Inverter tester using old CFL
This is a sticky topic.
+ More Options
Posts
    Re: Inverter tester using old CFL
    That is for testing the lamp, for testing the inverter circuits, you need test lamps.
    You can use something like this for testing lamps or replace your burnt out inverter.
    http://www.ebay.com/itm/Universal-CC...ht_5300wt_1400
    • LDSisHere
      • May 2012
      • 727
      • U.S.A.
      I picked up two devices off of Ebay to test CCFL lamps and I find them very handy. I will attach a picture with both of them in it. I like the larger black one better because it will drive larger bulbs and it came with more connectors. Budm's device is good to have around to test the inverter itself but I have found being able to directly test the CCFL's to save a lot of time and trouble. This may especially be true if you are unfortunate enough to have two blown CCFL's at the same time. The black one cost me $8 shipping included and took about two weeks too arrive. This device may not be everyone's cup of tea but I find it extremely useful. Even if I find obviously bad caps I still check the bulbs before doing any work because some monitors are not worth the effort of replacing the CCFL's IMO. It is quite frustrating to recap a power board and still have two seconds to black because of a burnt CCFL.
      • Ahakim
        • Apr 2013
        • 64
        Good idea. Not bad! I have many of them left aside...
        • tibimakai
          • Jan 2012
          • 3680
          How could we test LED strips in the panels?
          • selldoor
            Slow Learner
            • 7870
            perhaps one of these?
            http://www.lcdparts.net/LEDDriver.aspx
            Cant see any on ebay - yet?
            • bms operator
              • Jul 2013
              • Philippines
              #26
              Originally posted by budm
              Do not throw away those broken CFL (14Watts or smaller), you can use them for testing your LCD monitor inverter circuits without buying spare lamps for testing.
              You can solder the wires directly to the connectors on the inverter board or you can get the correct connectors but then you have to have more than one type.
              I tested it out on my lamp tester board as you can see in the pictures.
              I open up the lamp assembly using small hack saw just enough for me to crack it open, just be real careful.
              Enjoy!
              very informative, I'll do it in the future.Instead of buying spare lamp its good to know broken CFL can be used for testing.
              Thank you!
              • notallbad
                • Oct 2012
                • 1183
                Decided to hack a Philips 11w Genie Energy Saver bulb for inverter lamp testing, is this one suitable?
                Guess I'll soon enough find out!
                I noticed that your inverter b/d is slightly different to mine, where your blue and black wires go to the inverter would imply supply and return on the one connecter whereas other inverter b/d's (like the one I'm currently using) have the 'gnd' pin on a 2 pin connector at the bottom of the inverter b/d.
                  There is no polarity on the lamp connections to the board, as long as the wires are connected to the two pins of the socket that will be fine. This inverter board is for the TV so the ground return is on the small connector at the bottom right in the pictures, the two pin on the white connectors are for two lamps. If you look at the spec sheet of the panel, it will show how the lamps are arranged inside the panel.
                  • notallbad
                    • Oct 2012
                    • 1183
                    Thanks, seems I need to hook up one or two more 11w energy bulbs, the house is getting darker and darker as the lights go out and I won't be able to see what I'm doing soon and the wifey be home soon oops, still 2 secs to black!
                    Arghh dreading the worst now, faulty lamp.
                    Is this just a test to see the lamps illuminate briefly or should they run continuosly?
                    • notallbad
                      • Oct 2012
                      • 1183
                      OK, so after having replaced lamp 3 and 4 with energy savers it appears both 3 and 4 lamps are at fault, the backlights and energy savers come on and remain on. But with just 1 energy saver hooked up in place of either lamp 3 or 4 it goes back to half lit screen and 2 secs to black.
                      Thanks for this great info Budm, its now pinpointed my issue and given me an invaluable test tool for future use. Keep up the great work!
                      • PohTayToez
                        • Jun 2010
                        • 80
                        I just used this trick to great success and wanted to say that I came up with an easy way to separate the plastic housing on the base of the bulb. I didn't have a hacksaw handy so I put the lower half of the bulb in a vise and tightened it slowly, crushing the lower housing causing the upper part to pop free. I suppose there might be a chance of shattering the bulb this way, but both the ones I did this too popped free easily without having to apply too much pressure.
                        • danthompsonz
                          • Oct 2013
                          I just became a member, looking to repair my GATEWAY hd2200 / SAMSUNG 226BW screen, found a frayed HV wire right at the Silicon boot attached to the CCFL, the Lamp had burst and white stuff all over the back lead me to the trouble. I used this home CFL method and found inverter to be working somewhat. lamps still shut off and back on now in about 30 sec intervals, instead of 2sec to black. wonder if some component has also shorted on the inverter board.
                          All caps have been replaced, whole board re-soldered, and computer was attached to avoid standby mode, but still DOES go to standby, lamps off and returns back on by it self, lamps back on. any thoughts?? thanks Dan
                          • Phoenix83
                            • Jan 2014
                            • 53
                            • Slovakia
                            #33
                            Good idea, nothing complicated and yet it works.
                            Tomorrow I'll try it with 14W conventional fluorescent bulb.
                            • HAHOMETP
                              • Nov 2012
                              • 155
                              LDSisHere,
                              thank you for confirming my choice of the black tester over the blue one. Just ordered it from HK.
                              In the 4th picture all 18 CCFLs appear to be dark in the middle. Do you know why this is happening?
                              • LDSisHere
                                • May 2012
                                • 727
                                • U.S.A.
                                #35
                                The tester is made to drive one or two CCFL bulbs at a time. The 18 are part of a 32in TV where all the bulbs were wired in parallel. The center not being lit is not important as it is due to lack of power. The important thing is that they are uniform and all lit, if one was bad it would stand out. I was just wanting to show what it could do when pushed beyond it's design limits. I would also not do this for very long as it could damage the driver.
                                • HAHOMETP
                                  • Nov 2012
                                  • 155
                                  The reason I asked is I am seeing exactly the same in my Dell 2408WFPb:
                                  https://www.badcaps.net/forum/showpo...7&postcount=19
                                  The curved portions of the U-shaped lamps in the left side of my monitor are equidistant from their pins and they sometimes remain dark whereas the right side of the monitor where their straight ends are located ignites just fine. The fact that all 7 of them are doing this simultaneously leads me to believe that the problem might lay upstream. Perhaps the CCLFs are not getting enough power? If yes, then what common element might be responsible for this?
                                    Not enough voltage to drive the lamp is what I have seen when lamps are not fully lit.
                                    • aortiz
                                      • Feb 2014
                                      • 120
                                      • mexico
                                      #38
                                      good afternoon bud,can i use just 1 lamp,or i have to to have all the lamps conneted to the inverter board,to find out if the inverter its working or not? my dell monitor looks like it has all bad lamps,6 of them.
                                      • HAHOMETP
                                        • Nov 2012
                                        • 155
                                        Budm wrote in another thread:
                                        Thanks for the follow up. So what kind of 5W CFL lamp did you use? T5 type?
                                        Yes, I scavenged a 4W T5 bulb from an old Coleman Powermate. I should've gotten 6 more of those along with 7 pairs of alligator clips. The monitor that I was troubleshooting had problems in two inverters at the same time. That's why this single bulb when connected to them one by one would still result in the two seconds to black.
                                        Since we are on this subject.
                                        A while ago I took apart a non-working fluorescent bulb with a spiral tube like in the OP. The bulb was merely a week old and the tube looked brand new w/o any dark spots, so naturally I suspected the electronics. The circuit was comprised of several discreet components and I tested every one that had a p-n junction - they all checked out fine. Next I took apart an identical brand new bulb - fortunately this particular type had the easy to open snap-in cases. I swapped out the tubes with the electronics. After that they both lit up fine.
                                        In this particular bulb (picked up on HD sale: $2.97 per pack of 4, Soft White 2,700K) the spiral tube pins are simply inserted into the two pre-tinned eyelets in the PCB. The pins on this tube were dark of oxidation. My guess is the pins gradually lost contact with the soft tin in the eyelets and the bulb stopped working. I scraped the pins with a knife, reinserted the tube into the circuit and the bulb fired right up. In the hindsight I should've taken apart 3 or 4 dead ones that I had tossed into trash a few weeks ago. I bet they were fine as well.
                                        Yesterday I finally received that $8 CCFL tester from China. Below is a picture of the 4W T5 bulb connected to this tester in front of the newly repaired Dell monitor.
                                        • HAHOMETP
                                          • Nov 2012
                                          • 155
                                          A loosely related follow-up.
                                          This $8 CCFL tester from China and a $10 Milwaukee Non-Contact Voltage Detector (2200-20) proved to be rather useful in troubleshooting the intermittent lighting issue in the lightbox for commercial photography that I've built a while ago. Turned out that all 8 fluorescent tubes are still good but 2 out of 8 channels in the IceCap ballasts are dead.
                                          • Yanleb
                                            Sharp LC-60LE810UN Lamp Error
                                            by Yanleb
                                            I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                                            I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                                            Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                                            I've tried all the key...
                                            08-24-2021, 11:48 PM
                                          • vestaviascott
                                            Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                            by vestaviascott
                                            Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                            Here's what happens:
                                            1) Power on
                                            2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                            3) Blue status light flashes for appx 4 minutes...
                                            07-29-2020, 06:08 AM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • AJ847.63e
                                            BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                            by AJ847.63e
                                            Hi All.
                                            Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                            The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                            09-18-2023, 06:42 PM
