Viewsonic/HP LCDs with bad caps
  • Northeastern292
    • Jul 2009
    • 15
    Guys,
    My stepdad has been finding discarded LCD displays through his workplace (he's a carpenter who works in office buildings) and many of these LCDs have bad caps. The plague has also hit these too, but what is surprising is what I have come across.
    Many of these monitors happen to be HP and Viewsonic models, and it bothers me personally as I attend a college that buys strictly Macs, HP PCs and accessories and Dell printers. Need I say more? And the L2045w's that my stepdad has come across have the same capacitor issues it seems. My college also has a few of these LCDs as well.
    Any thoughts? Comments?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Viewsonic/HP LCDs with bad caps
    Many big name companies don't make their own stuff anymore. They get someone else to make it and just put their logo on the front.
    Get your Stepdad to collect them, recap, resell, and help pay your way through college.
    --- begin sig file ---
    --- end sig file ---
    • Northeastern292
      • Jul 2009
      • 15
      A ONE YEAR UPDATE:
      I've saved all the L2045w's from the scrapper. One is the second monitor in my bedroom, the second is the monitor for another computer in my room, the third my younger half brother uses on his machine. A fourth I need to possibly re-solder as I don't think I did a good enough job.
      I've sold a few of my items that I've fixed, given them to friends.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
