acer al1916w going bad
  • retiredcaps
    • Apr 2010
    • 9271
    Re: acer al1916w going bad
    Originally posted by 1supertech
    I tested Mosfet’s
    Top Mosfet 1
    D1-->G1 -08.76
    G1-->S1 -000.0
    D1-->S1 -08.81
    Mosfet 2
    D1-->G1-08.84
    G1-->S1- 000.0
    D1-->S1- 08.74
    Mosfet 3
    D1-->G1 08.68
    G1-->S1 000.0
    D1-->S1 08.28
    Mosfet 4
    D1-->G1 08.65
    G1-->S1 000.0
    D1-->S1 08.67
    1) For all your readings, momaka's #1 applies here.
    https://www.badcaps.net/forum/showpo...26&postcount=5
    2) All your mosfets are shorted gate to source.
    --- begin sig file ---
    --- end sig file ---
    • 1supertech
      • Apr 2012
      • 384
      Originally posted by Rtech
      The photo shows one line of pins,what about the other line,are they not marked ?? or is every pin in the top line connected to the pin immedoately below it...suggest some will be eg the Ground,it may be the DET pin,BUT check what the other ones are supposed to be..
      Pic other side top view
      • sabre504
        • May 2010
        • 449
        • United Kingdom
        Bottom row Top row
        1 aol+ - aol-
        2 aor+ - aor-
        3 shut - mute
        4 v adj - +13.8v
        5 +5v - +5v
        6 det - gnd
        7 gnd - gnd
        8 eva - Adj
        F102 is beneath this connector and should be marked w
        • 1supertech
          • Apr 2012
          • 384
          What do you think made them short out age or bad soldering job
          should the f200 fuse protect that side of inverter board?
          • 1supertech
            • Apr 2012
            • 384
            Originally posted by sabre504
            Bottom row Top row
            1 aol+ - aol-
            2 aor+ - aor-
            3 shut - mute
            4 v adj - +13.8v
            5 +5v - +5v
            6 det - gnd
            7 gnd - gnd
            8 eva - Adj
            By connector do you mean power connector? I looked all over for a W
            I know what your saying I have ssen this fuse in one of my ebooks.
            • Rtech
              • Jul 2010
              • 1095
              #26
              Looks like the mosfets need sorting then,before anything else.
              • 1supertech
                • Apr 2012
                • 384
                Will order mosfets today
                What do you think shorted them out?
                • sabre504
                  • May 2010
                  • 449
                  • United Kingdom
                  #28
                  Circled in yellow
                  • 1supertech
                    • Apr 2012
                    • 384
                    Circled in yellow
                    What is circled in yellow I see black lines
                    • selldoor
                      Slow Learner
                      • 7870
                      #30
                      Hi - he has marked where the fuse is with a yellow oblong.
                      Left hand side half way down just to the right of the connector
                      it is a small black fuse with a white w on it.
                      I believe the Mosfets fail because of fluctuating voltages often due to
                      bad caps - you should replace all the caps on the power supply with
                      good make ones - panasonic fm or fc.
                      • 1supertech
                        • Apr 2012
                        • 384
                        I don't believe I missed that yellow square need glasses but any way
                        I ordered a repair kit from ebay
                        http://www.ebay.com/itm/DAC-12M030-R...-/320634046613
                        but as far as that fuse I still can't find it
                        here is the pic of my board looking at the same direction as the other pic that Sabre sent
                        • Rtech
                          • Jul 2010
                          • 1095
                          #32
                          Just goes to show why members ask for photos of Boards as the differences can be many.These mosfets fail whether Caps are good or bad, they just seem not to stay the distance.But change the caps anyway, and hopefully that will out you back in business for a long time.
                          • 1supertech
                            • Apr 2012
                            • 384
                            Thanks to all
                            I will update when my parts come in
                            • 1supertech
                              • Apr 2012
                              • 384
                              Thanks to all
                              Update I received all my parts recapped board all new transformer Mosfet.
                              Turned it on and no image did flash light test I have an image. I think we are progressing
                              Did a continuity test on inverter transformers on primary side top one is 0.752
                              bottom one 0.000 Hope did this right.
                              Another problem is that the original owner of this monitor burned this spot where capacitor joint is can this be fixed.
                              • selldoor
                                Slow Learner
                                • 7870
                                #35
                                Hi Not sure about your test - can you post the numbers off the sides of the transformers and a picture of the underside of your board might help.
                                The solder/trace damage is repairable. Looks like it may be just solerable or it just needs a wire to connect the trace then solder the cap leg to the wire.
                                Youd need to check first that that is where the trace went - will be easier
                                looking at the actual board.
                                • 1supertech
                                  • Apr 2012
                                  • 384
                                  Inverter transformer # both are 2904761000
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #37
                                    Hi - no hits on that number. I have looked at the partial
                                    board picure but its not on there. However if you look
                                    at the top left it looks loke a cap may have been soldered in. -The joint on the right doesnt look great (sorry if you did it) but there is also mark/damage to the trace between the legs. It may be just shadow or flux but you can check its not connecting to the left leg of the cap.
                                    Good I will look at the picture now added - thanks
                                    • 1supertech
                                      • Apr 2012
                                      • 384
                                      Thanks yes I did it shame on me will fix that
                                      thanks selldoor
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        No shame - we have all been there. - May have to hold your hand up to more.
                                        I attach a pic marked with some dodgy bits - may be ok- just for you to check.
                                        Recommend looking over it all with a magnifying glass.
                                        Couldnt tell for certain which were the secondary windings on the transformers - I see the 4 posts have been marked. You will need to number
                                        the posts 1 to9 or whatever then with meter on ohms2000 check pin 1>2
                                        1>3 1>4 ........2>3 3>4...... etc etc and compare the two transformers.
                                        Primary is usually 3-6 ohms will read 0.00 in tet and secondaries 400-1500ohms.
                                        • 1supertech
                                          • Apr 2012
                                          • 384
                                          I fixed my soldering mistakes and fixed the bad trace to the cap by soldering a wire to cap leg it works it fired up
                                            09-06-2024, 05:27 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:00 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) boardview and Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz,...
                                            09-07-2024, 03:10 AM
