Dell 2408wfpb
  • selldoor
    Slow Learner
    • 7870
    Re: Dell 2408wfpb
    Were the volatages taken with it all connected up?
    In pic 4 down the right hand side there are the 4 bigger components with 2 and a half legs
    bottom one might be Q30 - Can you read the part numbers on them(may be all the same)
    • Rtech
      • Jul 2010
      • 1095
      Re: Dell 2408wfpb
      I would concentrate on finding the 5v,This is normally the only voltage that is regulated,and the rest do tend to 'float' somewhat,so think the 23v for now is not a problem.
      • jetadm123
        • 2169
        Re: Dell 2408wfpb
        Just wondering if the 23V is the standby voltage and maybe there's some sort of 5V regulator on the video/logic board? Why else would they be running 23V to the logic/video board?
        • Rtech
          • Jul 2010
          • 1095
          Re: Dell 2408wfpb
          You may be correct,unfortunately I don't know a lot about this Model,so would be helpful,if we perhaps had some more input from someone who does ?
          • knoxrebel
            • Oct 2009
            • 168
            Re: Dell 2408wfpb
            23.1V for all. All boards were connected
            #'s are 4h.oct02.a00/5E0CT02001 Power
            4h.oct01.a02/5edcoct01001
            • knoxrebel
              • Oct 2009
              • 168
              #26
              Re: Dell 2408wfpb
              The 4 components are mosfets Pn j598 ks 7
              • jetadm123
                • 2169
                #27
                Re: Dell 2408wfpb
                Having looked at budm's dissection of a dell 2407wfpb:
                https://www.badcaps.net/forum/showthread.php?t=21042
                Even though the boards are different, they apear to be made by the same company. Using the 2407 as a reference, it looks like the standby voltage is not 5v. The question now is your video card sending the PS/ON and BL/ON commands?
                Have you tried measuring the voltages of the power/video board wiring harness when you press the on/off power button? Hopefully you will see one of the wires that's now reading 0v rise to ~3.5-5v
                  Re: Dell 2408wfpb
                  It looks like it works the same as the 2407 I just took apart, if he is getting the 23Vdc (the 2407 uses 19V always on power supply) then the power supply is working, the lower voltages are on the logic board and are done by the LDO regulator and buck converter regulators.
                  Start checking those voltages, it should have some 3.3V, 1.8V LDO on the logic board.
                    Re: Dell 2408wfpb
                    I like to see pictures of all the boards to see if they look anything like what I have here:
                    http://s807.photobucket.com/albums/y...P%20Rev%20A02/
                    • knoxrebel
                      • Oct 2009
                      • 168
                      #30
                      Re: Dell 2408wfpb
                      Budm, they are the same boards.
                        Re: Dell 2408wfpb
                        So your power supply is OK then since you are getting the 23V. Just start checking the voltage regulator on the main board next.
                        • meangene
                          • Jul 2012
                          Re: Dell 2408wfpb
                          Has this been resolved? I have the option to refurbish one of these monitors and it appears that it's exhibiting the same fault. I'd rather not have to buy replacement circuit-board modules...
                          • sebr
                            • Oct 2010
                            • 79
                            Re: Dell 2408wfpb
                            Is the inverter of this display the same as the 2407 ?
                            • benco
                              #34
                              Re: Dell 2408wfpb
                              PSU : TP710 - 3,3V
                              TP707 - signal on=3,3V , off=0V
                              3,3V and signal go from the IC FLI30336-AC BGA
                              reball or new
                              https://www.aliexpress.com/premium/f...91&blanktest=0
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • master3112
                                by master3112
                                07-29-2025, 01:55 PM
                              • F R 2568
                                Dell Latitude 5420 does not start (no post) need help to find the reason why
                                by F R 2568
                                Hello all,
                                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                If the laptop is only connected to the AC adapter (battery removed):
                                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                The power/battery...
                                01-08-2025, 05:45 AM
                              • diamon
                                Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                by diamon
                                I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                Pictures of these boards:
                                Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                Dell...
                                02-28-2024, 12:51 PM
                              • lalle-
                                Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                by lalle-
                                Hello!
                                I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                08-11-2024, 02:01 PM
