LG L1710B - bitten off more than I can chew
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    To start off with, its power LED just blinked continuously
    This pic shows power board in its original condition
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: LG L1710B - bitten off more than I can chew
    I first replaced all the tiny capacitors because their values seemed a bit high on my Dick Smith ESR meter, measured in situ
    Hope dashed for a quick easy fix - power LED still blinked
    I then replaced remaining capacitors, although only the four around IC BIT3105P measured high ESR in situ
    Replacements purchased from local specialist electronics supplier's low ESR category, most of the bigger ones being Hitano
    Power LED still blinks, although less frequently than original
    Repeated cycle of staying on for about 7 seconds, then going off for about half a second
    Accompanied by faint tick which seems to be coming from the area around the LED itself
    Help appreciated
      The ticking sound can mean the power supply is detecting fault so It goes into shurdown - restart cycle, or it has a hard time starting up. Did you also replace the start up caps?
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        I guess those would be included in the tiny capacitors I replaced first, wouldn't they ?
        Two of 4.7uf 50v, one of 10uf 50v & one of 47uf 50v
          Well, I do not know which one you are referring to: "I first replaced all the tiny capacitors because their values seemed a bit high", if you did, then next thing will be to see if the loads are shorted or not by running the board without the main board connected, this power supply-inverter board is always running when you apply the power.
          Check the DC voltage at the output of the secondary rectifier to see if it still pulsing, the shorted circuits can be in the imverter section due to shorted MOSFET's.
          The symptom you have is the same as LGl1715S:
          http://s807.photobucket.com/albums/y...G/LG%20L1715S/
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Thanks budm
            My expertise isn't electronics, so I'm learning (I hope) as I go, and appreciate your patience
            Please don't misinterpret my post #4, it was a genuine question not a smart arse comment
            Your photobucket album looks good - need some time to give it the attention it deserves
            I didn't try powering the FSP board on its own, because I didn't know whether it needed to be switched on or not, like an ATX motherboard
            And because the power switch is on the little controls board that connects to what I think of as the video board - is that what you call the main board ?
              The power supply-inverter board is always on 24/7 the minute you plug it into the wall socket. The power switch just turn off the inverter circuits and the power to the T-CON board.
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Will need some hand-holding to do this - is secondary rectifier mounted on the heatsink surrounding the four caps, in the bottom left corner of picture ?
                • selldoor
                  Slow Learner
                  • 7870
                  I will let Budm answer that in the meantime perhaps measure the voltages on the connector between the power board and the main board.
                  Have everything connected up and switched off meter on 200vdc put black probe on a ground screw and check each pin on the connector with the red probe. As you have pulsing keep the test going to see if the pulsing shows
                  in the voltages. Then repeat with it switched on.
                  If you have a pin called pson or p on test this pin again but hold the probes on the pin with it off then switch it on with the probes in place ( may need help with that) and report wht happens.
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    Originally posted by selldoor
                    meter on 200vdc
                    My DMM's a Fluke 77 (original) which I bought new in the 80s - why?, because similar was what IBM issued their Customer Engineers, who had the best
                    So it's autoranging
                    I measured on the pads beneath the connector which are labelled as shown in this pic
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      First though, I did a bit of rework because it looked like I had a solder bridge from negative of C661 to the track above it
                      This pic shows what it's like now, when I did the measurements, which are:
                      With board only, plugged to mains 240v
                      5v = steady 4.97
                      12v = steady 11.76
                      On/Off = steady .000
                      Then main board connected, complete assembly still plugged to mains 240v, but power button off and LED off:
                      5v = steady 4.92
                      12v = steady 12.40
                      On/Off = steady .059
                      After pressing assembly's power button, LED lights up then ticks off after about 7 seconds, for about half a second, repeats that cycle
                      5v = steady 4.86 until tick off, re-initializes briefly at 4.94, settles at 4.86
                      On/Off = steady .065 - best I can tell, maintains that through tick off
                      12v settles at 13.37 - after tick off re-initializes briefly at 12.14, then 13.3something, climbs by .01 until reaches 13.39, drops back to 13.37, where it stays until tick off
                        That ON/OFF voltage reading does not look right, I expect to see >3VDC for the inverter to turn on. By the way, when you are testing these voltages, do you have all the backlights lamps connected?
                        Please take the resistance readings of the MOSFETS.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          No, logistically too challenging
                          Meter shows 00.2 ohm if probes are shorted together
                          Assuming the dot denotes #1, and others going away from it on the same side are #2, #3 & #4
                          xx or x in lieu of numeric digits denotes a changing value - values given are where they settled
                          Mosfets are marked 4600 AD3E19
                          U2
                          #1 1.3xx Mohm
                          #2 3.50 Mohm
                          #3 1.2xx Mohm
                          #4 1.3xx Mohm
                          U3
                          #1 1.4xx Mohm
                          #2 3.65 Mohm
                          #3 1.4xx Mohm
                          #4 1.49x Mohm
                          U4
                          #1 1.46x Mohm
                          #2 3.65 Mohm
                          #3 1.3xx Mohm
                          #4 1.4xx Mohm
                          U5
                          #1 259x Ohm
                          #2 2.89 Mohm
                          #3 00.2 Ohm
                          #4 35.x Ohm
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Originally posted by pfrcom
                            U5
                            #1 259x Ohm
                            #2 2.89 Mohm
                            #3 00.2 Ohm
                            #4 35.x Ohm
                            http://pdf1.alldatasheet.com/datashe...MD/AO4600.html
                            U5 is shorted.
                            http://www.ebay.com/sch/i.html?_saca...Ao4600&_sop=15
                            $1.02 USD + free shipping for two.
                            PS. In my 2 seconds guide, I wrote a procedure on how to test a mosfet for a short. I suggest you take a look and retest the other mosfets to get all possible combinations with reference to the linked datasheet for AO4600.
                            --- begin sig file ---
                            --- end sig file ---
                              I would change them in pair, might as well order at least 4.
                              When you finished installing the new IC, do not turn on the board without having the lamps connected, it will put out big high voltage (1500~2000V) arc at the lamp connectors when it try to start up.
                              • pfrcom
                                Oldbie
                                • Jun 2006
                                • 1230
                                Thanks for your help budm, retiredcaps and selldoor
                                Have just ordered two pairs of the AO4600, will post a sequel in due course
                                Considering working L1710Bs are on offer here for around $20, this one will be well over-capitalised
                                • pfrcom
                                  Oldbie
                                  • Jun 2006
                                  • 1230
                                  AO4600s arrived yesterday - very good service, especially considering their price, and the season
                                  Here's U4 & U5 after originals removed
                                  For the lifted pad I put a dab of Super Glue underneath, then very carefully flattened it back into place and left it to cure overnight
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    Here's U4 & U5 with the replacements
                                    Sorry budm, mindful of your suggestion, but I couldn't face the prospect of replacing U2 & U3 whose measurements indicated they were probably functional - what with lifting U5's pad, and if it ain't broke ...
                                    Reassemble it so I can plug in the backlights lamps, then the acid test, power it on ...
                                    ... steady green LED, not going Off & On, hmmm promising ...
                                    ... connect it to a computer, and hallelujah there's an image
                                    Thanks again for your help budm, retiredcaps and selldoor - without it, definitely would not have been a successful outcome
                                    • pfrcom
                                      Oldbie
                                      • Jun 2006
                                      • 1230
                                      Some more questions please
                                      This is the set of Capxons I replaced early on, each of which coincides with an AO4600
                                      Is it fair to blame the Capxons for the demise of the AO4600 ?
                                      With the wisdom of hindsight, I probably should have waited for better caps instead of using brandX (can't recall actual brand) from local specialist electronics supplier's low ESR category
                                      Finally this question
                                      I have some Rubycon YXF 47uf 63v in transit
                                      Could I use those in lieu of the brandX 47uf 25v with which I replaced the original Capxon ?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Now that everyting is working, it is a good time to ohm out U5 and see where the lifted pin has continuity to. That way, if the superglue fix doesn't work over time, you can then run a jumper wire from the U5 pin directly to the ohmed out component.
                                        • JonathanAnon
                                          Playstation VR Headset - Cable bitten through by dog
                                          by JonathanAnon
                                          I have one of these.
                                          The main cable that connects the headset to the base station was bitten through by an animal. And so now looks like this:
                                          Most of the wires are big enough to solder, but there seems to be three wires that are wrapped together and they are all silver in color. I'm not sure what to do with these.
                                          Does anybody have any experience with soldering these?
                                          thanks guys....
                                          07-23-2018, 06:47 AM
                                        • josejl
                                          Dell Ultrascan P991 no image.
                                          by josejl
                                          Hello. A few months ago I bought a Dell P991. I was very happy with purchase, geometry was near perfect and the colours were great.
                                          However, two days ago, I was using it, and the image blinked once, but it recovered. 10 minutes, it blinked again, and the image was completely gone.
                                          This is what happens when I try to turn it on.
                                          https://www.youtube.com/watch?v=ENFNS1-DYYc
                                          All electronic shops in my area refuse to do repairs on CRT, so I was wondering what could be the issue.
                                          11-14-2023, 08:41 AM
                                        • choucroutman
                                          Need help diagnosing why my TV isn't working anymore
                                          by choucroutman
                                          Hello, my LG OLED55C8PLA TV stopped working, and here's what happened:
                                          Around noon, it stopped turning on, meaning the screen stayed off, I heard a ticking sound when I tried to power it on, and the red LED light blinked 3 times. Afterward, nothing would happen for about 1 minute, and then the same cycle would repeat. A few days later, there was no more red LED blinking, and whether I tried turning it on with the remote or the power button on the back, it wouldn’t respond. I’ve tried some "quick fixes" I found online, like unplugging the TV and pressing the power button for...
                                          Yesterday, 03:10 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Cooped_Up
                                          Dell Latitude 5520 Motherboard repair
                                          by Cooped_Up
                                          So I have been working on this laptop for a while and I have come so far and I dont want to give up on it so I am hoping someone can see what I am missing. It started with "customer" my brother inlaws GF who said her laptop charger light blinked some colors at her and then no longer turned on so my Brother Inlaw looked at it for her and said there was nothing left to do. Me being me I said I would look at it. well that was close to 2 months ago and I have been working or waiting on parts lol. when my brother inlaw recieved it it no longer showed any signs of life it didnt do anything....
                                          04-08-2025, 05:30 AM
