Swapping CCFL bulbs
  • Mr Bill
    • Nov 2011
    • 648
    Swapping CCFL bulbs
    I have one widescreen monitor and one widescreen tv/monitor. Both are 19" The tv has a cracked screen and the monitor has the pink glow.
    Heres the stinker.....
    The tv only has 2 bulbs whereas the monitor has 4. Could the monitor work with 2 bulbs though its designed for 4?
    I'm just curious and i don't want to tear into it and then it be a big waste of time. Wanting to do this the freebie route since both devices were throw aways.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Swapping CCFL bulbs
    It depends. Some modification of the inverter circuitry may be necessary. The modification may not even be possible in some cases. And it depends on how clever you are. Pictures of the inverter will give some idea of your chances for success.
    • Mr Bill
      • Nov 2011
      • 648
      Here is a picture of the inverter side. Let me know if you need a shot of the power supply side.
      • PlainBill
        • Feb 2009
        • 7034
        This tells me enough to lead me to believe it's not going to work. The design uses a single secondary on each transformer. The CCFLs are in series with the current sense components tied to ground. I'm assuming the TV CCFLs are a larger diameter to give more area to glow. The monitor uses a higher output voltage so the current can be lower. The TV used a lower output voltage and higher current. I can't see any reasonable way to get them to work together.
        PlainBill
        • Mr Bill
          • Nov 2011
          • 648
          Thanks for the input.
          I just went ahead and ordered the 4 ccfl kit from ccfl warehouse. I've never soldered the bulbs but atleast i can say i attempted it.
          • rpgruss
            • Jan 2012
            • 124
            I re-tubed a 32 inch LCD, what a pain. It had 10 bulbs, lucky I only broke one taking them out, and none putting them in. Make sure you get the right diameter, I could only find one size and it was just barely smaller than the original, still fit in the clips, but on an all white screen you can see lighter and darker bands. Who knows what it's doing to the inverter too. Not to mention taking apart the panel...I doubt I would ever do that again.
              by momaka
              03-15-2023, 10:17 PM
            • DanPoka
              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
              by DanPoka
              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
              02-15-2025, 05:05 AM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • wattage
              AOC AG493UCX 49-inch monitor - Firmware request
              by wattage
              Hello Badcaps Community,
              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
              07-13-2025, 04:41 PM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
