DCLLCD DCL7A - quick flash of the back lights only
+ More Options
Posts
  • jayoung
    • May 2011
    • 172
    I have a DCLLCD DCL7A that when turned on shows a very (and I mean VERY) quick flash of the back lights and then goes to a black screen. I have read several threads on badcaps.net concerning the LM004 Rev:3 inverter board. I have replaced all of the electrolytic caps with Panasonic FM / FR and have even swapped out the big capacitor with one of equal value. I have resoldered the pins on the two transformers and also the grey block capacitors near the transformers (one of the legs of one of the capacitors had a cracked joint).
    I have measured the transistors as follows:
    Q6:
    0.599 kohms
    1.930 kohms
    1.212 kohms
    Q7:
    0.600 kohms
    1.929 kohms
    1.212 kohms
    Q11:
    174.6 ohms
    128.5 ohms
    90.6 ohms
    Q12:
    174.8 ohms
    128.8 ohms
    90.4 ohms
    The voltages on the connector to the input board from top to bottom (in the overall picture of the boards):
    0 VDC
    4.84 VDC
    4.84 VDC
    0 VDC
    4.87 VDC
    4.87 VDC
    4.87 VDC
    0 VDC
    0 VDC
    4.03 VDC
    0 VDC
    0 VDC
    no wire
    0.657 VDC
    4.72 VDC
    The voltage across the main capacitor is 160.1 VDC
    The voltage across the start-up capacitor is 13.73 VDC
    Forgive me for the pictures since it's been raining here for the last two days and I couldn't take them outside in natural light. The back side of the input card is a little blurry and I can take it again if someone needs any information from it.
  • jayoung
    • May 2011
    • 172
    Re: DCLLCD DCL7A - quick flash of the back lights only
    Forgot to mention, I have also tried 4 known good ccfl's with the same result.
    • selldoor
      Slow Learner
      • 7870
      Try disconnecting the cable from the main board to the panel. Do the backlights then stay on?
      Have you check the secondary windings on the inverter transformers
      • jayoung
        • May 2011
        • 172
        Disconnecting the cable from the main board to the panel makes no difference.
        Attached are the measurements for the transformers in ohms:
        • retiredcaps
          • Apr 2010
          • 9271
          Q11:
          174.6 ohms
          128.5 ohms
          90.6 ohms
          Q12:
          174.8 ohms
          128.8 ohms
          90.4 ohms
          I regard the above readings are in the "gray" area. They are not 100% shorted, but they are a bit suspicious compared to Q7 and Q6.
          Did you check fuse F1 to see if it is open?
          --- begin sig file ---
          --- end sig file ---
          • retiredcaps
            • Apr 2010
            • 9271
            See if Q9 and Q10 are shorted.
            • jayoung
              • May 2011
              • 172
              Maybe it's too late or my eyes aren't working, but I can't find F1...
              I don't see a label for Q9 or Q10, but if they are the ones below Q8, they don't appear to be shorted.
              Q9:
              2.733 kohms, 10.39 kohms, 12.11 kohms
              Q10:
              2.592 kohms, 10.46 kohms, 12.20 kohms
              • retiredcaps
                • Apr 2010
                • 9271
                See circled.
                • jayoung
                  • May 2011
                  • 172
                  See circled.
                  Fuse measures 0.3 ohms
                  Do I just check each pin to all other pins on Q9 & Q10?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    See my 2 seconds to black guide starting with post #19, there is a procedure on how to test the mosfets.
                    • jayoung
                      • May 2011
                      • 172
                      I've used that document more times than I can count and I thank you for your work on that.
                      The datasheet can be seen here:
                      pins 1, 2, 3 are designated as S
                      pin 4 is designated as G
                      pins 5, 6, 7, 8 are designated as D
                      I've never checked one with more than 3 pins and this one is not designated with S1, G1, D1, S2, G2, D2, etc.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Then check pins 1-4, 4-5 and 1-5.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Your readings for the 2 transformers are radically different. Can you doublecheck your measurements and posting?
                          Also, what is the part number of the transformer?
                          • Rtech
                            • Jul 2010
                            • 1095
                            Because the resistances of Q6 &Q7 are very different to Q11 & Q12,AND there is a significant difference in the transformer readings,as they are interlinked with the Q mosfets,then you really need to take the transformers out and measure them, and then decide if it is one of them or the pair of mosfets that are faulty.
                            • jayoung
                              • May 2011
                              • 172
                              Q9:
                              1 -4: 9.88 kohms
                              4-5: 14.55 kohms
                              1-5: 1.91 kohms
                              Q10:
                              1 -4: 9.99 kohms
                              4-5: 10.56 kohms
                              1-5: 0.60 kohms
                              I double checked the readings, they appear to be correct ( I did however have them labeled in reverse - Transformer 1 is actually Transformer 2 and Transformer 2 is actually Transformer 1)
                              The part number on the transformer is EPC-19
                              I have a couple of other monitors to work on and I'm sure I will be ordering capacitors for those. Since the transistors are fairly inexpensive parts, I will probably add them to my order and replace them. Hopefully that will help in determining if the problem is with the transistors or the transformers.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                If you asking nicely, you might get this ebay seller to measure the resistance of epc-19.
                                http://www.ebay.com/itm/160917988500
                                I'm think I bought something from that seller before.
                                • Rtech
                                  • Jul 2010
                                  • 1095
                                  I would suggest you have a look at Post 14.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Yes, obviously remove the transformer and retest everything, but I was just suggesting that he ask the ebay seller for two reasons:
                                    1) if epc-19 is bad, then he can compare that the replacement is indeed the correct part. Sometimes the part number, even though they are identical, is no guarantee they are the same.
                                    2) we have a reference, however unlikely, in case both transformers are bad
                                    I think we are both saying the same thing, but just from 2 different points of view.
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      You are right,and it is probably the same thing from two different directions.My concern was as yet it has not been shown to be either the transformer/s at fault OR the mosfets, or both,and until the former are removed and checked, as well as the measurements then on the mosfets with the transformers out,it really is hard to pinpoint the problem.
                                      • UniT3d
                                        • May 2011
                                        • 43
                                        Hmmm .....
                                        Pardon me for butting in ...
                                        Rtech is spot on for noting the differences in readings between Q6/Q7 with Q11/Q12.
                                        This is a royer circuit. Those Q6+Q7 or Q11+Q12 is a Rohm part 2sc4672 (available from Digikey). The way the circuit is interlinked, if Q11 is shorted, Q12 readings will also be affected (and vice-versa). The only way to confirm is to test off-circuit.
                                        Also while you're at it, check the tuning polycap tolerance. If its out-of-specs, that new transistor replacement will bork again.
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • tennno`
                                          RCA LED46C45RQ,Sound but no Back lights
                                          by tennno`
                                          Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
                                          Has All voltages coming from main board.No voltage going to
                                          Back lights from power board.Have no Schematic.Back lights work when
                                          Led Back light Strip tester is used.Tester shows 110 volts from each
                                          side.Also if you use the side controls and use the vol +or- tv shuts
                                          down.
                                          Thanks for any help
                                          04-10-2022, 03:34 PM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • Musictuff
                                          70UH6350 Back lights
                                          by Musictuff
                                          My LG tv started going dark a few seconds after powering on. I replaced the led back lights after doing the flashlight test. The problem I am having now is the bottom of the screen is really bright and the middle to the top of the screen is darker. I can actually see the individual leds at the bottom of the screen. Not sure why that is. I've tried lowering the backlight setting but I can still see the led's at the bottom, and the middle to the top of the screen gets even darker.
                                          04-09-2023, 11:45 AM
