Philips 230WP7NS Professional Series LCD
  • vdvrande
    • May 2013
    • Netherlands
    Re: Philips 230WP7NS Professional Series LCD
    After 5 years my 230PW7NS monitor stopped working. It started with a synchronization problem, that could be solved by switching the monitor off and on again. But after some time it died completely. Too soon I think, so I would like to fix it, especially since I am (at least was) very happy with the image quality.
    Looking around on the internet I was lucky to find this topic, with some interesting information.
    I also found another (more extended) version of the service manual:
    First I would like to check the PSU board. A visual inspection does not show anything abnormal: no bulging capacitors, no burned resistors, no broken fuse. So I seem to have a different issue compared with the problem the topic starter had.
    Next I would like to put power on, and do some measurements. But at this point I am a bit unsure: Is it ok to power on the PSU board stand alone, so without connections to the other boards? Also I would like to know whether the 'Power Saving' signal can be left floating or not.
    Hopefully someone has some suggestions for me.
    @Scenic: Did you succeed in repairing your monitor?
    • spantor
      power board manual philips 55pus6482/12 715g-p01-000-0h2s
      by spantor
      Hello.
      Some components have exploded and I can't figure out the values. I have obtained the manual for this power supply for 65" but comparing components there are some differences and it is not reliable.
      Could someone leave me the power supply manual for this 55" model?
      I would be very grateful
      03-19-2024, 01:19 PM
    • mikey5791
      by mikey5791
      Hi to all forum members,
      12-26-2024, 04:55 AM
    • MidnightRoller
      Can a resistor lose resistance after hot air?
      by MidnightRoller
      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
      02-02-2022, 11:46 PM
    • artvandalai
      What resistor ohm will work better to repair this waterpik?
      by artvandalai
      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
      01-05-2025, 04:10 PM
    • Sisko
      Onkyo-593 No power and now clicking sound
      by Sisko
      Hi all!!
      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
      10-03-2025, 02:18 PM
