Substituting 680uf 25v with 1000uf 35v
+ More Options
Posts
  • 1supertech
    • Apr 2012
    • 384
    Hello folks
    I am replacing caps on a Hp 19" monitor power supply It has 2 680uf 25v caps
    can I replace them with 1000uf 25v instead
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Substituting 680uf 25v with 1000uf 35v
    Title says 35v script says 25v - will they physically fit?
      If they are good caps, probably okay. If you are subbing them with general purpose ones, then no.
      • 1supertech
        • Apr 2012
        • 384
        I found 680uf 25v on digikey
        • tieny
          • Feb 2012
          • 478
          What do you mean by "general purpose" caps?
            Not suitable for power supply applications; not low ESR and ultra high reliability at high temperatures.
            • mariushm
              • May 2011
              • 3799
              There are series and series of capacitors, some are more general purpose with lower life time and temperature and not so great technical specifications ... others are more suitable for power supplies due to their low impedance and high ripple specs.
              You can have 1000 uF 25v capacitors rated for 2000 hours @ 85c with 500mA ripple and 0.4 ohm ESR/impedance.
              It might be unsuitable if the capacitor you replace had 800mA ripple and 0.2 ohm esr/impedance. Also, considering monitors are usually hot in the back and there's not much air around to keep stuff cool, such capacitor with 85c rating would cook itself and die in a few weeks or months.
              You'd want a capacitor that has 2-4000 hours @ 105c, as close as possible (ideally higher) ripple and less impedance/esr than the original capacitor.
              • ziauddin
                • Oct 2014
                • usa
                Originally posted by 1supertech
                Hello folks
                hi
                thats a starter cap dont put anything different
                zia
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • SwedishDiesel
                  Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                  by SwedishDiesel
                  Howdy folks,
                  I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                  10-30-2021, 12:47 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
