Samsung T220 : no power at all
  • h4z4rD
    • Jul 2014
    • 4
    • Croatia
    Re: Samsung T220 : no power at all
    Hello i did not want to open a new thread for this, i have the same problem, monitor does not power on, the button does not come on or the screen. I took it apart and saw that there were two bad capcitors (16V 1000 uF). I replaced them with working ones (tho i only had 10V 1000 uF, my friend who is electronic guy told me thats ok). After that everything is the same, no power at all. I tested both fuses (red and green one), and i measured voltage on the board where vga and dvi adapters are, and all seem ok just like the pins say (5v 3v etc). What else can i check?
    • vinceroger69
      • Mar 2012
      • 6714
      you really need to replace them with 16 volts capacitors going down in voltage ie the 10 volts like you have been advised is ok is never a good idea going up in voltage is usually fine though replace them with 16v 1000 uf then we can start trouble shooting further if needed.
      • h4z4rD
        • Jul 2014
        • 4
        • Croatia
        Thanks, i will try that and report when i replace those.
        • h4z4rD
          • Jul 2014
          • 4
          • Croatia
          Ok, i replaced bad caps with 16 V 1000 uF ones and still nothing, screen is just black, button is not powering on and no lights are on... Next suggestion pls?
            Is your power supply/inverter board is EXACLTY the same as shown in post 1? If it is, then check the DC Voltage right at the two legs of that big main filter cap and report the readings.
            • h4z4rD
              • Jul 2014
              • 4
              • Croatia
              #26
              Yes it is the same, and i have allready measured output voltage (5v 3v 12 v), so i think that part is ok, and i cannot tell you exact voltage on the big cap because i got a shitty voltmeter (measures 250V max ). Is there anything else i can check right now? Ty...
              https://www.dropbox.com/s/upgesr5jsdl94j2/power.JPG Here is a photo of the board, red circles are the new capacitors and the arrow is the end where i measured lower voltage...
              • selldoor
                Slow Learner
                • 7870
                #27
                What voltage on each side of the green fuse with respect to ground
                please upload pics using manage attachments jpgs less than 3mb are good
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4347
                  • Italy - Milan
                  #28
                  Have you checked voltages on the little conn. on the low side on the first photo in this thread? There are 3 voltage regulators on the main board, IC601/2/3, check their datasheet and them, if are ok consider to buy another main board (video input board)
                  • microso
                    • Oct 2016
                    • 13
                    • Romania
                    #29
                    I have same issue with my T220, no power (300 DC voltage across the 100uf 450V main cap and low voltages to CN2).
                    I have 2 caps C301 and C302 bloated, and i replaced with 2x 1000uF 25 V.
                    Again, no power led light, and i start to check the D104 and D105. D104 shows continuity between the anode 1 and the cathode and i replace.
                    Now my T220 is working again.
                    Thx again to all for sharing.
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
