HANNSPREE HF289H Black Screen No Power
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: HANNSPREE HF289H Black Screen No Power
    Ok easy bits first
    TCon board white oblong Fuse F400 near socket at top of picture (4 of7)
    Inverter board Pic (3of 7) left hand bottom- white oblong fuses F1 & F2
    Can you test them- (Power off) meter on 20 ohms probe on each end report result - should be same as touching probes together.
    I checked the big capacitor underneath the metal plate and it was reading 280vDC
    Hmm!I think that is either too high or too low - did you have your meter on DC? - can you check it again.
    • welch_41
      • Jun 2012
      • 21
      Good news and bad new -
      I checked those fuses and they read like you expected. Then I reread the big capacitor (using a different multimeter thinking that maybe I had a bad one), huge mistake. It caused an arch and burned the board. Caught me off guard and caused the dogs to jump. I'm not sure if I fried that capacitor because now I'm not getting any reading. You can see the burn in the attachment.
      • welch_41
        • Jun 2012
        • 21
        Out of fear that I might have killed this board, I did some extensive searching and found a reseller that has a few of these power supplies available for sale. Should I go ahead and drop the coins on buying a replacement?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Wow! - I am an optimist and think the board might be repairable, but it is your call.
          I can only suggest what happened either you got the polarity wrong or had your meter on the wrong setting.
          "I'm not sure if I fried that capacitor because now I'm not getting any reading."
          If you are using the same meter that was involved its just as likely you fried the meter. It may have a fuse you can replace?
          If you can clean up the damage zone with meths or isopropyl alcohol and take another pic we can look at repair. If you get a meter to work test the two resistors and the diode D106 - also test the traces for continuity from
          (it looks like R129 to the D106)
          • welch_41
            • Jun 2012
            • 21
            I'm usually and optimistic but just as a safety net, I ordered a new power supply. However, I'm still going to see if I can repair this cooked unit to resale or have as a backup. I'll check the flow of electricity between the numbers that you pointed out while re-posting a clean photo of that blemish. Thanks.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              As selldoor suggested your multimeter may be fried. Post a picture of it and the probes. Some people use their probes when they are falling apart or have obvious cut/nicks in the wiring.
              --- begin sig file ---
              --- end sig file ---
              • welch_41
                • Jun 2012
                • 21
                I was hesitant on using the multimeter because it was free from Harbor Freight. For those of you that don't know what Harbor Freight is, it's a tool/hardware store that offers the cheapest items that you can buy at your own risk. I can take some pictures of the multimeter and post later. It seems fairly new without any cracks or breaks. So how would I check to see if it were fried?
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  1) My first multimeter that I bought was a sort by lowest price ebay "Harbor Freight like" style multimeter for 99 cents. It arrived, thankfully, DOA. After I took it apart, I decided to spend more. When you see how badly they are put together and the potentially high voltage you are measuring (possibly up to 400V DC on SMPS with a PFC), you will quickly change your mind.
                  2) Pictures of that 99 cent multimeter.
                  https://www.badcaps.net/forum/showpo...4&postcount=25
                  3) Note in picture
                  https://www.badcaps.net/forum/attach...0&d=1275345583
                  that single thin strand of jumper wire (the Volt jack in the middle) that is barely soldered on could be carrying 400V DC. And YES, it arrived like that. There were no modifications done by me.
                  4) Recently I was attempting to repair a LG 22 inch monitor. It was made in 2008. As such, most modern LCDs have a SMPS power supply where there is a bleeder resistor that discharges the large filter capacitor in a few minutes once the lcd is unplugged.
                  I hooked up my Fluke to monitor the large filter cap and was TOTALLY SURPRISED that the voltage stayed at 165V DC after I unplugged the power. I left it overnight. The next morning the large filter cap was still at 155V DC. I finally used a 100K ohm resistor to discharge the large filter cap. Had I not checked or used a cheap multimeter that gives false readings, I would have had a nasty surprise.
                  5) 2 years later I now have several used Fluke multimeters that I got a very good prices. One of the latest purchases was a Fluke 27.
                  In addition, I couldn't resist another ebay bargain today so I have another coming. Hmm, which one to sell now?
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #29
                    Open it up and look for a fuse or burnt bits. Post a pic and we will have a look.
                    Initial test - Make sure it has a fresh battery in and put on ohms
                    - probably shoiuld have a 1 on the left side of screen.
                    Touch probes together should go to 0.00 or very close.
                    Switch to volts DC and measure a 1.2v or 1.5v 9v or 12v batteries.- (do you call them batterys or cells?).
                    Back onto ohms check a couple of resistors on your boards see of the results match the color ring code.
                    Then the big test meter on 600VAC plug in your power board and test the mains voltage in.
                    • welch_41
                      • Jun 2012
                      • 21
                      Well I got the new power supply and have hooked it up. I checked the big cap and is reading 165dcv with no source plugged in and doesn't change if I hit the power button. However, it does jump up to near 400dcv with a video source plugged in but eventually goes down to 280dcv.
                      • welch_41
                        • Jun 2012
                        • 21
                        Oh and it still won't turn on. Should I start looking at the main board or am I getting ahead of myself?
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Solid steady 5V DC standby is essential to any modern electronic/consumer device. Is it present and steady on the main board?
                          • welch_41
                            • Jun 2012
                            • 21
                            Before I called it a night, I checked the 5vsb pin on the power supply and it was steady around 2.75dcv. However, I didn't check on the main board. I'll give that a shot today and report back.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              Nothing is going to work with 5V standby at 2.75V DC.
                              Try this with your replacement power board.
                              1) Disconnect the main board from the power board?
                              2) What is the 5V standy reading?
                              3) Are you still using that HF multimeter that is possibly damaged?
                              • welch_41
                                • Jun 2012
                                • 21
                                I disconnected all wires from the main board.
                                The SB5V is now reading 4.94v without the main board connected.
                                I've reverted back to my Radio Shack multimeter.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  Post 262 and on are applicable to your situation since you get 4.9V DC rock solid without the main board connected. See
                                  https://www.badcaps.net/forum/showth...=11329&page=14
                                  • welch_41
                                    • Jun 2012
                                    • 21
                                    Thank you for the help. I will sift through that thread and the ones that run off from it. I know that people mention buying caps from digikey but is there any issue with using Radio Shack parts outside of paying a premium?
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #38
                                      Unless they have a special offer on good brand caps in the size you need
                                      which is unlikely.
                                      Most of the caps they sell are not low esr and are not suitable for this application. They might work but not for long. They are ok for resistors.
                                      • welch_41
                                        • Jun 2012
                                        • 21
                                        Please excuse my ignorance but how do I tell the specs of these capacitors. I've looked around the web for a clear explanation but haven't seen anything...which makes it hard to order replacements from DigiKey.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          The most important parameters are
                                          a) voltage
                                          b) capacitance
                                          c) diameter of cap
                                          d) height
                                          e) esr
                                          f) ripple
                                          For example, EC905 is a 470uF, 25V cap. Now measure the height and diameter. For esr and ripple, see the megathread as I instructed, I wrote instructions just less than 24 hours ago.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • grimacelord
                                            HP 15-EH1070wm - Black Screen With Power LED.
                                            by grimacelord
                                            I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                                            First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                                            01-28-2023, 10:50 AM
                                          • joaquinmjuan
                                            Canon TS8350 Screen Freezes on Power On
                                            by joaquinmjuan
                                            Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
                                            05-07-2025, 12:26 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                            03-31-2024, 02:12 PM
