Samsung Syncmaster 460p
  • tieny
    • Feb 2012
    • 478
    Hey guys, I have this samsung syncmaster 460p monitor that turns on (backlight turns on) but there is no picture. I looked at power supply unit and it is filled with samyoung and samwha capacitors so I'm thinking to replace all of those first.
    Considering all the capacitors are actually acting fine, what would cause the no picture? any suggestions?
    For a capacitor that rates 16V 1000 uf, is it okay to replace it with a 25V 1000 uf capacitor? (basically only a higher voltage rating)
    Wondering if anyone has the service manual for this monitor? that'll be great! thanks!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung Syncmaster 460p
    If the power LED is green and the backlights are on, then it may be a blown SMD fuse on the panel card. The panel card runs the entire length of the monitor and usually found underneath a shield at the top of the lcd.
    Alternatively, you could have a loose cable. Clean and reseat all your cables.
    PS. I always recommend testing monitors with a known working source that displays your favourite wallpaper.
    --- begin sig file ---
    --- end sig file ---
    • tieny
      • Feb 2012
      • 478
      The panel card? Would that be the same as the T-con board?
      • retiredcaps
        • Apr 2010
        • 9271
        Since you listed this in the "computer display" section, I called it the panel card. If this were in the TV section, I would call it the t-con.
