AL196W Acer Monitor- Slightly Different Issue
  • Solder Boy
    • Nov 2006
    • 178
    Hello all before getting into this I did take a look at the AL196W thread that already exists but I didn't quite see anything that resembles the issue I have with the one I am trying to fix ( Either that or I am blind lol)
    Briefly C204 is a new cap, and the cap beside C103 is also a new one.
    After I replaced these caps and turned it on, all I got was a very brief flicker and that was it. I have a set of working CCFL's as testers, I plugged them in and they didn't even fire. However the green/orange power light was on.
    The main filter cap is missing because I initially thought it was bad, will be replacing it.
    I have about 6 or 7 of these monitors to look at.
    Tested the main fuse.. seems to be okay.. I'm a bit rusty with this been away due to medical reasons..
    Any ideas?
    www.bcrelectronics.ca
  • jetadm123
    • 2169
    Re: AL196W Acer Monitor- Slightly Different Issue
    If the main filter cap is missing, you should not operate the power supply, since a large amount of AC ripple is going unfiltered and will damage the other components.
    • Solder Boy
      • Nov 2006
      • 178
      I know that I haven't operated the PSU without it.. I said I'm going to replace it. It was previously installed and that's how I know what it is or is not doing.
      • jetadm123
        • 2169
        Below the inverter transformer in your first photo are two mosfets, Q205 and Q206. Check them for shorts as they are a known problem on your board.
        • Rtech
          • Jul 2010
          • 1095
          And if my memory serves me correctly there is also an SMD fuse on the bottom that blows when the Mosfet/s fail.
          • selldoor
            Slow Learner
            • 7870
            There is a fuse its a small black one marked N top left in the bottom board picture. Test - meter on ohms probe each end of fuse - should read same as touching the probes together.
              Yes, there are two fuses, as jetadm123 has indicated, those two MOSFET's usually shorted out nad blown the surface mounted fuse and some time also takse out the Gate drive resistors and Diodes with them also.
              Also check the secondary of the transformer windings.
              • Solder Boy
                • Nov 2006
                • 178
                Thanks for the input guys.. greatly appreciated will get back to you with my findings soon!
                • selldoor
                  Slow Learner
                  • 7870
                  Hmm in that case there are 3 (Three! ) fuses. 1x N and 2 x W
                    Darn selldoor, your good set of eyes see the third fuse, where?
                    Never mind, I see it now close to the top left.
                    • Solder Boy
                      • Nov 2006
                      • 178
                      I've had a chance to do some measurements:
                      The N fuse reads normal
                      The W fuses all read normal as well.
                      On the transformer it read open on both measuring points as indicated in the edited photo.
                      The 2 MOSFETS near the transformer both read that they were shorted ( not sure if I tested them right though)
                      Last time I tried to get a replacement transformer from Delta, they told me I was out of luck.
                      • selldoor
                        Slow Learner
                        • 7870
                        Can you do a close up pic of the w fuses
                        Mosfet test from retiredcaps 2 seconds to black guide
                        https://www.badcaps.net/forum/showthread.php?t=10419- worth reading
                        start at post 19
                        Mosfets
                        If you have a manual range multimeter, set it to 200 ohms (two hundred). This is for 3 pin ICs only. You can test a mosfet (Q, IC designation) "in circuit" by (power off and unplugged)
                        a) black on pin 1- red on pin 2 - record ohms
                        b) black on pin 1- red on pin 3 - record ohms
                        c) black on pin 2- red on pin 3 - record ohms
                        If any reading is less than 30 ohms you might have shorted mosfet. Remove from circuit and repeat the tests to verify.
                        Some mosfets are more than 3 pins. To test those, identify the part number and search for its datasheet. Once you find the datasheet, the pins will be designated source (S), gate (G), and drain (D). It will probably be documented as S1, S2, G1, G2, D1, D2.
                        Simply test
                        a) black on pin S1- red on pin G1 - record ohms
                        b) black on pin S1- red on pin D1 - record ohms
                        c) black on pin G1- red on pin D1 - record ohms
                        Repeat for the "2" pins. That is S2-G2, S2-D2, G2-D2.
                        Note: a shorted mosfet would likely cause a very brief flash of the backlight or no backlight.
                        Transformer - Unusual for BOTH to be open check that your meter was on 2000 ohms
                        and also that there was no lacquer on the pins like in Budms picture scrape down to bare metal
                        • Solder Boy
                          • Nov 2006
                          • 178
                          Thanks for the additional input selldoor, will do the additional measurements tomorrow.
                          Regarding the transformers I did peel off the silicone, will use a different meter.. the one I used didn't have a selector switch.
                          As I said earlier.. little rusty doing this.. hadn't done much service work lately.
                            If you find out that this monitor has bad the transformer, shorted out MOSFET's, blown fuses, needs a set of caps, and hope that it does not have bad lamp/s. You may want to total up all the parts to see if it is worth to repair it not. But for learning how to troubleshoot the problem, that will be priceless.
                            • Solder Boy
                              • Nov 2006
                              • 178
                              a) black on pin 1- red on pin 2 - record ohms Open
                              (b) black on pin 1- red on pin 3 - record ohms Open
                              (c) black on pin 2- red on pin 3 - record ohms Resistance varied then read open.. 2nd Mosfet read 176 then instantly read open
                              I used my digital MM with a selector switch obtained reading of 751 and 749 OHM respectively
                              I retested the SMD fuses again this morning.. I did find one of the W fuses that read open.
                              Tried taking a close up of the W fuse in question turned out blurry. If I can get a clear closeup I will post a pic.
                              • Solder Boy
                                • Nov 2006
                                • 178
                                Well it was a learning experience that is for sure, after thoroughly testing the PS board with the help from this forum.. I think it might be a case of not worth fixing.
                                I'll certainly be a bit more thorough with my diagnostics in the future before I go ordering caps assuming that alone will solve the problem.
                                • jetadm123
                                  • 2169
                                  You might be able use parts from this monitor to repair the other monitor you're looking at.
                                  • Rtech
                                    • Jul 2010
                                    • 1095
                                    The transformer readings look Ok now,and normally replacement of the two mosfets and the fuse, would restore it to life.
                                    • Solder Boy
                                      • Nov 2006
                                      • 178
                                      I hear you on the mosfets, those I'm sure I can source out but the little W fuse is another story. I have no idea what value it is or even the foggiest idea where I would get it from.
                                      If anyone has knowledge in that dept please let me know
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        Id keep this one as spares and use the other "w" fuse to replace the one in the screen you seemed to quickly set aside as it had a blown "w" fuse?
                                        Try google smd fuse marking
                                        • DqMagetz
                                          Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                          by DqMagetz
                                          Good day!
                                          I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                          Here are the voltage readings:
                                          • Input – 19V (stable)
                                          • +LCDVDD – 3.3V briefly, then drops to 0V
                                          • EDP_HPD – 3.3V briefly, then drops to 0V
                                          • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                          • EC BKOFF# – 1.8V briefly, then drops to 0V
                                          • PANEL_OD_EN – 0.3V
                                          Is it possible that the EC chip is corrupted or damag...
                                          07-12-2025, 09:37 PM
                                        • Mirenia
                                          Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                                          by Mirenia
                                          got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                                          The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                                          If this happened once, then the laptop only runs for a few minutes until restart.
                                          This happens regardless while staying in windows or uefi or in a linux environment.
                                          At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                                          01-05-2025, 05:15 PM
                                        • maralexbar
                                          How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                                          by maralexbar
                                          I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                                          It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                                          If anyone knows how to force the external monitor as primary for Notebooks of those models
                                          11-02-2024, 09:18 AM
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
