Fixing DAC 19M005, what fuse value?
+ More Options
Posts
  • chico1st
    • Jan 2012
    • 21
    I am trying to fix my DAC 19M005 BF REV 01A and I was wondering what the F200 fuse value is.
    In the schematic (here) it states that the fuse is a 4A for the 00A REV whereas on this ebay kit it states that the fuse is 2A but 4A fuses are available.
    Anyone have any idea which is correct for my REV01A?
  • jetadm123
    • 2169
    Re: Fixing DAC 19M005, what fuse value?
    What number or letter is stamped on the original fuse?
    • chico1st
      • Jan 2012
      • 21
      It was "W" or "M"
      Also i assume i should be ordering fast blow fuses, as opposed to standard or time delay.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Hi, the "W" indicates it is a 4A fuse and is available as follows
        http://uk.mouser.com/Search/ProductD...-SF-1206F400-2
        The Ebay advert also goes on to say
        "IMPORTANT:
        The fuse that you will be replacing is referenced "F200" on the PCB.
        *(You may request a substitution of the 2A fuse for a 4A fuse.
        Be sure to include this request with your PayPal payment.)."
        A 2Amp fuse will give your circuits better protection but may blow more often.
        Ideally you need to know first what caused it to blow and if you dont youd better buy a few. There are a few posts on this forum which may help you if you've not aleady read them.
        • Babbar
          by Babbar
          04-12-2024, 01:12 AM
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
        • jshhh
          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
          by jshhh
          Hi guys,
          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
          Anybody know how to remove this type of fuse?
          (The fuse is toward the bottom of the image labeled F2)...
          06-17-2025, 01:35 AM
        • drykid
          Matsui 175S microwave fuse replacement
          by drykid
          I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
          Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
          12-21-2020, 01:15 PM
