Gateway FPD2485W | 2 second to Dark
+ More Options
Posts
  • Acidrainopg
    • Feb 2012
    • 16
    Greetings all,
    I want to thank all those that will answer my thread in regards to my issue. I have done a search on this website and elsewhere, I have the same symptoms of many others however I don't believe that my problem isn't as far as so many others.
    Gateway – FPD2485W | 24”
    Some Details: In the last couple of days, I have experienced what so many have in regards to their LCD TV monitor, going blank after attempting to turn it on. I receive what others have stated as being the 2 second to black screen. When I have experienced this, I have waited aprox 10secs and tried again and it turns on just fine, that was yesterday. Today, it wouldn't catch even after trying, waiting to try and power it up again, and nothing. Therefore, I unplugged it and it turns right on. As well, I want to note that this only happens after perhaps the monitor sitting for aprox 12hrs or more, but if I turn it off and on throughout the day, I don't experience this at all.
    All power LED lights come on, they flicker off after trying to turn the monitor on but the blue LED lights are in there normal position and DON'T go dark, but no picture, I do receive the logo, which flickers and goes off with no picture and ive notice that the screen coming on is a lot slower than usual.
    Iam receiving no unusual colors, or lines, I do receive a slower start up. Screen image disappears after several seconds. No diming of the monitor as well, is as bright as it has always been.
    In researching these problem through your website, to that of some videos on Youtube which I have found to be very useful as well. I just have a few questions in regards to my specific issues, while there are those that have the same issues, I don't believe mine per se have become sever problem that others have had.
    Note: My monitor power button is a censor, not a physical button itself.
    What I have done at this stage; I have researched a lot to understand the problem, through your website and others.
    Questions: I have not taken the monitor apart yet, in order to understand the situation and receive some answers to my issue, I realize that I need to take apart the monitor however, which part would I be looking for per se?
    In researching, I feel confident that I can do what needs to be done, I realize I need to inspect that of the board itself, but like I have stated, I have a censor button, not a physical button, if it is the power board or that of the inverter board, or are they one in the same?
    I look forward to some clarification on my situation and my problems.
    Cheers,
    A
  • Jont3
    • Jan 2012
    • 24
    Re: Gateway FPD2485W | 2 second to Dark
    When the lcd goes black, is the panel still active? try a flashlight or such in front of panel.
    As in backlight still on?
    • Acidrainopg
      • Feb 2012
      • 16
      Jont, thank you for answering my post. When the LCD goes dark, the panel is still active, on the two normal, which shows the power button and the menu button both blue and active while the others that come on during power up go off in normal manner. I hope that clarifies.
      • Jont3
        • Jan 2012
        • 24
        I´am not sure if i understand you right here, when monitor starts backlight goes off and everything else seems normal? if so, and you put an heavy amount of light on the screen do you see the desktop/boot up?
        • Acidrainopg
          • Feb 2012
          • 16
          Not a problem, when i boot up my PC in the morning it is coming up from being asleep. The PC comes up fine, i wait a few secs to wait for the PC to boot up, then i hit the power button. At which time all the LED lights come on as normal when turning on the monitor. Within a few secs, the logo appears, and goes off, while all the LED lights go out, except the menu button and the power button but that is normal. So i wait a few seconds and try and again and it does the same thing, instead this morning i unplugged it to bring the monitor on and it came up. I hope that clarifies.
          • Jont3
            • Jan 2012
            • 24
            Well, you would have to open up the monitor. This could be multiple faults, checking overall condition (defects, burns etc) and seaching for bulgy caps on the power and inverter board is the first step.
            • Acidrainopg
              • Feb 2012
              • 16
              Ah, well i wanted to get some clarification. Thank you.
              I would welcome other people and there positions on this problem?
              • jetadm123
                • 2169
                I do remember reading that there were some problems with the touch control panel for these type monitors. It uses some type of capacitive discharge circuit that uses the electrical discharge from your body to complete the circuit. Perhaps another member can further elaborate on it.
                As for your 2 seconds to black problem, it can be caused by bad caps, bad ccfl's, bad ccfl wirng, bad transformer or bad sense circuitry.
                As you can see, we can talk about the problem until we're blue in the face and not accomplish anything. What's needs to done first is a visual inspection to look for bloated caps or burned parts. If none found, then voltage/resistance measurements of various components. Of course, none of this can be done until you open it up and post some good focused overhead photos of the top and bottom of the power board. And a overhead photo of the top of the logic board. Do not post photos inline, but use the manage attachments option.
                • Acidrainopg
                  • Feb 2012
                  • 16
                  Jet,
                  Thank you for the response, i will be doing what you have suggested soon i simply want to try and make sure i understand everything before i go diving into the situation.
                  What you had suggest din regards to the sensors, would you have any idea where i could look into in regards to the possible sensor online or here?
                  If i may ask, what does cclf's and cclf's mean? As well, could you further explain in regards to the possible bad transformers or bad sense circuitry?
                  As for when i do attempt to take apart the monitor, ill be taking hi-rest images and i will post them as you have suggested.
                  Again, thank you for the detailed response. Much appreciated and i agree we can discuss these things until we are blue in the face. Though i wish to make sure i understand everything before i attempt, again i appreciate his site and the other detailed experiences that i have researched on the same monitor.
                  Question; In my area, i only access to Radio Shack, however those on these boards have stated, not to use anything from RS, could anyone further elibreate in regards to being able to obtain these items i will possibly need in order to fix this problem?
                  • jetadm123
                    • 2169
                    Originally posted by Acidrainopg
                    Jet,
                    Suggest you perform a search on this site for the FPD2485W. There are several good threads pertaining to your monitor. This thread is a good starting point:
                    https://www.badcaps.net/forum/showth...ay+touch+panel
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      http://en.wikipedia.org/wiki/Cold_cathode
                      2 seconds to black in great detail starting with post #19 at
                      https://www.badcaps.net/forum/showthread.php?t=10419
                      Follow the instructions in my sig file below exactly when uploading pictures. NO inline pictures.
                      A SMPS application requires low ESR caps. Radio Shack is unlikely to sell these types of caps. They are likely to sell general purpose caps which are unsuitable.
                      Everything is explained in the troubleshooting guide.
                      --- begin sig file ---
                      --- end sig file ---
                      • Acidrainopg
                        • Feb 2012
                        • 16
                        retiredcaps,
                        I appreciate it and ill be going through all that you stated and again thank you. Iam going to research further into this entire situation as it is difficult to simply find a common solution and resolution to the situation.
                        Cheers,
                        A
                        • Acidrainopg
                          • Feb 2012
                          • 16
                          Hey guys,
                          Well i finally had some time to do this, here is the pictures as requested. I look forward to your findings, also just to let you know i had noticed the ones that look bad are also rather loose.
                          Acidrain
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            See section 1 of the troubleshooting guide in post #19. It will explain, with an example, how to choose replacement caps.
                              I can see at least 3 bad caps with domed tops, very common in all MONITOR BRANDS as you can see in my albums if you want to see them.
                              http://s807.photobucket.com/albums/yy352/budm/GATEWAY/
                              See PDF of your picture that I red circle the bad caps.
                              • Acidrainopg
                                • Feb 2012
                                • 16
                                Thank you replying, i bought an entire set through some of the recommended site everyone had referenced. Are my pictures clear enough to know which ones? Iam going to go pick up volt meter for the checks.
                                • Acidrainopg
                                  • Feb 2012
                                  • 16
                                  Thank you so much for replying, it is much appreciated and your explanation. As well, when i took the monitor case apart it had pulled the sensor wire off of the case wire, how is the best way to reattached? Iam heading to my inlaws to use a meter on them. Give update soon
                                    Oh, I was hoping you did not detach the ribbon cable from the front bezel, real hard to put it back in since it is very short, I had to use tweezer to slip it into the socket and flip the tab back down. You can easily damage the small conductors at the end of the cable also. The first time I did it took awhile to get it back in place properly otherwise not all the functions will work.
                                    • Acidrainopg
                                      • Feb 2012
                                      • 16
                                      I was afraid of that, any good information or good pics in putting it back on? It seemed as if there is no place to place it, as it seems as it was just stuck to the lead. I would appreciate anything you can help with.
                                      • Acidrainopg
                                        • Feb 2012
                                        • 16
                                        Greetings all,
                                        I have successfully changed out all the damaged capacitors and replaced them all and the Monitor is once again working. Ill update in a few days if anything comes up, but i suspect that nothing will.
                                        Thank you all so much!!!!!
                                        Acidrain
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
                                          Wise Wing F199 19'' LCD monitor - recapped
                                          by momaka
                                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                          When I saw the Craigslist post, I wasn't...
                                          08-24-2020, 10:58 AM
                                        • sew333
                                          Pc shutdown, monitor flickered with no signal after 10 seconds
                                          by sew333
                                          My pc:
                                          10850K stock 4800mhz stock Kraken X73 good temps
                                          2x16 GB DDR4 GSKILL 3000mhz XMP
                                          Seasonic Tx-850 Ultra Titanium
                                          Gigabyte Rtx 3090 Gaming OC
                                          Aorus Z490 Pro Gaming
                                          1 TB SSD
                                          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                          Power...
                                          02-22-2022, 10:27 AM
