Samsung Syncmaster 940BW White screen
  • Sparks88
    • Sep 2011
    • 110
    I have a sammy 940BW 19" monitor with a white screen, did a visual and on the video board a component has blown, its designated Q400, unfortunately its totally white so unreadable, anyone had the same problem and managed to identify the component or a schematic would be very usefull, i have also checked the lcd board and a smd ceramic cap seems to have been stressed because its got black scorch marks on the pcb lands.
    Any pointers appreciated.
    Re: Samsung Syncmaster 940BW White screen
    The Q400 is on the logic board (the board where you plug in the VGA cable)? Or it is on the board attached to the LCD panel assembly.
    you can download service manual from www.elektrotanya.com
    • selldoor
      Slow Learner
      • 7870
      Cant see a q400 on the schema perhaps different revision.
      Can you post good clear pics of the boards - fronts and backs label them as you refer to them so we know which you are referrring to and also a close up where the q400 was and a pic of the remains.
      Could you also update your profile with country and mains voltage.
      • Sparks88
        • Sep 2011
        • 110
        Q400 is on the logic board and the ceramic cap on the lcd, i have managed to get a manual after having to put up with a load of adverts, managed to get all needed components from farnells in uk so will see if it powers up after i change the mosfet and cap, if it works i intend on recapping the board cos its got capxon, here goes with fingers crossed, will update after i finish.
        • Sparks88
          • Sep 2011
          • 110
          replaced the 100nf cap on the lcd and the mosfet q400, cleaned the board because the tracks under q400 were burned away and had to put in a link across to where the tracks were missing, powered on and was rewarded with a good picture, success, another monitor salvaged from the scrappers.
          • Tetsujin
            • Dec 2012
            • 3
            • Romania
            Hello there, i have the same problem with my samsyng synchmaster too, but i noticed on logic board the piece marked in red square being fat, i mean isnt flat...
            So, what kind of SMD is that? And with what i can replace?
            Because when i power on, backlight work but the screen is white, like there is no cable connected from logic board to lcd screen.
            And here is the printscreen: http://s15.postimage.org/fqmtuemvt/DSCN0205.jpg
            • selldoor
              Slow Learner
              • 7870
              That is a good picture - can you re-post it using "manage attachments"
              found by scrolling down in "go advanced" under quick reply.
              I thought there should be a q400 on the board as mentioned earlier in the thread but there is not.
              Can you decipher the part number?
              White screen is often a blown fuse on the panel board - can you do a picture of that?
              • Tetsujin
                • Dec 2012
                • 3
                • Romania
                The part number is not listed in electrical part list of the board.
                On the board the part is noted in a square with Q301, and on it is coded TR2 or TA2, like in the picture above, but the Q301 is not listed on electrical part list.
                The fuse on the panel board is good i`ve checked it with a multimeter.
                I cant make good pictures now because i dont know where is my data cable...
                • selldoor
                  Slow Learner
                  • 7870
                  Is there something after the TR2?
                  • gavs
                    • Oct 2012
                    • 4
                    • Russia
                    You can thank to obscure colleague from China, who had published the following Service Manual: According to this document Q301 is P−Channel MOSFET NTR2101P(8.0V, 3.7A, ).
                    • Tetsujin
                      • Dec 2012
                      • 3
                      • Romania
                      Yes is a 3 but turned down, i think is the lot number
                      I will, because i guess that part is a NTR2101P-D mosfet.
                      Thanks very much.
                      I`ll keep in touch if the problem is solved..that device on my board is blown, like a half expanded popcorn :P
                      • harp
                        White screen repairs
                        by harp
                        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                        05-13-2024, 03:43 AM
                      • Chrissygizmo
                        samsung galaxy ao2s very temperamental after screen replaced
                        by Chrissygizmo
                        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                        Ive eventually managed to get it on and working but it's very temperamental...
                        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                        05-26-2024, 12:05 AM
                      • JunkmanJimbo
                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                        by JunkmanJimbo
                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                        No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                        Please help. Thanks in advance!
                        Yesterday, 11:45 AM
                      • Kiberge
                        Samsung LH82QENELGC/EN Help needed - Static line on screen
                        by Kiberge
                        HI guys!
                        I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                        I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                        the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                        This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                        04-22-2024, 11:28 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
