Re: view sonic vx2035wm flashing blue power lite dark svreen
That is normal for most monitors - without a signal you are unable to access the menu.
PlainBill
Let me think about it but I may just give up on for now. You were very helpfull and I wouldn't have goten this far without your help.
One other thing I noticed that even with the voltages stable I was never able to bring up the menu and when I turn on the monitor without the analog cable connected I get a message on the screen that states no signal analoge cable disconnected then it goes away.Leave a comment:
1) Okay, that new picture helps. Unfortunately, I don't spot anything obvious that is wrong.
2) My best guess right now is that something is wrong on the main board if the analog and DVI signal cause the voltages to fluctuate. Since you say the voltages are stable when there is no connection, it sounds like the main graphics chip might be shorted internally?
3) A really long shot would be to recap the entire main board?
4) I'm out of ideas for now.Leave a comment:
I forgot to point out that sometimes in circuit readings are not 100% accurate and you have to desolder the component to get an accurate reading.Leave a comment:
Main board has the hdmi, rca connections. The 2 previous photos you have are not clear enough to make details (all fuzzy). It should be like this clear so we can make out all the detail and suggest test points.
https://www.badcaps.net/forum/attach...0&d=1290283049Leave a comment:
is the main board the power board the one we have been working on?Leave a comment:
Those readings indicate that the SMPS IC is working fine as per page 5 of
http://pdf1.alldatasheet.com/datashe...C2/LD7575.html
Can you post a clear focused picture of the main board (front and back) as close to 2000x2000. Use macro mode if your camera has one.Leave a comment:
16.4 volts across c809
16.4 volts on I801 pin 4 and 6Leave a comment:
same symtomsLeave a comment:
analog computer cableLeave a comment:
the readings for I801 g to pin 6 is .417m
D810
.214
.909
.214
.909
D812
.220
lnf
.219
inf
I'm not an electronics expert but I would expect to see the same readings on both. I would expect to see inf on the reverse readings so maybe D810 has a problem.
If a diode read the same in either direction, it is shorted.
Did I mention that when the signal cable is disconnected the voltages settle in and the blue flashing lite goes solid orange.
Which one do you call the signal cable?Leave a comment:
You were corect I did have P801 connecters reversedLeave a comment:
I wasn't able to get the voltage reading since I have to get them off the bottom of the card and I cann;t get to the test points with the cables connected.
D810
.214
.909
.214
.909
D812
.220
lnf
.219
inf
I did the reading using the center pin and going to the outside pins. I hope that was the correct way to measure the dioads.
All my soder points are fine and making good connections.Leave a comment:
That is why I suggested #5 to doublecheck all your solder work especially in this area around D812, C823, C825, C822, and R833.
Some of things I'm asking you to check is more for verification. I have an idea what to expect for #1 to #4, but it is nice to have confirmation.Leave a comment:
thanks, I'll work on tomorrow and report backLeave a comment:
Refer to the schematic.
1) With power off and lcd unplugged, test diodes D810 and D812 using the diode test function on your multimeter. Report your diode measurements. You should have 4 readings per diode.
2) With power off and lcd unplugged, measure the resistance between pin 6 (Vcc) and pin 4 (GND) on I801. Report your ohm measurement.
3) With power on and lcd turned on, measure the DC voltage across C809 (10uF 50V). Report measurement.
4) With power on and lcd turned on, measure the DC voltage on pin 6 (Vcc) using pin 4 (GND) as ground on I801. Report measurement.
5) Check all your soldering work for solder bridges and gently tugging on all caps to see if they are held in solid.Leave a comment:
I replaced the two caps and fixed the loose connection on c825 and I still have the same problem. Any ideasLeave a comment:
by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,... -
This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:50 AM
This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
- Loading...
