANEL DIRECTLY. SECOND PANEL HAS 100% GOOD TCON BOARD. THAT MEANS WAIT FOR ME TO TRY AND GET BACK WITH NEW INFORMATIONS.
                      Is that understandable? Sometimes I have the feeling you ignore what people say and just repeat yourself till the opposite side just gives up.
                        Re: Acer V223w
                        Can you MAKE IT BIGGER LETTERS?
                        • Behemot
                          • 4845
                          • CZ
                          #32
                          Re: Acer V223w
                          OK, whatever…
                          • wcoyote
                            • Dec 2012
                            • 14
                            Re: Acer V223w
                            OP here. I gave up on mine. I replaced the caps and it worked great for about a week. Then it went back to the original problem. Anyone want parts from it?
                            • lexwalker
                              • Feb 2011
                              • 307
                              • Malaysia
                              #34
                              Re: Acer V223w
                              You could hook it up to a video source to keep the display going. If possible you could also try to invokke the panel self test (not sure if that panel supports self test though).
                              Swapping panels? Make sure you checked the panel datasheet first for pin compatibility...
                              • Behemot
                                • 4845
                                • CZ
                                #35
                                Re: Acer V223w
                                They're compatible most of the times, there are several types of LVDS connections (for 4:3 displays, 5:4, 16:10 and 16:9, the latter maybe have another one with LED backlight) and if you have the right type, there's like 95% chance it will work.
                                I've actually acquired the smalelr version of this monitor, the V193W so hopefully it will be all the same
                                • Behemot
                                  • 4845
                                  • CZ
                                  #36
                                  Re: Acer V223w
                                  Tcon is the problem. Anything I can look for on it? +5 V is fine, +3,3 V (output of one transistor in there) as well.
                                  • lexwalker
                                    • Feb 2011
                                    • 307
                                    • Malaysia
                                    #37
                                    Re: Acer V223w
                                    If you had swapped panels and found the replacement works then most likely the original panel was the problem. Usually for this problems, I would simply find a replacement panel. Trying to find the problem on the panel's Tcon board itself is a very lengthy process and often goes nowhere (plus lack of replacements especially if the main Tcon I.C is spoiled). The most obvious place to check is usually the power supply section to the Tcon main I.C (on the Tcon board itself). Look for cracked solder joints on the I.Cs also (requires powerful magnifying glass plus bright flashlight).
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #38
                                      Re: Acer V223w
                                      Yeah I know, jsut if you have some idea for something simple which may be it, otherwise I'll skipp it, the owner is OK with that, actually he left it here for me. And new panel is most likely not worth it, the cost is higher that price of the display itself.
                                      • lexwalker
                                        • Feb 2011
                                        • 307
                                        • Malaysia
                                        #39
                                        Re: Acer V223w
                                        For Tcon problems, I would consider them hopeless (which is why panel replacement would be better and quicker). I've already try a couple of things like solder reflow, replacement of discrete components, direct power injection (not thru the LVDS cable), invoking self-test, etc. Most of the time I give up.
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #40
                                          Re: Acer V223w
                                          Yeah…I'll just keep the electronics for two or three years when the 1680x1050 panels will be more common, now there's hunger for them and they are too expensive…
                                            09-06-2024, 05:27 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:00 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            Acer Aspire A315-58-38H7 + Pack Gold Acer 15.6'' Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A315-58-38H7 + Pack Gold Acer 15.6'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-58-38H7 + Pack Gold Acer 15.6'' boardview and A315-58-38H7 + Pack Gold Acer 15.6'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 03:10 AM
