BenQ FP71G
  • jasmin811
    • Nov 2012
    • 3
    • Bosnia and herzegovina
    BenQ FP71G
    Hello everyone,I have monitor BenQ FP71G and when turn on,somethimes works good without turning off,but when I do something(surfing the net or play the games) it's suddenly turns of.
    The most interesting part is when I take out the Cover from behind it's stays on and I can do everything(surfing,playing the games) it does not turn off.I checked if it's maybe something pressed the panel but it's seems good.
    I checked the caps,it seems that there are OK not inflated or burned or something else.
    Please if anyone can help me with it .
    Thanks a lot for answers.
  • selldoor
    Slow Learner
    • 7870
    Re: BenQ FP71G
    Hi - when you say it goes off do you mean completely - what does the power led do?
    If it is just the backlight see if you can still see a very dark image on the screen perhaps shining a flashlight at an angle.
    Try also reducing the brightness and see if it stays on longer.
    Finally you should do this as a first step.
    https://www.badcaps.net/forum/showpo...2&postcount=21
    If soldering does not fix it then you will need to post pictures so we can look for problems..
    • jasmin811
      • Nov 2012
      • 3
      Re: BenQ FP71G
      Yes it's going cmpletely off,the power led stays on.
      Yes as you says,I can see a very dark image on the screen,almost nothing.
      Do you know what can be?
      • SuperDuty
        • Mar 2011
        • 299
        • France
        Re: BenQ FP71G
        The CCFL lights aren't powering up. So it's either a bad inverter/power supply, or dead CCFL.
        • jasmin811
          • Nov 2012
          • 3
          Re: BenQ FP71G
          Please can you give me an picture of it and circle it please so I can find it.
          Thank you forwardly.
          • selldoor
            Slow Learner
            • 7870
            Re: BenQ FP71G
            Superduty - if you read the post they do power up but then go out later.
            It is a known problem with this set.
            • selldoor
              Slow Learner
              • 7870
              Re: BenQ FP71G
              We are going to need pictures of your boards and you will need to do the soldering as in the link I provided.
              • Behemot
                • 4845
                • CZ
                Re: BenQ FP71G
                I got this well known tragedy which keeps blowing the 2SC5707 transistors. Or not exactly blowing, every time one gets slightly more open and than it stops working (2 seconds to black).
                May the foil capacitors be bad shorting the transistors?
                ADD// all of them are fine shich is strange. I have even tried a bruteforce by using two transistors in paralel So it seems problem realyl is somewhere else…0.22K 160 probably means 0,22uF 160V polyester caps, right?
                ADD2// Oh man, thanks for the Viewsonic VX924 threads Seems to indeed be them polyester caps. Replaced them with two 0,15uF 250V (closest I've found right now) and it seems to work. Will test it during the week, hopefully it will be OK and I can ship it to customer
                • survivalbloke
                  Xbox Series X - crashing to dashboard shortly after launching games
                  by survivalbloke
                  Hey all! I've got a XBOX Series X which came in with the complaint of games crashing to the dashboard after launch. I've tested a few games so far. Red Dead Redemption I observed will load up fine and sit on the menu no problem, but once I actually load into the world, it will not complete the load-in, and crash, stating something about an error must be sent to Rockstar, etc.. Truck simulator seemed to work fine. Minecraft loaded up and zoned into a world, but within a few seconds, it too, crashed to the dashboard. Where are the logs stored? What should I check?​
                  09-18-2024, 11:54 AM
                • seppde
                  Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                  by seppde
                  I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                  ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                  The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                  In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                  02-09-2024, 05:19 AM
                • AJ847.63e
                  BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                  by AJ847.63e
                  Hi All.
                  Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                  The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                  09-18-2023, 06:42 PM
                • amigo744
                  PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
                  by amigo744
                  Hello there,
                  ps5 cfi-1016a disk console
                  Problem: ps5 shuts down when playing ps4 games after cold boot with error code ce-108262-9.
                  After the shut down the console boots up normal and then the ps4 game functions without a problem.
                  ps5 games run allways without any problems after cold boot.
                  Thats absolutely curious....
                  I have already rebuild database, clean cache and reinstall latest firmware with usb stick in safe mode.
                  That doesen´t help
                  Furthermore i have opened console and renew liquid metal on gpu.
                  This all doesn´t...
                  06-19-2023, 05:02 AM
                • ChatBTC
                  Benq EX3501R
                  by ChatBTC
                  Hi!
                  I am new to this site, and found it via LLM ChatGPT.
                  I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                  01-24-2025, 08:49 PM
