Is this cap problem getting worse or better?
  • Hunt
    • Jun 2009
    • 31
    Not been on this forum for a while; I am still using a ViewSonic VX922 that you people helped me repair
    I've just noticed the length of the Samsung Syncmaster 225BW thread https://www.badcaps.net/forum/showth...d=1#post215741 !
    The above tread is enormous! Does this mean the bad cap problem is getting worse?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Is this cap problem getting worse or better?
    The question is ambiguous. There are two interpretations.
    1. "Are capacitors less reliable than those manufactured 5 or 10 years ago?" I would say no, quality caps are more available and of better quality than they were 5 and 10 years ago.
    2. "Are more items failing due to bad capacitors?" I would say Yes. The endurance of a cap is a function of it's hours under stress. When a TV or monitor is in standby the actual power dissipation is quite low, and the caps are under very little stress. As 'power on hours' increases reliability problems will show up. Or as I should have expressed it - "The monitor that is on 24 hours a day will fail due to bad caps at an earlier date than the one that is on only 8 hours a day." We are now getting into the monitors which were seeing less use per day.
    In addition, we are also seeing monitors that are failing due to other causes than bad capacitors.
    PlainBill
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      And #3.
      While better caps are available, they are using worse caps more often.
      Mann-Made Global Warming.
      - Dr Seuss
      • PlainBill
        • Feb 2009
        • 7034
        Originally posted by PCBONEZ
        And #3.
        True. But at 5:22 I can't count that far.
        PlainBill
        • mariushm
          • May 2011
          • 3799
          In an ideal world, as polymer capacitors get cheaper and more ranges available, we should see less issues related to capacitors as companies replace the regular electrolytics with polymers. As far as I see, they're more reliable.
          They're still more expensive even when buying in volume and I know there are some cases where you just can't use them...
          However, it sort of looks like more companies go the planned obsolence route and design their devices in such ways that guarantee at some point their devices fail after a while.
          I'm seeing a lot of devices which have general purpose or 85c rated capacitors near heatsinks, I'm seeing undersized heatsinks, too little or excessive thermal paste applied (which is bad) and I really doubt all this is to save a dollar or so on a 100-150$ device, but rather to guarantee the device will die within a couple of years.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            PlainBill
            I have to.
            The coffee pot takes 3 scoops.
            - Dr Seuss
            • Hunt
              • Jun 2009
              • 31
              In addition to the above, what do you people think about the possibility of panel makers unwittingly using counterfeit capacitors?
              I seem to remember this was a concern or was that just scare mongering.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Scare mongering.
                They buy in vast quantities - direct from the factory.
                If they are using counterfeits - they KNOW it.
                - Dr Seuss
                • PlainBill
                  • Feb 2009
                  • 7034
                  One point that I think bears consideration. Cost / benefit considerations are important for any consumer electronics firm. I think it's pretty obvious that
                  1. A large number of the problems we are dealing with are related to inferior caps, and
                  2. Good quality caps are available.
                  The manufacturers don't find it cost effective to use Nichicon / United Chemicon / etc when CapXon, Elite, etc will supply caps at a lower cost that will last through the warranty period, and several years beyond. Until consumers are willing to pay a premium for a more durable product, we are going to be replacing bad caps, shorted (or open) transformers, and pink CCFLs.
                  PlainBill
                    • Jul 2011
                    • 6046
                    PlainBill
                    I think you might have some thing in what you are saying here
                    For my self I would not mind paying more for better caps
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      As consumers continue to want cheaper, larger TVs, cap quality becomes less important,
                      Especially in cheap/brands like Vizio and Dynex.
                      As long as the majority f the units live past warranty, they're fi e using crp components.
                      By the ti,e issues start showinnbn up online in places like here, theyve discontinued that model...
                      • smason
                        • 1652
                        We have a metric crapload of LG monitors in the office. Almost everyone has a notebook, and 1 or 2 monitors. We've been buying them since probably 2005.
                        We've had maybe 4 fail in warranty, and about 5-7 out of warranty. I take 'em home, fix 'em and donate the 17" and 19" ers.
                        It's almost always bad caps though one was a failed CCFL that killed a dual FET, which I bought for too much from the U.K. replaced, re-capped THEN found the bad lamp.
                        Anyway, my point... even though they have known bad quality caps, and they're connected to power 24/7 (some don't get switched off) the majority have lasted well past warranty. 'course they're all ticking time bombs, and I'm never surprised when one dies....
                        • severach
                          • Aug 2007
                          • 1055
                          I think you would't. Do you prefer servers or desktops?
                          sig files are for morons
                          • PeteS in CA
                            • Aug 2005
                            • 3581
                            • USA, Unsure of Planet
                            As long as there's people who think they can get good quality from cheap crap the cheap crap will be produced. The worst part is that the buyers of cheap crap put pressure on makers of decent stuff to cut a corner here or there just to survive. The buyers of cheap crap don't see consequences of their cheap ways until enough time has passed that they can't see the connection between buying cheap crap and poor product life.
                            PeteS in CA
                            • Hunt
                              • Jun 2009
                              • 31
                              I agree we should not just buy cheap, but the problem is price may not be an indicator of good value since there is limited unbiased information for buyers to judge how good a product is.
                              • Zeonalbasta
                                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                by Zeonalbasta
                                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                09-13-2024, 01:17 PM
                              • perzyk23
                                Lenovo T580 - LCD Panel problem - error 0288
                                by perzyk23
                                Good morning,
                                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                10-25-2024, 12:42 AM
                              • lazaro.089
                                Asus Zephyrus M16 / GU603ZW problem
                                by lazaro.089
                                Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                CPU: Core i9-12900H
                                Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                08-26-2025, 06:33 PM
                              • SDNarcia
                                Dell 15R-5521 keyboard problem (KBC?)
                                by SDNarcia
                                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                As additional information,...
                                07-20-2024, 10:47 PM
                              • s_specialist
                                Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                                by s_specialist
                                Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                                07-07-2025, 11:47 AM
